Old 08-29-2021, 06:51 AM   #26
darkhorse970
darkhorse970's Avatar
Re: My GMC re-restoration
Great build and write up! I’m following along.
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 09-11-2021, 08:54 AM   #27
Moore87
Active Member
Exhaust is done. Bumper back on. It’s a running and driving truck now. Need to shim and align the bed/cab better then move on to paint/body
Moore87 is offline   Reply With Quote
Old 09-11-2021, 09:14 AM   #28
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Love your shop, I'd love to have a wood bed and stainless steel exhaust! Perhaps I could just drop by and you could sort me out! LOL
Great work and that green is the only color I like better than my Bronze (but I do like my white with it).
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 09-11-2021, 09:18 AM   #29
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Originally Posted by Moore87 View Post
Painted the axle, installed 3.73 gears and a Yukon locker
Also finish welded everything in the rear and did the final assembly on the 4-link
So you were just able to upgrade the stock rear end 3.08 with the 3.73/locker stuff? I been wondering about a upgrade like that myself.
Richard
Old 09-12-2021, 06:30 PM   #30
Moore87
Active Member
Thanks for the feedback. Yea the 3.73 and locker is a pretty simple upgrade if you know how to do gears. I’ve done a few sets now. Just time consuming if you don’t do them all the time. Mine took 3-4 hours or so
Old 10-04-2021, 04:34 PM   #31
cjohnson6772
cjohnson6772's Avatar
Little progress. Found some original doors locally at a great price. No rust through. One has a speaker hole to be fixed and the other has a dent but no big deal
Pulled the rear and finish welded the 4 link. Bent up some brake lines and mocked up my 2014 mustang brake calipers. Went to install the gears but ran into a snag with my parts. Awaiting replacements
I know that everybody says this lol but I have been staring hard at the Durango 350mm rotors for the front of my truck and mustang calipers for the rear because of parking brake!
What rear rotors did you use? Did you have to machine the center bore on the rotors for the front or rear?
cjohnson6772 is offline   Reply With Quote
Old 10-04-2021, 07:03 PM   #32
Moore87
Active Member
I chose to machine the hub and axles so I use 100% stock off the shelf rotors
Rear rotors are 330 mm Durango as well
Old 10-04-2021, 07:42 PM   #33
cjohnson6772
Awesome. I am going to look into the same. I think that this may be the most practical brake set up I've seen. Really nice build so far. I'm excited to see how you finish it off! Thanks for the replies.
Old 10-05-2021, 01:27 PM   #34
SkidmoreGarage
Nice job! We are in similar spots. My truck was a little rougher to begin with, but the build directions and priorities are similar. I just got mine back on the road after doing the suspension, tank, and interior (among just about everything else).
I'm going to be redoing my exhaust shortly. The stainless tubing should show up today. That's an interesting choice about under the axle. Does the four link not have much droop? To avoid this issue, I plan to exit in front of the tire.
SkidmoreGarage is offline   Reply With Quote
Old 10-06-2021, 09:24 AM   #35
Moore87
Active Member
The coilovers have 5.25” total travel. I have it setup for 2.5” up, 2.5” down. I asked Rob at no-limit about the exhaust and he suggested under the axle or out the side in front of the tire. I was surprised you can’t see any of my exhaust unless you are actually looking for it. Fuel cell hides it
Old 11-18-2021, 03:48 PM   #36
cjohnson6772
Any more updates on this build? Did you ever install NVU gauges or PB hood hinges. Interested in the install and feedback on both of those pieces.
Old 11-23-2021, 08:24 PM   #37
Moore87
Active Member
Unfortunately been working on a couple other cars to make $$ for this build. I have enough parts for the phase 2 ready to go. Will start back up in a few weeks
I have the NVU gauges installed. Work perfect. My only issue is I ran my tach wire in my main wiring bundle do it is catching some interference. I’ll fix that when I rewire it
Old 12-20-2022, 11:03 PM   #38
Moore87
Active Member
Took a long break to finish a couple other trucks but now I’m going again. Also moved and had to setup a new shop. A bit smaller but functional
Had to rework a new bedside to match the tailgate. Love repop parts
New to me OEM doors. No rust. Cost me some $$$ but worth it. Fitment is way better than the aftermarket ones I had
Old 02-02-2023, 07:48 PM   #39
Moore87
Active Member
Enough upside down photos
Got the front end back on. Good gaps, and doors open/code easily with GMC Paul’s push on weatherstrip
Also got the grille fit. What a pain. Had to move the mounts on the drivers side because it was shifted 3/8” to the passenger side. Also had to break the spot welds holding the headlights in and reweld to center them in the trim
Got the vintage air condenser in
Old 02-02-2023, 07:50 PM   #40
Moore87
Active Member
Got started on the under hood filler panels after I installed the porterbuilt hood hinges
Also mounted the battery under the bed on a custom drop down mechanism I designed
Old 02-03-2023, 09:20 AM   #41
cj847
cj847's Avatar
Any time someone moves a battery to that position I like to remind them.....
Be sure to build a shield of some type to protect it from mud, tire rubber chunks, rocks, etc. Ask me how I know....lol.
cj847 is offline   Reply With Quote
Old 02-03-2023, 12:11 PM   #42
nicklear36
nicklear36's Avatar
Do you have a picture of your battery shield? I'm in the same boat
nicklear36 is offline   Reply With Quote
Old 02-04-2023, 07:58 PM   #43
cj847
cj847's Avatar
No pics. It was actually on a Willys wagon. I ended up moving the battery inside the frame rail on it as I found some room.
Old 02-17-2023, 12:27 PM   #44
Moore87
Active Member
Yep its on the agenda. Shouldn't take too much. Plan is to have a simple formed stainless shield
