10-07-2021, 06:25 PM | #1 |
Rear axle question
Good evening, I have a 1972 k10 that had a 3.07 ratio want to switch to 3:73 ANYONE KNOW IF THIS WOULD BE TYPE 3 OR 4 CARRIER WITH ORIGINAL 3:07 RATIO? I NEED TO FIGURE OUT CARRIER INFO FOR ORDERING PARTS
STAMPED GM 56 ON ONE SIDE OF HOUSING Last edited by MDFarms; 10-07-2021 at 06:32 PM. |
10-07-2021, 06:42 PM | #2 | |
The Older Generation
Re: Rear axle question
Ratio should be stamped on the metal tag fastened to the top bolt. If it only has the tooth combination stamped on it go to the red chart in post #2 in this thread to look it up. http://67-72chevytrucks.com/vboard/s...d.php?t=578793 I can't help you on the series. LockDoc
10-07-2021, 07:18 PM | #3 |
K10? Are you changing the front gear too? Figure the need another differential case
Your 3.08 is a 3 series and the 3.73 is a 4 series.
10-07-2021, 08:05 PM | #4 |
The 3.08 gears are on a 3 series carrier from the factory. If you want to go to 3.73's on the 3 series carrier you can use a "Thick" gear set. That is what I did with my Burban.
Do you currently have a posi? https://americanpowertrain.com/shop/...-a-3-73-ratio/ https://www.differentials.com/techni...arrier-breaks/
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
10-07-2021, 09:05 PM | #5 |
the tag said 3.07 i believe and its all correct for year as the date is on ring gears. Yes switching both from 3.07 to 3.73 frnt is a Dana 44.
I thought 3.73 is a series?type 3? I see I have two different opinions here so far. Last edited by MDFarms; 10-07-2021 at 09:13 PM. |
10-07-2021, 09:21 PM | #6 |
Do not go by the tag after 40 years, look at the gears and get numbers off of those. You can use the same carrier in the front
10-07-2021, 09:48 PM | #7 | |
Project Family Values Build Thread Vehicles/Projects: -1971 C10 SWB Fleetside! Gathering parts now, will begin frame-off resto soon... Pleasure in the job puts perfection in the work. -Aristotle |
10-07-2021, 10:34 PM | #8 | |
I wanted to point out that there was a way to go to 3.73's without having to get a new carrier for the rear axle. See the first link I posted above. Fortunately for you the Dana 44 carrier is 3.73 and down so you can use your current carrier for the new 3.73's. See the second link I posted.
10-08-2021, 06:15 AM | #9 |
You may want to pull the cover to be sure. I thought I had a standard 3.07 axle because of the "spin the wheel" test, but was surprised to find it was a posi when I took the cover off. The clutch plates from one side fell out when I pulled the cover. I installed a new clutch kit and all is well.
Steve/NH 1967 K10 327 Short Bed Stepside 2008 F350 Power Stroke 2007 BMW X3 2020 BMW 540xi 1995 Harley FLSTC |
10-08-2021, 07:57 AM | #10 | |
So.it seems I need wide gear set for my carrier. I had cover off and it was not a diff lock unit. Wouldn't mind one though. |
10-08-2021, 08:03 AM | #11 |
Anyone have a good 3.73 posi lock carrier for a GM 12 bolt rear-end they would wanna part with?
10-08-2021, 08:58 AM | #12 |
Depending how you use the truck I would suggest a detroit locker in the rear. Posi rears will lock in after approx 1.5 tire rotations to push you forward but if there is to much torque applied to one wheel they will disengage. Street use is not a big deal but off road it becomes apparent. Pulling a hill on loose gravel is enough for the tire to unlock. I would also not use a govlock type limited slip. They act the same but tend to unlock when you feather the gas. Detroit keep both rears locked together under normal driving and then unlock the tire for turning. I have all 3 types of these units and my gravel driveway let's you know quickly how well each type work.
We have a jeep that we use for the driveway since the 2wd vehicles usually can't make it up the hill. The rear-end was swapped to the ford explorer axle with a factory limited slip. I rebuilt it with the mustang clutches that are stronger and that rear has some odd behaviors. You can feel it lock in all the time and gives a push feeling to the jeep. It tends to get you going at a slight angle. The Detroits don't give me that since they were already pushing the truck forward. Just food for thought since regearing is expensive and you want to get it right the first time. |
10-08-2021, 08:28 PM | #13 |
I just switched from 3.73 to 3.07 I have 3.73 dana 44 gears and 3.73 12 bolt gears and open carrier if you are interested
10-08-2021, 08:45 PM | #14 | |
10-08-2021, 08:47 PM | #15 |
10-08-2021, 09:07 PM | #16 |
I will get some pictures on Saturday
10-09-2021, 09:12 AM | #17 |
10-09-2021, 10:05 AM | #18 |
