07-13-2019, 01:37 PM | #26 | |
Re: 1967 GMC V6 - 351E on a Camper Cruiser
07-13-2019, 01:39 PM | #27 |
Mike 16 - How weird they'd create fix it's for the engine over that span of time rather than redesign it. Thx.
07-13-2019, 03:00 PM | #28 |
Best way to ruin a large V6 or a large diesel is run it at high rpms. These engines were designed to put out maximum torque at low rpms, unlike most V8's that are designed to put out maximum horsepower at high rpms. High rpms are great for a race car, but lousy for a working truck. V6 valves were mechanical that required periodic adjustment during scheduled maintenance. Why v6's weren't designed with hydraulic valves ( which Chevy v8's had during this period) continues to be a mystery to me.
07-13-2019, 03:12 PM | #29 |
Interesting; I guess the Camper Cruiser, put out in '67 was meant to be driven under 60 mph as the transaxle gears are so high. The lower gears would have allowed for driving into steep camp sites and such at slow speeds with all that torque.
I just noticed, in my project to put the engine back together, that one of the push rods for the valves is bent - a lot - the max in it's sleeve, as the elbow of the bend is roughed up. this probably means the bolt in the cylinder hit a valve - and the aluminum rod bent - which is good! Probably means the valve is undamaged - I don't see any damage. but now Have to find or make another push rod. |
07-13-2019, 03:55 PM | #30 |
To whom may be interested; I found a site with downloadable old manuals and found one for the GMC 351 / 305 ; https://www.manualslib.com/download/...c-305c-V6.html
07-13-2019, 08:05 PM | #31 |
Might find this interesting. Discussing the new line up for '69, Don't know why its loading side ways, photo are upright in my files.
07-15-2019, 03:39 PM | #32 |
Well, that is hopeful. The original transaxle was extremely high geared. You could feel it whine at 50. I realized too that the tires on there are way smaller than the wells so that it would take much larger tires = better milage. I hunted down a lower geared transaxle and had it welded on and never did get to test that for milage as I screwed things up putting on a different carb . . . so - I may have good looking numbers waiting for me! Thanks!
07-15-2019, 03:43 PM | #33 | |
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
07-15-2019, 03:54 PM | #34 |
Yeah, I wasn't too clear on that high low thing. So - if a transaxle or a tranny is low geared it means the wheels go faster at low RPM's and vice versa. right?
I can't get my phone to send to my email to post some pics of the truck. By welded I meant that the axles were just swapped but the drive shaft difference required shortening the drive shaft - hence - the welding - on the shaft. I think it's a ford transaxle I ended up with. |
07-15-2019, 06:53 PM | #35 |
Trying to post a photo of my truck on this site. I click the icon for uploading a photo which asks for a URL for the photo - but the photo is just on my desk top. Any hints? thx
07-15-2019, 08:10 PM | #36 |
Who Changed This?
Make a reply and scroll down to view the "manage attachments" button. Click and a box will appear where you can select up to 5 pics. Click "Choose file", and you then go to your computer and find the file. Click and then upload. This puts a pic in the post. It has to be a file, not a pic you click on your desk top (I think that is true). If you are looking to make an avatar, go to your user CP and edit the avatar. Pretty much the same process to get the avatar pic, but there are some size restrictions.
07-16-2019, 04:19 AM | #37 | |
I never heard of valve train trouble on these engines, just that they gave poor fuel economy and were very expensive to manufacture. The V-6 was good for 200-250,000 miles in highway service when other truck engines were lucky to see 100,000.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. Last edited by Bob B.; 07-16-2019 at 03:04 PM. |
07-16-2019, 02:22 PM | #38 |
Yes I picked up that they had great reliability and endurance from an old add someone posted to me; "Our first V6 went 246,000 miles before it's first service". That's sure attractive - but for the milage thing. With the right carb, largest wheels possible and a different differential perhaps 12-14 mpg possible. It's an impressive engine. I wonder as the literature repeats over and over that the 305 and the 351 are almost identical - does that mean the 305 has the density of steel the 351 has?
07-20-2019, 07:04 PM | #39 |
The 351 was essentially a larger bore version on the 305. There was a heavy duty option on the 305E, not sure about the heavy duty option on the 351E. Maybe Bob B. is familiar with this option and how to detect if a engine has this option.
07-22-2019, 01:50 PM | #40 |
Interesting. I wonder just what 'severe service' means? Very heavy loads, and continuous use probably. So - the 351 was the same block? as the 305? Since the score on the one damaged cylinder is so slight, I wonder if I could just put the rings back in and just run it without even honing? The rings would adjust the slight difference of surface?
07-23-2019, 03:58 AM | #41 | |
I think the easiest way to tell if a 305 has the HD option would be to pull the valve covers and look for the rotaters under the valve springs.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. Last edited by Bob B.; 07-23-2019 at 04:10 AM. |
07-23-2019, 06:31 AM | #42 |
sustained hiway speeds does not mean over reving the motor. just hiway speeds, ordinary to you and me but hard on long stretches for that v6, even at 65 mph would wear it out pretty quick.
valve train repairs, on a steady basis was one solution but you will note that streight six and sbc v8's became available options as well. |
07-24-2019, 12:51 PM | #43 |
Thanks for the input but most of what you say is way over my head! But perhaps you could help me with something? I'm considering putting a 305 in in place of the 351E - on Craigslist they mention 305 "small block" as different from what? a 305 big block I assume. What's the diff and would the small block fit the bell housing of my Camper Cruiser? I think probably not - it would have to be a big block? Thx.
07-24-2019, 06:33 PM | #44 |
Who Changed This?
305 small block is probably a V-8 Chevy. Did the ad say GMC? I could see the SBC 305 in a GMC Sprint. for example. I don't remember if the Sprints were still available by the time the 305 SBC came around, though.
07-24-2019, 09:55 PM | #45 |
Really depends on the gearing. 1/2 ton V6 GMC's came standard with 3.07's. Incorrect gearing was the problem with V6 3/4 and 1 tons GMC's. With 320lb torque @ 1600 rpm's, most should have been equipped with 3.54 ( came too late ) or 3.73's ( not offered by GM at the time ), not the 4.10's or 4.56's commonly found.
07-26-2019, 01:12 PM | #46 |
Thanks. I'll try and put the puzzle together.
07-26-2019, 01:14 PM | #47 |
I'll have to crawl under there and see what I've got. Thx.
12-02-2021, 04:41 PM | #48 |
Hello fellas I am new to this i bought a1967 2500 with a 351E and 400th trans was missing two side gas tanks would like to get them, if anyone has a link or knows of a place to acquire them i would appreciate thanks W.K Thunder bay Ontario Canada tried finding them but no luck thanks again
12-04-2021, 04:42 PM | #49 |
Use to be common aftermarket pieces back in the day, several different manufactures. Doubt if anybody makes them new anymore, especially after the squarebody lawsuits. I would check out Craigslist regularly '67-'72's trucks being parted out.
12-06-2021, 02:02 PM | #50 |
Or if you had dimensions you could have Boyd Welding in Ocala, FL make you some. They will build aluminum tanks to your specs/prints.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
