01-19-2022, 11:38 AM | #2051 | ||
Re: My 50 roadster pickup build
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
01-25-2022, 10:49 AM | #2052 |
Update on power steering. I talked with Borgeson about the flow valve I had and number of shims needed. Didn't know anything about the flow valve, but suggested to remove it, install stock fitting and 4 shims. So that's what we did. Hard to see it pic, but the flow valves hole is about half the size of stock one...Jim
01-25-2022, 10:59 AM | #2053 |
After changing everything out, I took it for a drive, like the feel better that before. I the way back to the house, I heard the squealing from the engine. Mark and I checked it out, thought it was the belt, but after further checking it was the water pump. New pump, but something went wrong. So tear apart the front, remove radiator, etc. It's 95 percent back together now, will finish up the morning, and will let you know.
Pic 1 old pump removed Pic 2 new pump all painted and ready to install. Pic 3 and 4 not good pic, but back together, ready to put on cover and fill up the radiator. stay tuned...Jim
01-25-2022, 11:06 AM | #2054 |
Glad you got the power steering on the right track!
Bummer about the new water pump though.
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
01-25-2022, 12:18 PM | #2055 |
Glad the power steering pressure reducer worked to your liking. Now that you mention it I think I used 4 as well. I just followed the directions. Seems like I had one shim left in the bag.
Good to find a failing water pump on your terms. Nice catch. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
01-25-2022, 04:00 PM | #2056 |
seems like its always something, glad you got it figured out though!
01-25-2022, 04:27 PM | #2057 |
Hope you slayed the last gremlin and can now drive and enjoy!
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
01-25-2022, 08:41 PM | #2058 | |||
01-25-2022, 08:46 PM | #2059 |
Update from yesterday. Got everything buttoned up, anti-freeze in radiator. No squeal from engine area. Took it down the road for about 5 miles. Steering is tighter that before, but not as much with the old system. Maybe 5 shims would have worked, but not going to change. Plans are tomorrow for me to take it on about a 50 to 60 mile jog, and see how it runs. Still need to get Brendon to hook up lap-top and fine tune things. Will let you know tomorrow...Jim
01-26-2022, 08:51 AM | #2060 |
Try your best to not to pull a muscle around your jaw from smiling all day! Have Fun Jim and good luck on your shake down cruise.
01-26-2022, 10:31 AM | #2061 |
Great off season upgrades Jim.....Now the fun part......Driving it.
Marc
01-26-2022, 10:59 AM | #2062 | |
01-27-2022, 06:40 PM | #2063 |
Where do I start, if it wasn't for bad luck I wouldn't have any luck
Ok Wednesday 1/26 started to take my shake-down run. Went about 20 miles or so, heard a noise and noticed my volt gauge was dropping down, lower and lower, turned around and headed home. Needless to say with low voltage, thinks started going wrong, temp went up (no fan), etc. Was about 4 miles from home. Called Mark, he came with jumper cables, let engine cool down, then made a mad dash to the house. Pull radiator, etc apart again. Removed thermostat, and alternator. Went to parts store, alternator bad, only had about 80 miles on it, didn't want to chance the thermostat going bad with hight temps around 240. Bought a new alternator $$ and thermostat. Came back and got alternator ready for paint, installed thermostat, etc. Today Thursday 1/27 Mark reinstalled everything, along with new anti-freeze, etc. Took a short drive and everything seemed good. After lunch I took off again, this time everything went good, about a 90 mile round trip. Next week Brendon will hook-up laptop and find tune everything. Here's a few pics. Pic 1. This was Wednesday running along about 70 mph everything good Pic 2. Looking down the road. Pic 3. Torn apart again. Pic 4. New alternator painted No pics today, forgot the camera. A big THANK YOU to my son Mark for all his hard work..Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> Last edited by oldman3; 01-27-2022 at 06:57 PM. |
01-27-2022, 07:39 PM | #2064 |
OH no. It never fails though the one part you should not have a problem with. At least you did get home without a tow, and everything else is working great.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
01-28-2022, 12:29 AM | #2065 |
Hey Bob, what makes me mad, is all the parts are new, from good sources, I guess someone has to get the bad ones...Jim
01-28-2022, 01:35 AM | #2066 |
Had to catch up on your project ..hopefully you got the bugs worked out..
01-28-2022, 10:10 AM | #2067 |
it is very frustrating when new parts are faulty.
Glad to hear 'Icon' is back on the road and doing well. enjoy. No test drives up here til' April
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
01-28-2022, 10:17 AM | #2068 |
I hope all the bugs are gone and that you get to drive the tires off of it.
Also, please tell me what brand washer that is that doubles as a paint booth.
01-28-2022, 10:22 AM | #2069 |
Isn't hot rodding fun??? You guys are probably getting as efficient as a NASCAR pit crew disassembling that front end.
Enjoy test drive #3....You'll get it Marc
01-28-2022, 10:46 AM | #2070 |
i had actually never gone back thru the whole build on this truck, holy balls! i'm guna have to take more time to go page by page at some point.
01-28-2022, 11:56 AM | #2071 | ||||
Thank you, yes it's been through several upgrades over the years...Jim
01-28-2022, 12:20 PM | #2072 |
wow thats a hard luck story if i heard one. glad its all fixed, I gotta tell ya I laughed at the alternator on the washer picture, one of the work at home things that I appreciate seeing!
i bet all the people you passed on your 90 mile trip were wondering who the nut with the convertible in january was.
01-28-2022, 09:28 PM | #2073 | |
01-29-2022, 09:37 AM | #2074 |
Congrats on finishing the swap. It’s amazing the gremlins you find when doing something like this. No question that the aftermarket parts available today don’t live up to a high standard. Enjoy cruising with the modern engine!
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build |
01-29-2022, 11:44 AM | #2075 |
Thank you...Jim
