Old 01-08-2022, 10:36 AM   #51
57FleetsideC4
Re: Someone else's truck. '48 Chev
Coming along very nice!! Sorry about the tube nut but stuff happens. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054
57FleetsideC4 is offline   Reply With Quote
Old 01-10-2022, 10:13 AM   #52
lower50's
lower50's's Avatar
Originally Posted by Dieselwrencher View Post
Very nice work! I've bit myself on the tube nut before too.
Originally Posted by oldman3 View Post
Nice...Jim
Thanks guys!!
Ya I think no matter how many tubes you flair you will still forget the nut sometimes lol
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 01-10-2022, 10:19 AM   #53
lower50's
lower50's's Avatar
Well over the weekend I figured out where and how to mount up the peddles. Turned out really nice, I will defiantly use the this kit again. I also got the mustang steering column installed. Now to take apart weld and paint.
1951 MG TD
Old 01-10-2022, 10:39 AM   #54
6DoF
6DoF's Avatar
you are cookin sir, they are guna love it.
6DoF is offline   Reply With Quote
Old 01-10-2022, 01:05 PM   #55
layinrocker65
layinrocker65's Avatar
Pedals look fancy. Who makes them?
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 01-11-2022, 10:47 AM   #56
lower50's
lower50's's Avatar
Thank you, I'm trying.
Walton Fabrication.
1951 MG TD
Old 01-13-2022, 06:21 AM   #57
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Those pedals look really nice!
Ryan
1969 Chevy milk truck
Old 01-18-2022, 12:55 AM   #58
lower50's
lower50's's Avatar
Well the peddles are painted and installed, made some foot pads that thread on. Gas peddle is hooked up. You can also see how I mounted the M_stang steering column, when the steering shaft finally shows up yesterday!? it will go above the headers to the s10 box. The cooling fan/shroud are mounted it's a Derale 2400 cfm unit and today I got the AC condenser/dryer sitting in place.
1951 MG TD
Old 01-18-2022, 09:00 AM   #59
8man
Very clean looking, and I still like that radiator/fan/shroud a lot.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 01-18-2022, 11:02 AM   #60
oldman3
oldman3's Avatar
Everything looking great...Jim
oldman3 is offline   Reply With Quote
Old 01-18-2022, 01:09 PM   #61
youngrodder
youngrodder's Avatar
It all looks really well build. Nicely done.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 01-19-2022, 01:20 AM   #62
lower50's
lower50's's Avatar
Thanks I too really like how rad/fan/shroud all fit together.
Thanks Jim
Marc
Thank you Marc It all seems to be coming together nice.
1951 MG TD
Old 01-28-2022, 06:44 PM   #63
lower50's
lower50's's Avatar
I installed the under dash ac/heater vents and got the under dash ac system mounted. Wiring has started now that all the hard parts are in place I had to move the fuse panel a bit from where the kit wanted it to clear the clutch pedal. Also got the heater core plumbed in.
1951 MG TD
Old 01-28-2022, 06:51 PM   #64
8man
Nice work. We are in about the same spot putting the trucks together.
8man-aka Robert
Old 01-28-2022, 06:52 PM   #65
lower50's
lower50's's Avatar
Probably the most complicated rad support, but it works good. Here is how the steering shaft worked out using the M_$tang column.
1951 MG TD
Old 01-28-2022, 09:31 PM   #66
oldman3
oldman3's Avatar
Looking good there Bob...Jim
Old 01-29-2022, 09:51 AM   #67
Father&son56project
That steering column turned out very well. It looks a lot nicer than having an S10 unit in the cab (I know, cuz I have one and it is seriously ugly!). A few quick questions:
-What year Mustang is the column out of?
-What firewall pass-thru did you use for it?
Father&son56project is offline   Reply With Quote
Old 01-31-2022, 12:17 PM   #68
6DoF
6DoF's Avatar
something seams fishy ... this is going together a little too well ...
Old 02-02-2022, 09:14 AM   #69
lower50's
lower50's's Avatar
Thank you
Ya I have used 80's gm column's in my last 2 trucks might have to switch over.
I have no idea what year column it is came with the truck. Fire wall pass through is just a rubber grommet, if I find it flexes whenever I get the tires I was going to use a 1" pillow block bolted to the fire wall. But tight so far.
Ya I'm wondering the same
1951 MG TD
Old 02-09-2022, 12:23 AM   #70
lower50's
lower50's's Avatar
Fender and box modification has started. The owner did not want as fat of a rear fender. I'm cutting the fender width down 3", then making my own mounting flange and making the box 6" wider. It's all just mocked up for now till the tires show up then I will fine tune the box width.
1951 MG TD
Old 02-09-2022, 12:28 AM   #71
lower50's
lower50's's Avatar
Also been working on more wiring, but I did get the block that bolts to the back of the ac compressor. So then I got the hoses trimmed up ready for crimping.
If anyone is looking for a cheap driveshaft, this one you can buy pre made (Amazon)
1951 MG TD
Old 02-09-2022, 09:59 AM   #72
Tempest67
Tempest67's Avatar
hmmmmm... widen the box , that is an interesting mod. that I have not seen before. I enjoy seeing the ideas that you all have.
I look forward to seeing this when done,
Thanks for the pics, and the workmanship looks 'top shelf'
Tempest67 is offline   Reply With Quote
Old 02-09-2022, 12:28 PM   #73
6DoF
6DoF's Avatar
NICE!! someone else to share ideas with! i've intended to leave the rear fenders as-is and widen the bed until they cover the dual's.
are you making a header plate, gap filler, or going to seam 2 together? tailgate?
i've been planning at this point to buy 2 headers and 2 tailgates, none with logo, to cut and seam together.
Old 02-15-2022, 09:52 PM   #74
lower50's
lower50's's Avatar
I have not seen it either so this will be interesting how it looks after. Thank you I try.
Anytime sir. Well you might have to wait I have some ideas in the works, coming soon.
1951 MG TD
Old 02-16-2022, 07:59 AM   #75
Dieselwrencher
Very nice work. I was involved with making a bed wider on a 53 1.5 ton bed many years ago. It was more work than the owner thought but it fit that truck a lot better IMO.
Ryan
