Old 12-25-2021, 07:36 PM   #351
Jason 56
Re: My 56 build
Merry Christmas everyone. Been working on the heat/AC install. Trying to mount it so it can be removed after I fill in the dash. After much thought I decided to use a post and grommet on the dash side. So a cleat on the top of the firewall and 2 studs welded on the bottom.
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build
Jason 56 is offline   Reply With Quote
Old 12-25-2021, 07:48 PM   #352
Jason 56
Re: My 56 build
Also finished beating the crap out of the dash panels. They’re held up with clecos now so I can work on the center counsel. That’s why there’s a gap between them. We’ll see how that turns out
Old 12-28-2021, 10:53 PM   #353
Jason 56
Re: My 56 build
Little more progress today. The bracket on the dash side of the air box isn’t going to work. So I’m just going to use the rear bracket. Just no room! I’m trying to build it so I can remove it in the future if needed. I managed to get the heater/AC control mounted. My angle iron had to be notched for that. Also have the steering column figured out and had to rebuild the dash side of my pedal box. Here’s a couple pictures.
Old 12-28-2021, 10:55 PM   #354
dsraven
Re: My 56 build
Tilt column?
Old 12-29-2021, 12:02 AM   #355
Jason 56
Re: My 56 build
Originally Posted by dsraven View Post
Tilt column?
Yes
Old 12-30-2021, 12:01 PM   #356
dsraven
Re: My 56 build
Gotta love the cleco fasteners, I have a bunch, mostly 1/8, different sizes and a few of the clamps as well. I generally work alone so the help from a cleco, a c clamp vice grip, a strong magnet or even some sheet metal screws is nice.
Youre doing some great work and progress. Keep the pics and dialogue coming as you go forward.
Old 12-30-2021, 12:05 PM   #357
dsraven
Re: My 56 build
Those el cheapo deluxe sheet metal clamps also work great for jobs where you can access the back side and the areas are flat. You know the ones with the little square bar on the backside? Harbor freight sells them as well as other places.
Old 12-31-2021, 12:06 AM   #358
Jason 56
Re: My 56 build
Thanks DS, here’s a picture of the butt welding clamps you’re talking about for anyone interested. I got mine from Amazon. They can be a bit of a pain to use but do a nice job. Clecos are nice, but I prefer to butt weld exterior panels to avoid rust in the overlap area. Not a concern in the interior… hopefully unless I drive into a lake
Old 12-31-2021, 01:26 AM   #359
dsraven
Re: My 56 build
That's the ones.
I'm a butt welder too.
That came out wrong, didnt it. Haha.
Old 12-31-2021, 02:22 AM   #360
dsraven
Re: My 56 build
You can use clecos for butt welding too. They are a bit of a pain as well.where the 2 parts butt together make a 1/2 hole on the edge of each part so when they fit together you have a full hole the size needed for the cleco. Use a small washer on the backside for the cleco to bite on. Magnets work well to keep the panels where you need them while you get the cleco set up.
Old 12-31-2021, 10:44 AM   #361
my56chevytruck
my56chevytruck's Avatar
Re: My 56 build
Good job Jason, your work is spot on. Keep us all posted.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 12-31-2021, 11:01 AM   #362
mrbuck
Re: My 56 build
:Lovin’ the extended dash
Bucks build thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=825476
mrbuck is offline   Reply With Quote
Old 12-31-2021, 07:37 PM   #363
57FleetsideC4
Re: My 56 build
Great work. Coming along nice. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054
57FleetsideC4 is offline   Reply With Quote
Old 01-02-2022, 12:16 AM   #364
Jason 56
Re: My 56 build
Center console is nearly done. Took about 8 hours of beating on it, but it turned out pretty good. I plan on finishing the lower part with plywood covered with whatever material I use on the seats/door panels.
Old 01-02-2022, 12:20 AM   #365
Jason 56
Re: My 56 build
Here’s a before and after.
Old 01-02-2022, 02:22 AM   #366
dsraven
Re: My 56 build
Do you plan to attach it so that it is removable?
Old 01-02-2022, 10:28 AM   #367
Jason 56
Re: My 56 build
Not sure yet. That’s a good idea! Today’s project is to see if I can get the heat/AC box out. We’ll see
Old 01-04-2022, 11:55 AM   #368
6DoF
6DoF's Avatar
Re: My 56 build
props on the sheet metal work! Interesting design i can't wait to see done.
6DoF is offline   Reply With Quote
Old 01-04-2022, 11:56 AM   #369
slammed57
slammed57's Avatar
Re: My 56 build
lookin good jason, do a test run for the A/C unit to slide up in there before you weld'er up.
My 57 current build
http://67-72chevytrucks.com/vboard/s...d.php?t=662590
slammed57 is offline   Reply With Quote
Old 01-05-2022, 12:44 AM   #370
Jason 56
Re: My 56 build
Thanks 6DoF. I’m hoping it turns out well. So far so good. I know you mentioned you don’t care for sheet metal work on your build thread. I enjoy the metal work, but don’t care for the body filler/sanding part
Definitely a good call. I’ve had it in and out many times so far. Think it will come out. When I’m ready to weld I plan on tacking everything in a few places… remove all the clamps and see if it still comes out. It’s tight, but I think I can get it out.
Old 01-05-2022, 12:52 AM   #371
Jason 56
Re: My 56 build
Few pictures of today’s progress. I finally got my last 90* heater core hose. I installed my crossover and the valve under the dash right next to the core. Heater lines are all done now!
Old 01-05-2022, 01:02 AM   #372
Jason 56
Re: My 56 build
Also modified the air duct box for the 2 round vents I’m putting in the center console. I finished the corners and mounted the vents. Next is the cup holders which will be to the right of the shifter.
Old 01-05-2022, 10:35 PM   #373
duramax55
Re: My 56 build
looking good jason nice job
duramax55 is offline   Reply With Quote
Old 01-07-2022, 02:25 PM   #374
Jason 56
Re: My 56 build
Old 01-07-2022, 09:20 PM   #375
G&R's57GMC
G&R's57GMC's Avatar
Re: My 56 build
You would be happier with the vents at the highest point on the dash and at the ends of the dashboard also .
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
