10-20-2021, 11:54 PM | #1 |
Parking brake calipers- Wilwood
Anyone ever use these?
Are they intended to lock on the wheel rotor? https://www.summitracing.com/parts/wil-120-12069-rd
1963 C20, small window, long bed 292, 4-speed |
10-21-2021, 10:38 AM | #2 |
Re: Parking brake calipers- Wilwood
Those look similiar to the calipers on the rear of my 79 Trans Am. They are a screw in style of piston for the emergency brake. The piston works with hydraulic pressure during normal braking. When applying the parking brake there is a threaded screw in the back of caliper piston that attaches to that arm It puts manual pressure against the rotor to keep it from moving.
79 Chevy 2wd BIG10 350 TH400 |
10-21-2021, 03:17 PM | #3 | |
I'm wondering if anyone makes a mechanical caliper just for parking brake applications. It looks like that is the one I linked from Wilwood. I will have to call them and check.
10-22-2021, 08:39 AM | #4 | |
Yes, the link you posted from wilwood is exactly as you describe, a cable operated mechanical disc brake, typically used for a parking brake.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
