#76 | |
Re: Bedwood/bed floor ideas ond pictures
#77 |
Looks good! I don't think anyone would know the difference.
Brad handshoe |
#78 |
Plywood underneath & a buddy's old (cedar) fence that blew down in a storm.
"Over my head" 1957 Chevy 3200, big rear window & 6 lug. Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina. |
#79 |
![]() Join Date: Aug 2013
My truck will be utilized fossil hunting so will be exposed to the sun. I wanted the floor weather resistant and tough enough for daily use.
Multiple coatings of POR-15 then two coats of black paint for sun protection. |
#80 |
Not complete but heres what I got
#81 |
![]() Join Date: Feb 2009
#82 |
what year dakota or does it matter?
#83 |
5/8" exterior grade plywood as a base, 125 year old tongue and groove barn wood for the finished bed.
---Shawn Cecil-1953 5 window build thread Skymangs..Chris of Old Sarge customs had a shop fire and was severly injured. To help with the medical bills and expenses a fund has been set up here....http://gofundme.com/c49h5mjx8 More details are here...http://67-72chevytrucks.com/vboard/s...=1#post7253189 |
#84 |
Very very nice.
#85 |
Wow 6 years since anyone has posted their bed! I’m game. Stain looks nice but seems like a pain to keep looking nice when clear coated, would it be easier to just oil or beeswax the wood?
Jan's 53 Last edited by Rickysnickers; 11-07-2021 at 10:17 AM. |
#86 | |
The one benefit to just using oil is that it does need re-application, but when you do, you can easily just wipe it on the bed and be on your way every 6 months, vs. removing the wood, sanding, resealing, and reinstalling every few years.
My Current Trucks: 1958 Apache BBW 4.8LS/4l60 "Lucky" Built By Me 1958 GMC BBW LS1/4l60 "The Kraken" Built By Delmo |
#87 |
Here is a crazy bed wood design. Not sure if it lifts but wow.
1955 second series, 3200 standard bed, big window. Owned since 1975, decided it was time to do a frame off. 327, 4L80e, Ford 9 inch. |
#88 |
Some others I’ve seen at shows that were beautiful. To dang nice to use.
1955 second series, 3200 standard bed, big window. Owned since 1975, decided it was time to do a frame off. 327, 4L80e, Ford 9 inch. Last edited by Rickysnickers; 11-07-2021 at 10:18 AM. |
#89 |
My trucks bed is maple, black dye, exterior water base clear coat. Not sure how well it will hold up over time but the truck is garaged and not generally in the bad weather.
#90 |
I cut my own out of what they call Brown Maple, hardest wood ive ever worked with. 4 coats of the same 2k clear i used on the metal, supposed to have UV protection in it. We’ll see.
#91 |
Not everyone's cup of tea but I am putting a metal floor in mine from a 1997 silveardo. I got a mint bed for 100 bucks and took about a day of drilling spot welds and cutting it to fit. I'm having to tub my bed anyways so this seemed like the cheapest option for now cheaper than lumber and new stainless strips anyways haha. I still have to cut the wheel tubs down I don't like how high they are.
#92 |
Where did you find that gas filler hatch/ cover/ door thing? looks really clean.
#93 |
It might not be perfect but I can show you the hillside where the oak trees were cut in the 70s.
#94 |
That's a seriously nice looking bed in my book.
I've been looking into getting one of the bandsaw sawmill guys selling live edge planks to Rough cut me the boards for a bed out of a log of interesting wood. A friend of mine is still teaching high school wood shop and his students can plane the wood for me.
#95 |
I love it when someone revives old threads. Lots of wisdom herein.
T-111 exterior siding coated with Marine Spar Varathane. The plate is for battery access.
1951 Chevy Panel Truck |
#96 |
After like 5+ beds in 50+ years i wanted durability and longevity over beauty. I used stainless runners and hardware over Lowes Choicedek Fascia (not decking). At about a foot wide it gave me more latitude to fit bed easily. Held up well here against ocean spray.
#97 |
lumber yard pine, I routed and oak stained
![]() 1940 Ford Dlx Coupe 1969 Mach1 |
#98 |
Nice work! I particularly like your wheel tubs!
'59 Apache - 383" SBC/TH-350 '68 GMC - BBC/TH400 |
#99 |
I put a steel box floor in mine. we get lots of temp differences here and I want to not have to reseal or anything once done. I have wondered about a plastic decking like trex though, it is a sold piece and takes maching well if the edges need to be trimmed or routered etc. not sure how it would hold up under the heat of the muffler etc. may need a heat shield, like any bed should also have. my tank filler is in the tep side fender because I do plan to haul stuff and would inevitably need to fill the tank when there is something in the box. filler has a door over it from a newer truck that is reshaped to the fender contour.
#100 |
Now almost 4 years old the synthetic deck in mine is still like new. The stuff cuts and routs just like soft wood. Because i chose to use the thinner choicedeck fascia boards from Lowes i did not rout the runner grooves but simply laid them on top. I spaced the runners to cover the seams and slightly routed them to fit under side bed rails. I too was worried about exhaust heat with only 7-8" clearance but it hasn't been a problem. Having the rails sit proud of the bed material has prevented any scuffs. Again my only regret is not bolting bed in BEFORE tank was installed.
