Old 12-28-2021, 09:03 AM   #1
Joyridin
Anybody using a 6l80 in their swap?
I want to keep the column shifter for the normal PRNDM/S. Is there a way to hook up something like a rocker switch or even a small hidden shifter when I want to manually shift the transmission in M/S mode?
Joyridin is offline   Reply With Quote
Old 12-28-2021, 12:01 PM   #2
Ziegelsteinfaust
Re: Anybody using a 6l80 in their swap?
The only thing I have seen aftermarket was a floor shifter with the tap shift feature.
Or people have fabbed in late model steering wheel assemblies to get the column shifter, and tap shift.
Ziegelsteinfaust is offline   Reply With Quote
Old 12-28-2021, 06:01 PM   #3
LS short box
You might want to check over on LS1tech. Lots of different swaps detailed over there.
Old 12-28-2021, 06:36 PM   #4
Joyridin
I have been on there. Most people just want to talk about their 4l transmissions.
Old 12-28-2021, 10:04 PM   #5
ls1nova71
ls1nova71's Avatar
This should work for what you want to do. https://www.speartech.com/product_p/tssb.htm
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 12-29-2021, 08:24 AM   #6
Joyridin
That one has to use an E38 ECM. I have an E93 if I recall, which is the Gen 5 version.
I did find a couple others though, so I think I am good. Thanks!
Old 12-29-2021, 10:46 AM   #7
6600DURAMAX
6600DURAMAX's Avatar
Mind sharing what you have found - I'm using a 6L80e as well just havent gotten that far... hahah
What did you do for your linkage?
thanks
1972 K5 Build - plans - LS3-6L80e-One Tons.....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 12-29-2021, 06:24 PM   #8
Joyridin
thanks
I was probably going to use the Lokar kit, but I haven't gotten that far either. I need to get a new column first, then I can go from there.
Old 12-30-2021, 12:18 AM   #9
bigmoe
bigmoe's Avatar
I always thought it would be cool to have a rocker switch on the console assuming a guy has buckets.
bigmoe is offline   Reply With Quote
Old 12-30-2021, 04:33 AM   #10
Richard
PSI sells a wireless paddle shifter setup that gets power from the horn wire in the wheel. In my conversations with them they told me it works with the e67 ecm I am using (my engine harness is from PSI). Thinking about giving it a try for the 6L90 in my truck. Looks like for aftermarket wheels only. With a stock steering wheel would require a lot of modification, if it is even possible.
Richard
Old 12-30-2021, 08:06 AM   #11
bigmoe
bigmoe's Avatar
You would think that you would just have to find the three wires in the harness and run them to a rocker switch. Do you have a pin readout for the E93?
Old 12-30-2021, 08:18 AM   #12
ls1nova71
ls1nova71's Avatar
The wires for the tap up/tap down go to the BCM, so not as easy as hooking them up to the ECM.
Old 12-30-2021, 09:23 AM   #13
Joyridin
It looks like Swaptimeusa has a kit that will work and uses a rocker switch. Supposedly, you don't even need to reprogram the transmission, although that is probably not a bad idea if you are doing any modifications. Their set-up works with any ECM. Most of them seem to work with the E38.
I have some time on this yet, but it looks definitely doable!
Old 01-03-2022, 11:44 AM   #14
6600DURAMAX
I'm running a PSI harness on my LS3 conversion as well, might reach out to PSI and see how much to add this harness on? Mine is a 58X harness if that makes a difference.
Old 01-05-2022, 09:14 PM   #15
pcmcobra
pcmcobra's Avatar
I have the swaptime module, let you know how it goes.
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 01-06-2022, 08:37 AM   #16
Joyridin
That would be great! Thanks!
Old 11-28-2022, 06:34 PM   #17
6600DURAMAX
Any update on this ?
thanks
Old 11-29-2022, 08:38 AM   #18
Joyridin
I am installing it this winter, so I will know if the unit works in the spring. The one from Swaptime is no longer available. He claims he could not get the chip needed to build the units any longer. Is there a chip inside?
There are a few other companies that make the unit. I am trying one of those.
Old 12-04-2022, 03:46 AM   #19
Richard
Ended up purchasing the paddle shifter from PSI https://www.psiconversion.com/produc.../TAP-1000.html The paddle module is installed at steering wheel but I still have a lot to do. Have spoke to them a couple of times and the engineer there insists it will work in my application. Connects to trans by only one wire and requires changes to ECM. Hope to check out operation in a month or two.
Richard
Old 12-04-2022, 08:18 AM   #20
jjzepplin
jjzepplin's Avatar
Following along.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 12-04-2022, 10:10 AM   #21
Joyridin
I am not sure what they mean by changes to ECM, but I was told by 2 places that it is not a wise idea to reprogram the ECM to a Corvette O/S if that is what they require. Speartech requires this for their set-up and you run a 50% chance of bricking the ECM.
I have no idea if it is accurate, but it does make sense. Good luck!
Old 12-04-2022, 12:00 PM   #22
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Im not done with the swap, but HPtuners reads tap up and tap down correctly when in scanning mode. I usedthe Corvette wiring diagram, 3 resistors per that diagram and wired just like the diagram.
If you don't run the BCM, you have to change the settings in the tune for this to work.
https://www.youtube.com/watch?v=34u5nH06x6Y
hptuners link in site requires forum access, if you dont have it,
uploaded it to my site since there is a limit on upload to here
http://87chevy.com/share/6speed%20Ta...uck%20Tune.doc
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 12-04-2022, 01:08 PM   #23
Joyridin
clint
I looked on HPTuners forum, but I do not recall seeing that write-up. Thanks!
Old 12-04-2022, 10:00 PM   #24
Richard
clint
Thanks for this. Helps clarify the instructions and information I was told. I should have said changes need to made to the TCM tune parameters.
@joyridin Should be able to avoid any complete reflashing. The main reason I got the engine, trans and ecm all from the same ZL1 Camaro. The TCM located in the 6L trans needs to be flashed if not matched to the ecm.
Richard
Old 12-05-2022, 01:15 PM   #25
Joyridin
Any 6l that came in a car should be set up for manual shifting already. Truck 6L transmissions were not set-up that way and use a different O/S on the trans from what i understand.
