Old 10-29-2021, 05:48 PM   #1
Ironhorse
Ironhorse's Avatar
Mixing Oil Weights?
Well seems along with every thing else being on the short list the oil I use in my '05 Tahoe 5.3 LS engine is added in locally here. I use the Quaker State Full Synthetic 5W30 Dexos2 per the owner's manual. Usually change my own oil /filter and the first time I changed oil I found out the capacity is SIX quarts not the usual Five I have been used to for so many years. Bummer having to be sure and buy ONE extra quart each time. Also use Wix filters when I change.
The Change Oil message has come on the DIC screen several times and I know the oil life percentage has reached 0% within the last week. Oil capacity is good on the dipstick, just about halfway to the first mark below full. Problem is can not find a 5W/30 one quart container. Bought the five quart jug okay, checked three local stores, no single 5W/30 to complete the six needed quarts. Closest I can find is a single 5W20 which I did buy. Thinking can't be much of a difference using the one quart of 5/W20 mixed with the five quarts of 5W/30. Any one care to share thoughts on this.
Hate these shortages in everyday products and items needed.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 10-29-2021, 06:10 PM   #2
Thealien
Thealien's Avatar
Re: Mixing Oil Weights?
I just buy a few jugs and fill an empty quart up from the jugs.
Old 11-04-2021, 04:55 PM   #3
truckdude239
truckdude239's Avatar
1 qt of 5w20 wont hurt
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 11-04-2021, 07:12 PM   #4
Ironhorse
Ironhorse's Avatar
Decided to go this route and filled an empty 5W30 quart container after buying a second full 5 quart jug. Have 4 remaining quarts in that jug so should be good to go for several oil changes.
No WIX filter available at my local parts house. Had to go to an alternative Microguard (?) brand filter? Counter guy said it is made by WIX but is there lower cost alternative? No idea about that, any comments there?
Wellington, Ks
Old 11-04-2021, 07:21 PM   #5
DPowers
One foot in front of the other
DPowers's Avatar
I use the two-quart Wix on my 87. Get it through Amazon and can set it up so an automatic delivery.
DPowers is offline   Reply With Quote
Old 11-05-2021, 12:14 PM   #6
kwmech
Not going to make that much of a difference. What about when you put additives in the oil?? I look at it as the same thing. Been mixing weights for years on the old school stuff. You just have to be careful if you have a VVt system not to get too crazy. Having clean oil to begin with is the number 1
Old 11-05-2021, 05:37 PM   #7
hatzie
Moderator
hatzie's Avatar
Thankfully 2005 is too early for VVT.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 11-05-2021, 06:51 PM   #8
Ironhorse
Ironhorse's Avatar
For the benefit of an old school wrench bender from way back, what the heck is VVT, LOL? Being tech challenged in today's world sure is rough,
Wellington, Ks
Old 11-05-2021, 08:36 PM   #9
57taskforce
All about them K’s
57taskforce's Avatar
For what it’s worth, most Napa filters are wix rebrands… variable valve timing uses an oil psi controlled cam phaser to manipulate the cam timing within a certain programmed amount of degrees to give the best possible low end torque and high end end Hp, and fuel economy. It wasn’t available on the LS stuff until Gen 4 came out in early 06 in the GMT 900 trucks/suv’s
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
Old 11-08-2021, 10:41 AM   #10
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
Variable Valve Timing
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 11-08-2021, 02:09 PM   #11
kwmech
Pretty sure you haven't been read on the Can-Bus systems then?
Old 11-09-2021, 11:13 AM   #12
MJN
MJN's Avatar
Whether you use synthetic oil or conventional this blog always has great information about a variety topics- you can search for topics too.
https://blog.amsoil.com/5w-20-vs-5w-...he-difference/
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
