12-21-2021, 03:35 PM | #1 |
'67 C10 Bed Body Line Alignment
Happy Holidays!
I have a '67 that was an original step side. The PO had purchased a new fleet side bed for it. I noticed when I picked the truck up that the cab to bed body line was way off (like the bed was shimmed way up). After a couple of weeks, I just can't figure it out. The bed lays mostly on the second bed mount from the front. It does not lay on the the bed mount closes to the cab. I can shim the rear up, which lowers the front, but not enough. The cab has a new mount kit in it. Are the fleet side and step side bolt on replacements? What am I missing here? Any options other than shimming the cab up or modifying the frame bed mounts? Last edited by '67 C10; 12-23-2021 at 02:47 PM. Reason: Made the title more fitting. |
12-21-2021, 04:01 PM | #2 |
Re: '67 Fleet Side vs Step Side Bed Height
Alot of times the cab settles over the years due to rotting rubber cab mounts or mushy cab supports or a combination of both.
I believe the bed should just bolt on. I would think the brackets on the frame are the same for fleetside or stepside beds. Perhaps when the new cab supports were installed, the cab was not jacked up to account for the settling that occurs over the years which can cause the body lines to not line up. Maybe you can add some shims to the rear cab supports to help with aligning the body lines.
John 1967 C20 2WD Longbed 2001 2500 HD 4X4 Extended cab long bed |
12-21-2021, 04:04 PM | #3 | |
It's looking more and more like shimming may be the fix. |
12-21-2021, 05:08 PM | #4 |
Just a thought...Did the PO change the bed cross sills when he changed the bed? According to AMD's web site they are different.
https://www.autometaldirect.com/body...-c-23_345.html
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power |
12-21-2021, 05:22 PM | #5 | |
I'd love to hear this isn't the case. And this point, the bed sits directly on the frame mounts. Two in the front, two in the back. Only the very back one and the second from the front (on the bracket) actually touch without shims. |
12-21-2021, 09:36 PM | #6 |
The cabs are the same so the Fleetside will line up on a truck that was originally a Stepside. You have some other issue
12-21-2021, 10:16 PM | #7 | |
12-21-2021, 10:43 PM | #8 |
C10 cab mounts are different than the C20 and K10-K20. Were the right ones used? Also had bad luck with the LMC cab mounts myself and heard others have as well.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
12-22-2021, 10:42 AM | #9 | |
This is one of those frustration points that starts to raise doubts in ones mind. I know part of an "off frame" is solving issues, but it would be nice if SOMETHING just worked. The one thing that makes me feel better is the bed was like this when I purchased it. So I don't think it was anything I did. I assumed it was cab mounts. But the way it sits on the frame is just odd. |
12-22-2021, 01:38 PM | #10 | |
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power Last edited by ga-stepside; 12-22-2021 at 02:12 PM. |
12-22-2021, 04:05 PM | #11 |
How about some pictures?
1972 GMC K2500 Super Custom Matt |
12-23-2021, 11:47 AM | #12 |
12-23-2021, 02:27 PM | #13 |
Ok, pictures. Keep in mind we have the rear of the bed shimmed up enough that the front of the bed is hard against the front bed mounts. This amounts to about 3/4" in the rear. The second bed mount (from the rear) doesn't touch the frame.
A few points: The cab does have new LMC rubber (not poly) cab mounts. This is a new bed, no idea on the origin. Came with the truck. As I look back over delivery pictures, the body line was like this when I purchased the truck. Last edited by '67 C10; 12-23-2021 at 02:34 PM. |
