01-30-2022, 07:06 AM | #51 |
Proprietor of Dale's Corner
Re: LockDoc's "Low Budget", "Low Maintenance" Project Thread
I like it....a lot!
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
01-30-2022, 08:32 AM | #52 |
Looking good Doc!
01-31-2022, 11:12 AM | #53 |
The Older Generation
Thanks guys.
It's a nice day today but it will start getting colder soon. I am working on this outside so things may slow down unless I can figure out a place to store the '34 Ford Coupe so I can get it in the shop. I have been working on doing that for the last couple of months.... I think I am gaining on it though. LockDoc
01-31-2022, 09:44 PM | #54 |
I made enough room in the big building to put the '34 Coupe in there so hopefully it won't be long until I have the Dually in the shop. I need to do just a little more cleaning first. I am such a "slopo" I also need to put the steering cloumn in the truck to make it easier to move. LockDoc
01-31-2022, 11:54 PM | #55 |
I really like the Mud Flaps
02-01-2022, 01:10 PM | #56 |
Only problem is they aren't wide enough now.... LockDoc
02-01-2022, 01:15 PM | #57 |
OK, truck is in the shop. It's a tight fit but I should have enough room to get a bunch of stuff done on it. I started stripping out the wire loom on the engine today. I will be removing quite a few wires from it. I will be jumping back and forth on different things depending in how much time I have each day. LockDoc
02-02-2022, 02:16 PM | #58 |
I had a little time to kill so I decided to get started on setting up the ECM using my HP Tuners software this morning. I got it all connected and the laptop fired up. I built a wire loom so I could do all of the ECM programming stuff on the dining room table. It makes it a lot more enjoyable to be able to sit down in comfort...... I got the original tune scanned and backed up to my hard drive, now I can go in and remove the VATS, EGR, rear 02 sensors, A/C, and 4x4 stuff. There are a few other things but I will have to look at my cheat sheet and double check. It has been quite a while since I did my '67 Panel Truck. In the picture, the large grey box in the back is the regulated 12v power supply. There is a separate rocker switch that turns on the power to the ECM. The large silver box is the ECM (Truck Computer), and on top of it is the Diagnostic connector from under the dash of the donor truck. It has the cable from the HP Tuners interface box plugged into it. The small grey/black box is the HP Tuner interface that connects the ECM to the PC. The PC will read the "tune" in the ECM, then you can make changes to it and write the modified "Tune" back to the ECM computer. The only thing you really have to remove to make the engine run is the VATS (key resistor chip) information that would keep the engine from starting. I'm sure some of this stuff will be pretty boring to some but I want to document it for future reference. LockDoc -
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 02-26-2023 at 11:00 PM. |
02-03-2022, 06:57 AM | #59 |
6>8 Plugless........
Leon, do you have the pro version of HPtuners, or just the entry level version?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
02-03-2022, 07:29 PM | #60 |
I am looking at installing a LS motor in my truck. I am only in the cost feasibility stage. Can you help others with your knowledge? Maybe charge us for your computer time?
02-04-2022, 01:07 AM | #61 | ||
LockDoc
02-04-2022, 06:38 AM | #62 | |
02-04-2022, 10:54 AM | #63 | |
Last edited by LockDoc; 02-04-2022 at 02:02 PM. Reason: Corrected the spelling in my quote |
02-04-2022, 12:01 PM | #64 |
Just stumbled onto this one and am so glad I did. The photo with the cab and bed on made me smile from ear to ear. Cannot say how much I like that.
I'm in to see how this comes out.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
02-04-2022, 01:02 PM | #65 |
low n' slo
man this looks like a fun build.
are you going to leave the rear bed like that...or add dually fenders?
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
02-04-2022, 01:24 PM | #66 | |
Very cool that you've been able to get that set up and have that knowledge. I would like to be able to get to that point eventually. |
02-04-2022, 02:19 PM | #67 | ||||
If an old school-old fart like me can figure it out anyone can. It just involves a lot of reading. All of the information is on here and numerous other sites on the net. Thanks guys. LockDoc
02-06-2022, 09:30 PM | #68 |
Currently Blazerless
Cool.project Leon, looks like your.making really good progress on it. As for your rear wheel openings keep your eye out for a set of 76-86 JEEP CJ-5, CJ-7 factory rear wheel flares. They fit our wheel arches almost perfectly. They don't cover the entire wheel openings but.most of it. You should be able to find a set cheap and they're molded and look much better than the cut to fit ones.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C Last edited by LockDoc; 03-04-2022 at 02:39 PM. |
02-06-2022, 09:35 PM | #69 |
Here's a Longhorn dually I saw on a FB group the other day.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
02-06-2022, 09:42 PM | #70 |
Looks like a fun build Leon!
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
02-06-2022, 09:45 PM | #71 |
Looking great
02-06-2022, 09:57 PM | #72 | |
I was going to do a Longhorn based on a '67-'68 and I pretty much had everything to make it happen except the cab and frame weren't in very good shape. I sure like them. LockDoc
02-06-2022, 10:00 PM | #73 |
Thanks guys. It's been fun so far. I'm looking forward to more progress in the coming weeks. LockDoc
02-06-2022, 11:03 PM | #74 |
Leon, I vote “ no” on the flares. The look you have now, is better and likely uncommon....
02-07-2022, 10:46 AM | #75 |
low n' slo
ya I'd have to see the flares I think. I like that look the way it is. there might be laws though in your state since they poke past the wheel well
