Old 06-25-2021, 08:46 AM   #1476
reaper71
reaper71's Avatar
Re: "Project Orangepeel" 52 A.D
Haha, I don't have a teen anymorebut that would work
reaper71 is offline   Reply With Quote
Old 11-14-2021, 11:30 AM   #1477
reaper71
reaper71's Avatar
I haven't posted in awhile thought I'd put some shots up.
I did upgrade the door panels with a 50's Era material and suede on the inserts.
Mark.
Old 11-14-2021, 01:03 PM   #1478
8man
The door panels look good.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 11-14-2021, 01:13 PM   #1479
olcarguy
Gotta love it.....Sweet
olcarguy is offline   Reply With Quote
Old 11-14-2021, 05:10 PM   #1480
OutlawDrifter
Good job on the door panels!
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 11-15-2021, 10:42 AM   #1481
reaper71
reaper71's Avatar
Thanks Guys!
Mark
Old 11-15-2021, 10:58 AM   #1482
youngrodder
youngrodder's Avatar
Great job on the door panel. Very unique design.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 11-15-2021, 12:11 PM   #1483
Tempest67
Tempest67's Avatar
what a great looking truck
nice upgrade on the door panels too
Thanks for sharing
Tempest67 is offline   Reply With Quote
Old 11-16-2021, 06:41 AM   #1484
lower50's
lower50's's Avatar
Defiantly sets it off now.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 11-16-2021, 10:26 AM   #1485
reaper71
reaper71's Avatar
Thank you everyone!
The door design was put together by Erin Ruddy @ Ruddymade
he lives here in town and we planned it out when the truck was first put together. (all black then)
Mark.
Old 11-16-2021, 11:10 AM   #1486
Rickysnickers
Honestly speaking, I am not a fan of the patina look. However, this truck is awesome!
Old 12-01-2021, 09:49 AM   #1487
reaper71
reaper71's Avatar
Thanks.
Yeah patina is not everyone's cup of tee.
This a bit of survivor and custom.
Mark
Old 04-03-2022, 11:02 AM   #1488
SARBlade
Junior Member
SARBlade's Avatar
Originally Posted by reaper71 View Post
quick shot of the notch i used a piece of 4" tube..next pic is of it all welded and boxed..
Mark...
Hi, I know this has been awhile since you built your truck, but I see you’re still messing with it, great build by the way! I am starting a project myself on a ‘56, I have the same triangulated 4 link set up that I’m putting into mine. I have a question regarding your install if you’d mine sharing some info. I have a 10 bolt from a Camaro rear end going in, the large cast pumpkin, has issues, can’t weld to it, and it takes up room. I want to do the same direction of angles you used but welding the upper links as close to the pumpkin, and going forward only gives me about 22 degrees of opening vice the 25 I am looking for. Yours appears like the angle is closer to 30 degrees. Also, your uppers appear to point upwards vice inclining down toward the IC of the truck to prevent too much pinion angle movement. Lastly, your bottom bars look parallel with the ground, and are mounted on the inside of your frame. What is the distance in between your frame rails? Mine is 41.5”, this makes it really difficult for me to mount my lowers on the inside, I am thinking directly under the frame rail. Any insight you have would be greatly appreciated. Thanks
Kick the tires, light the fires!
My Build: 1956 Chevy 1/2 SB
SARBlade is offline   Reply With Quote
Old 04-03-2022, 06:10 PM   #1489
reaper71
reaper71's Avatar
Thanks for checking out my build!
As far as the upper bars go the angle in or out isnt as crucial as long as they are parrallel to the lowers.
your 22 degrees would be fine.
Your lower bars... id try to really get them inside if possable depending how low its going to be.
If you mount under the frame they could drag.
When you start to set it up get your pinion angle set @3 degree up and tack a piece of 1x1 tube to frame and top of rear end tube to hold it in place. now it will make getting the 4 bar mocked up easier.
hope this helps
Mark
Old 04-04-2022, 11:24 AM   #1490
SARBlade
Junior Member
SARBlade's Avatar
Thanks Reaper, I will do that, the welder series instructions aren’t that complete, but they do show that there is convergence of the upper and lower somewhere near engine. If they’re parallel, the pinion angle doesn’t change when diff goes up and down. With the two uppers at angles, in theory, they’re arc of travel would keep the diff cantered in the frame, left and right, and would only allow travel up and down depending on how stiff the bushings are. The shorter they are, the tighter the radius, and not much travel. Anyway, I’ll follow your suggestions and build. Thanks for the advise, and I won’t put the lower underneath, you’re right, it would interfere with ground lol
Old 04-05-2022, 10:09 AM   #1491
lower50's
lower50's's Avatar
Sorry to hijack Mark
SARBlade Here is a web sight I used to figure out a 4 link. It talks about a 4x4 but the concept is the same. It is quite forgiving if you have interference in places.
https://www.crawlpedia.com/4_link_suspension.htm
1951 MG TD
Old 04-05-2022, 11:47 AM   #1492
SARBlade
Junior Member
SARBlade's Avatar
Thanks L50!
Old 04-05-2022, 04:24 PM   #1493
joedoh
joedoh's Avatar
i love your truck mark!
Old 04-05-2022, 07:12 PM   #1494
reaper71
reaper71's Avatar
Thanks Guys
