08-14-2021, 12:00 AM | #101 |
At the body shop.
Re: 2wd swap
Keeping a 17 yr old motivated is fun.
Baby step getting finished up
" That didnt make it any newer " " Dont antique the equipment " |
09-28-2021, 10:09 PM | #102 |
At the body shop.
Re: 2wd swap
This kid is something else.
09-29-2021, 09:58 AM | #103 |
Re: 2wd swap
I would agree. He's doing well. Especially for being a young-gun.
10-01-2021, 10:45 AM | #104 |
At the body shop.
Re: 2wd swap
Not suspension related.
But weave aluminum? Seriously !?
10-06-2021, 07:09 PM | #105 |
At the body shop.
Re: 2wd swap
Kids showed some initiative.
He wasn't feeling the 2 link plan. So triangulated 4 link it is. And was gifted this 9 inch housing. Got a 2.91 gear and a 31 spline locker for it.
10-08-2021, 06:56 PM | #106 |
At the body shop.
Re: 2wd swap
Any reason not to do the upper links like this and the lower outside the rail?
10-08-2021, 07:02 PM | #107 |
Re: 2wd swap
I did my uppers inside and lowers outside. Did it to push the bags out further.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
10-08-2021, 07:18 PM | #108 |
At the body shop.
Re: 2wd swap
Any pics ?
10-08-2021, 08:36 PM | #109 |
Re: 2wd swap
http://67-72chevytrucks.com/vboard/s...&postcount=407
Lost a lot of pics due to Photobucket. This is probably the best pic.
10-08-2021, 10:09 PM | #110 |
At the body shop.
Re: 2wd swap
Thanks.
I think we're gonna do a triangulated deal.
10-10-2021, 05:45 PM | #111 |
At the body shop.
Re: 2wd swap
So no more 4 link thoughts?
Anyways back to the front end. We raised the upper pivot 1" and cycled the suspension 7 inches has -4° of camber change and 3/8 toe at full bump from ride height.
10-17-2021, 11:16 PM | #112 |
At the body shop.
Re: 2wd swap
That escalated quickly.
10-18-2021, 11:28 AM | #113 |
Re: 2wd swap
As long as the upper links have enough angle for keeping things centered, where the lowers go is likely decided by project packaging. Keeping the links & springs as far outboard as possible should be a benefit to stability. If there's room outboard of the frame, that's how I would do it.
10-18-2021, 07:38 PM | #114 |
At the body shop.
Re: 2wd swap
Tentatively using the stock spring hanger as the lower link pivot.
And boxing the inside of the frame at the hanger for upper link off the diff housing.
10-18-2021, 10:01 PM | #115 |
Re: 2wd swap
Using the OE hangers is how I'd do it as well. Sounds like a solid plan.
10-21-2021, 01:33 PM | #116 |
At the body shop.
Re: 2wd swap
Kids wishful thinking
10-21-2021, 01:42 PM | #117 |
Re: 2wd swap
I mean you already have the body off right...?
Whats a few inches between friends LOL (sorry had to..)
10-21-2021, 08:03 PM | #118 |
Re: 2wd swap
Do it! Looks killer!!!
11-07-2021, 03:34 PM | #119 |
At the body shop.
Re: 2wd swap
Some stuffs.
Raising the floor up 3" makes room for diff and suspension links.
11-22-2021, 08:05 PM | #120 |
At the body shop.
Re: 2wd swap
Welding lots of Welding.
I think he is going to hate plumbing these. But the bag plates fit up was terrible so he cut them up and welded them in.
11-23-2021, 03:26 AM | #121 |
At the body shop.
Re: 2wd swap
Bags look right ?
11-23-2021, 11:33 AM | #122 |
Re: 2wd swap
Looks ok/normal to me.
11-23-2021, 01:43 PM | #123 |
At the body shop.
Re: 2wd swap
Good, the bottom bolt is concerning me.
Looks like aired out it might drag/hit 1st
11-23-2021, 05:41 PM | #124 |
At the body shop.
Re: 2wd swap
I believe the lower bag bolt won't be as much of a issue as these grease zerks.
11-23-2021, 06:35 PM | #125 |
Re: 2wd swap
Wow. I'm guessing the engineers didnt plan on people laying out...
