Old 09-14-2021, 11:46 PM   #2151
Gregski
Gregski's Avatar
Re: A '54 named Busty
and the glass was in
Gregski is offline   Reply With Quote
Old 09-14-2021, 11:48 PM   #2152
Gregski
Gregski's Avatar
and last we had to put in the vertical felt channel for the big glass, I used some stickem on this, the wrenches were used to press them in and they are just the right thickness to glide through the entire groove
Old 09-15-2021, 08:42 AM   #2153
daddyjeep
daddyjeep's Avatar
They look More Better
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 09-15-2021, 08:57 AM   #2154
Gregski
Gregski's Avatar
ha ha, why thank you, I appreciate that, we were rockin' even got the bottom weather strip metal retainers screwed on with them new fancy teflon or what ever coated screws (we'll see how quick they rust... report at 11)
I tell you what, the details belong to the devil that's fer sure, you agree or disagree?
CAUTION FROM THE FUTURE ME: this proved to be an Epic Failure and a waste of money. I could not get the doors to shut with this weather strip on no matter what I did. I even tried only running it above the windows and still had to push on the doors with both hands while standing outside the vehicle to finally get them to latch, not the way you wanna haul your girls around.
Old 09-15-2021, 09:43 AM   #2155
8man
Just got back, and saw the vent window rivet compression tool you used. Yep, brought back memories. I went through 2, one per side getting those little suckers compressed properly.
Good JOB!
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 09-15-2021, 11:57 AM   #2156
Gregski
Gregski's Avatar
Good JOB!
you're telling me!
I mean those fragile tubular rivets must be made out of Kryptonite, look what they did to my sheet metal brake bar I used as a backing to hammer them down (and that's from Harbor Freight so you know it's gotta be good! and made from unobtainium)
Old 09-15-2021, 11:58 AM   #2157
8man
Yes, those vent rivets are definitely Kryptonite.
8man-aka Robert
Old 09-15-2021, 08:31 PM   #2158
Gregski
Gregski's Avatar
so Bad News and More Bad News
so, first the Bad News
so I hung the passenger door and now it won't shut all the way like it used to, all I get is the first click
now I've heard of this happening, and I did go with the thicker weather strip thinking I got gaps the size of the Grand Canyon to fill, but what is disappointing is how good it used to shut before, I mean you could fling it with your pinky finger and it would close all the way perfectly
Old 09-15-2021, 08:34 PM   #2159
Gregski
Gregski's Avatar
... and then this happend!
now I didn't slam the door, so I think maybe I broke it carrying it in and out of the garage to work on it, maybe
either way no further updates tonight as I may or not be hydrating if you catch my draft [I mean] drift, and yes I did mount the door before putting the triangle back in but you need the door hung to adjust the thing ma jigs
Old 09-16-2021, 08:32 AM   #2160
8man
That sucks! Keep the faith and keep moving forward.
8man-aka Robert
Old 09-16-2021, 09:05 PM   #2161
Gregski
Gregski's Avatar
so I woke up this morning had some coffee and decided to look up the price of a new passenger side window
and bam, it's only $90 bucks, no problem, hewk, I might just break the other one for funsies
that got me remotived, so I went ahead and popped out both windows
the passenger side slid off the track real easy, the driver side fought me all the way which made me want to get it off even more and clean that track properly even more
once the windows were out in the wild I noticed an unusual flat spot in the middle of both tracks
Old 09-16-2021, 09:08 PM   #2162
Gregski
Gregski's Avatar
here's that flat spot on the driver side with the window in the door, it's hard to explain but it just looks like its worn in that area, sorry the pic turned out blurry, you can sort of make out the cleaned up and greased channel
Old 09-16-2021, 09:13 PM   #2163
Gregski
Gregski's Avatar
guys I don't know what the regulator roller ought to look like but I doubt they are supposed to be thin and razor sharp like pizza cutters
I think on modern cars they got white plastic wheels on them like our bedroom closet doors
Old 09-16-2021, 09:37 PM   #2164
Gregski
Gregski's Avatar
got the driver side door hung, and it also doesn't close all the way - thinking about putting the truck on Craigslist jk
So this proved to be an Epic Failure and a waste of money. I could not get the doors to shut with this thicker 11/16ths weather strip (wonder if the 1/2" would have been better) on no matter what I did. I even tried only running it above the windows and still had to push on the doors with both hands while standing outside the vehicle to finally get them to latch, not the way you wanna haul your girls around.
Old 09-16-2021, 09:43 PM   #2165
Gregski
Gregski's Avatar
and got the triangle back in and let me tell you, Christ on Crutches getting the bottom 1/2" bolt up the vertical channel was a nightmare, sliced up my forearms real good, and may have even invented some new cuss words
and what's the result? well the window goes up and down with the same resistance as before, so not smooth, so it wasn't the crudy weatherstipping that was binding it
as mentioned above I suspect a combination of a worn out window channel and a hellish regulator roller
Old 09-17-2021, 08:26 AM   #2166
youngrodder
youngrodder's Avatar
They do sell new regulator rollers (wheels). They are press fit. I replaced one on one of my regulators. I was suspect on how well it would install but it was a piece of cake.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 09-17-2021, 09:13 AM   #2167
Gregski
Gregski's Avatar
Marc
Thanks Marc, this is what the one from the Filling Station looks like, did yours look like that? just wanted to confirm before I spend $3.00 on a kit, ha ha
please and thank you
Old 09-17-2021, 09:16 AM   #2168
8man
What a PITA!
It's Friday. Do something nice for your girl. Then Karma can help next time you are working on the truck.
8man-aka Robert
Old 09-17-2021, 09:26 AM   #2169
Gregski
Gregski's Avatar
What a PITA!
OMG, you read my mind bro, the plan was to have the truck ready and go on our first date night in it tonight to BJ's for some pork chops and Hefefeizen and then see the new Clint Eastwood movie Cry Macho, now that I think about it, it sounds appropriate, ha ha
Old 09-17-2021, 09:54 AM   #2170
youngrodder
Yes that's it. Once you insert the shaft into the wheel and into the arm of the regulator you smash the end over to secure it. I used my bench vice under the arm when I smashed the end over with a punch. I grinded off the old one from the regulator arm. You probably already had that figured out.
Also come good grease in the regulator track helps.
Good luck
Marc
Old 09-19-2021, 09:57 PM   #2171
Blue GMC
Blue GMC's Avatar
Finally finished the the Rusty build yesterday and jumped and finished this one today. Hell of a good job man.
No we have seen a 4.8 ls put in and a 5.3 ls in Busty the only way to top that would be a twin turbo diesel in Dusty think of all the room that has to be filled under that hood!!!
Blue GMC is offline   Reply With Quote
Old 09-19-2021, 10:58 PM   #2172
Gregski
Gregski's Avatar
oh wow, thank you so much, you know there is a 6.0L LS, hmmmm? (I'm trying to grow some jeuvos rancheros to do a YouTube video series on the Dusty build)
Old 09-20-2021, 05:03 PM   #2173
daddyjeep
daddyjeep's Avatar
Just do it. Don't worry about your first few videos not being great. Just keep at it and they will get better.
04 1500 crew cab
Old 10-01-2021, 02:07 PM   #2174
Gregski
Gregski's Avatar
Pay Day = Parts Order
just ordered two new windows with tracks and two regulators
Old 10-01-2021, 02:14 PM   #2175
youngrodder
Look at you big spender....guess you wont be retiring for a few more years.
Marc
