Old 12-27-2021, 07:49 AM   #401
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: '72 Cheyenne K10
At least you had a rack for the conoe...lol. How did you do on gas?
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 12-27-2021, 10:54 AM   #402
jimbosprint
jimbosprint's Avatar
About 10mpg
jimbosprint is offline   Reply With Quote
Old 12-27-2021, 12:34 PM   #403
Ol Blue K20
Originally Posted by jimbosprint View Post
About 10mpg
Not bad mileage, Blue runs about the same.
Dale
Old 12-31-2021, 12:01 AM   #404
jimbosprint
After my trip I noticed the coolant leak around the thermostat housing has gotten worse. It has been on my to-do list for a while, and it made me think it's time to check a few more things off. Here's what's coming up:
- New thermostat housing and radiator hoses
- Rebuild and swap in the extra steering column I have
- Get horn working
- Replace wiper motor, washer pump hoses, and switch
- Upgrade to hydroboost brake booster
- Rebuild rear driveline
- Clean out cowl and install debris screen
Old 12-31-2021, 12:23 PM   #405
Ol Blue K20
Sounds like you're gonna be busy.
Dale
Old 01-01-2022, 10:27 PM   #406
jimbosprint
No turning back now (no turning at all now). Today I removed the vacuum brake booster and the steering column. I also replaced the thermostat housing.
Old 01-02-2022, 07:59 AM   #407
Ol Blue K20
Yeah, I'd say you're pretty much committed now. I hope the hydroboost goes easy. Are you going tilt wheel on the column?
Dale
Old 01-02-2022, 03:51 PM   #408
jimbosprint
No tilt. I picked up a cheap used column that was the same color a while back. I took it apart the other day and ordered parts to rebuild it. About $150 total cost for parts (horn parts, signal parts, bearings, shift indicator and optic cable).
Old 01-02-2022, 05:21 PM   #409
Jiggers72-GMC
Jiggers72-GMC's Avatar
Great build and info here Jim, I missed the reason you went to a twin shifter setup on the TC, your truck is a lot like my 71, tia
Gerry, North Bay Ontario
1971 Chevy K10 short stepper, 518 med green & white
1972 GMC C1500 long box, dark Brown, owned since 1977
1969 GMC C2500 manual
Jiggers72-GMC is offline   Reply With Quote
Old 01-02-2022, 09:49 PM   #410
jimbosprint
Thanks. The twin shifter has easier shifting and it gives you RWD high/low, FWD high/low, and 4WD high/low.
Old 01-02-2022, 10:38 PM   #411
Jiggers72-GMC
Thanks Jim, that's very interesting, great build man.
Old 01-04-2022, 05:38 PM   #412
jimbosprint
The Hydroboost bracket from CaptainFab showed up yesterday so I worked on fitting everything to the truck today. The bracket interferes with the steering column firewall bracket a bit so both parts needed grinding. The knurl on the Hydroboost studs did not quite fit through the holes in the new bracket so I drilled those holes out to 1/2". And the studs were about a half inch too long so I cut them down.
Old 01-04-2022, 05:41 PM   #413
jimbosprint
I am still not sure how I am going to fabricate the brake pedal linkage. Having the steering out is sure a big help though.
Old 01-09-2022, 03:49 AM   #414
jimbosprint
I pulled the rear driveline out and took it up to High Angle Driveline in Paradise. He told me to change the u-joints and grease the slip joint. I have a lot of respect for a business that will turn away a customer and not charge for unnecessary work.
Old 01-09-2022, 07:32 AM   #415
Ol Blue K20
That should smooth out some vibration..Nice shop to give advise.
Dale
Old 01-11-2022, 07:20 PM   #416
jimbosprint
LMC order showed up, so I got my steering column all put back together.
Old 01-12-2022, 09:35 AM   #417
Ol Blue K20
Nice!
Dale
Old 01-12-2022, 07:07 PM   #418
jimbosprint
Got some more done today:
- Reinstalled rear driveshaft
- Cleaned leaves and dirt out of the cowl
- Replaced burnt windshield washer hoses
- Replaced windshield wiper switch (much improved!)
- Tested windshield washer pump (no good)
- Worked on Hydroboost brake pedal linkage
Old 01-14-2022, 09:32 PM   #419
jimbosprint
I think I have almost everything I need to finish up the Hydroboost. My friend that works at a local hydraulic shop made pressure lines for me, and I have a piece of return line that will work. I just need to get a "T" for the return line.
I also had my custom brake pedal adapter welded today and gave it a quick sandblast and paint. It bolts on so any future booster r&r won't require fabrication. (I made a few extra )
Old 01-14-2022, 11:04 PM   #420
MikeandCheryl
Amazing truck - it looks good as it is. I like what you've done...
We have a 72 K 4sp and will watch what you do. i'll start a build post one of these days. Curious of the lift removal (i will have mine stock), so wondering about tire size (thinking 31 x 10.5) with stock leaves at both ends. Curious about the internal gas tank and it's future. also, wondering how deep into the bones of the truck to go. I can remove the cab, take all the suspension off, the engine/tranny/diffs... and end up with a bare frame to start upwards. how necessary is this? Also, are you rebuilding diffs, t-case, tranny, or hoping 50 years of age still holds true? Trying not to make a 5 year project, but wanting a solid runner. I see function before fashion. Maybe you too.
MikeandCheryl is offline   Reply With Quote
Old 01-15-2022, 12:03 AM   #421
MikeandCheryl
whoa. Nice to see but didn't see that there are 17 pages of updates. I'm so behind now...But like the color, eh?
Old 01-15-2022, 03:46 AM   #422
jimbosprint
Smile Re: '72 Cheyenne K10
Thanks MikeandCheryl. 31x10.5 tires will fit these trucks with stock springs. There's a thread on here somewhere about what tire sizes fit what lifts. Replacing the gas tank in the cab is relatively easy and inexpensive. Clean fuel is a great place to start working on the engine. How far you go really depends on your goals and what you start with.
Yes, this thread is a very long read. I started with a truck that needed everything fixed after a decade of sitting. Ochre is definitely my favorite paint color, it suits the era so well.
I will watch for your build! Cheers!
Old 01-15-2022, 09:37 AM   #423
Ol Blue K20
Attachment 2158603
Attachment 2158604
Attachment 2158605
Adapter looks good! Good idea making extras, someone else might want to try this..
Dale
Old 01-16-2022, 05:44 PM   #424
jimbosprint
More progress today putting together the Hydroboost system. Sort of a pain to take the inner fender off, but I had to trim it back where the pressure line goes into the steering gearbox. Bonus - it will make installing the steering column easier.
Old 01-16-2022, 06:46 PM   #425
Ol Blue K20
It looks like it belongs there. Nice!
Dale
ochre
