10-20-2021, 08:23 PM | #76 |
Re: 1950 Chevy 3600 Woody R
I was wrong, the firewall needed one more fill!
Should be is primer tomorrow, God willing
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 10-21-2021 at 10:25 AM. |
10-21-2021, 09:08 PM | #77 |
First we drillled the hole for the firewall pass through grommet for the engine harness
Then we welded a tab to bend and hold the starter wires Here’s the firewall masked and wet sanded Here it is in one color Much easier to tell where it needs work, and there are a few places
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 10-22-2021 at 10:34 AM. |
10-21-2021, 09:10 PM | #78 |
then we dragged over a mock up engine and started designing the engine cover
this is the template for the coil covers The lines are where we intend to bead roll
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 10-22-2021 at 10:33 AM. |
10-22-2021, 09:40 AM | #79 |
nice custom touch, looking forward to seeing it in metal.
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
10-22-2021, 10:55 AM | #80 |
Thanks we try
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
10-22-2021, 11:52 PM | #81 |
We did figure out the coil covers though. We have to re-make the left one, screwed up the bead roll.
The transfer of the templates to steel The mock up of the passenger coil cover, it’s out of position and not fastened down yet We will be building a center cover, I just need these figured out first
10-25-2021, 07:22 AM | #82 |
got a nice patina look there too
10-25-2021, 09:45 AM | #83 |
Thanks, but we will be repainting the truck. Patina'd robins egg blue
10-25-2021, 09:54 PM | #84 |
We started the day working the firewall. Bodywork where it needed touchup
And then a final coat of filler
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 10-27-2021 at 09:50 AM. |
10-25-2021, 10:01 PM | #85 |
we wound up re-making both coil covers, the bead roll wasn’t as straight as I thought
Here’s the finished product we primed both sides Tomorrow we build the intake cover and work on the outside of the cab
10-26-2021, 07:35 PM | #86 |
nice...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
10-26-2021, 08:50 PM | #87 |
Thanks buddy
10-26-2021, 09:26 PM | #88 |
so we pretty much worked on the engine cover all day. This is what $30 worth of specialty hardware gets you
so once we had attachment figured out we could begin designing the intake cover
10-26-2021, 09:29 PM | #89 |
the crease is just for templating, won’t be there in steel. The lines represent bead rolls
The idea was a round cover to go with the round lines of the truck
10-27-2021, 09:11 PM | #90 |
The firewall has about done
Here’s the engine cover, now we still have some bending and tweaking to do, but you get the idea the last pic is an idea we had. Putting an oval hole in the side of the engine cover to use the fender supports
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 10-28-2021 at 10:12 AM. |
10-28-2021, 07:33 AM | #91 |
i don't know, something is messing with my eye ... the big center cover just seams kinda too much. maybe the back could be cut in kind of like the front cuts out, just less?. maybe a step between the intake and coil covers to break up the solid plane? maybe i'm missing the look with the rest of the fender and rad covers, or maybe i'm nutz and am just the guy who never really likes full covers too.
but i don't have your final vision, so i shall stay tuned! |
10-28-2021, 10:06 AM | #92 |
dunno, I’ll run the cutting the back idea by my mechanic and see what he thinks
10-28-2021, 10:21 PM | #93 |
We’ve discussed cutting the back of the intake cover and decided against it. The owner is delighted with the look.
10-28-2021, 10:23 PM | #94 |
The last few trouble spots on the firewall
Firewall in primer
10-28-2021, 10:29 PM | #95 |
After some hammering and dolliieng the engine cover is much straighter
I can almost be proud of that!
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 10-29-2021 at 10:33 AM. |
10-28-2021, 10:35 PM | #96 |
Gas filler got it’s final fill and prime
But we found a few more dents
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 10-29-2021 at 10:34 AM. |
10-29-2021, 07:46 AM | #97 |
10-30-2021, 10:54 AM | #98 |
We worked on that hinged center grill
I think it came out looking pretty sharp! Monday we’ll make the radio plate that goes behind Unless you have strong objections, I am going to paint the center of the grill and glovebox door dashboard color And we finally got that right speaker pod in!
10-30-2021, 11:33 AM | #99 |
nice touch with the hinged speaker grill.
What are you going to use for a latch? magnet? Thanks for sharing these ideas,
10-30-2021, 12:37 PM | #100 |
yeah, magnets seem to work best. Powerful earth magnets
