Old 02-04-2022, 02:34 AM   #51
tucktuck
tucktuck's Avatar
Re: My 72 Build
Well, the wife is out of town this week so I decided to tinker on the truck. That and the fact that we've gotten about 6" of snow here in Texas...
I started out by shimming down the pinion angle on the rear end.
tucktuck is offline   Reply With Quote
Old 02-04-2022, 02:37 AM   #52
tucktuck
tucktuck's Avatar
Re: My 72 Build
Picked up my drive shaft last week, so threw it on. Its got a couple degrees difference, but may be too straight with those shims. Have to wait and see once the body and everything else is on.
Old 02-04-2022, 02:40 AM   #53
tucktuck
tucktuck's Avatar
Re: My 72 Build
I swapped my thermostat neck out for the adjustable one, still waiting on my radiator to arrive...
Old 02-04-2022, 02:42 AM   #54
tucktuck
tucktuck's Avatar
Re: My 72 Build
Went ahead and pulled my drivers side header off and trim up the tabs on the Bellhousing. Painted, then reinstalled the header.
Old 02-04-2022, 02:44 AM   #55
tucktuck
tucktuck's Avatar
Re: My 72 Build
The plug wires were a little close to the headers so I threw on some heat shielding that I ordered.
Old 02-04-2022, 02:47 AM   #56
tucktuck
tucktuck's Avatar
Re: My 72 Build
Next up was tackling the rear brake lines. Not the prettiest, but they'll work. Waiting on some tabs I ordered to get here to button it all up.
Old 02-04-2022, 02:55 AM   #57
tucktuck
tucktuck's Avatar
Re: My 72 Build
Installed my fuel lines and fuel filter. Again, waiting on fittings that I got shorted out of my kit...
Plan is to get everything under the bed finished up, so that I can install the bed floor to fab in my filler neck, then put the bed parts together, measure my backspacing to order wheels, pull the bed back off, seam seal, and rhino line inside the bed as well as the bottom side.
I'll take my cab and doors to get blasted soon, replace whatever metal is bad, smooth my firewall and fill holes, route my wiring and AC lines, then send it out for body work and paint.
Old 02-04-2022, 01:19 PM   #58
LT7A
Re: My 72 Build
That's going to be a cool truck. If you continue with the level of detail throughout, you'll be able to drive that thing anywhere and enjoy the heck out of the trip. Just curious, did you check the measurements on the shortened frame? In your pictures at the beginning, it looks as if the bed sits really close to the cab.
Old 02-04-2022, 01:38 PM   #59
tucktuck
tucktuck's Avatar
Re: My 72 Build
Thank you sir.
When whoever cut the bed down originally put it back on, they didn't adjust anything, but yes I did measure when I first got it.
Old 02-06-2022, 01:15 PM   #60
tucktuck
tucktuck's Avatar
Re: My 72 Build
Well the plan was to throw the bed floor on and cut my filler neck hole before assembling the rest of the bed, but that did happen.
The bed floor needs to move towards the passenger side an 1/8th inch to be centered. Every other measurement was perfect. So, I have to throw the bedsides on and cab on to make sure the body lines match up, then get the bed centered with the cab, then mark and drill my filler neck.
This floor was also supposed to be for the wide tubs, but its not, so I'll have to cut a few inches out on each side as well.
Fitment of these bed sides are horrible.
Old 02-06-2022, 01:18 PM   #61
tucktuck
tucktuck's Avatar
Re: My 72 Build
I'll have to adjust my axle as well to get it centered. It's not a huge deal, just going to be a pain since its all under tension now.
Old 02-06-2022, 01:20 PM   #62
tucktuck
tucktuck's Avatar
Re: My 72 Build
Went ahead an cut the tunnel out for the high hump so I can't get the cab back on and clear the trans.
Have to clean up my cut a little more and bolt it in.
Old 02-06-2022, 01:25 PM   #63
mr.mud1
mr.mud1's Avatar
Re: My 72 Build
looking good,marvelous progress.great work.
mr.mud1 is offline   Reply With Quote
Old 02-06-2022, 03:41 PM   #64
CG
BlahBlahBlah
Re: My 72 Build
I dont typically care for modern aftermarket pulley set ups. I really like yours though, its not in your face, and pretty compact.
Old 02-07-2022, 07:20 PM   #65
tucktuck
tucktuck's Avatar
Re: My 72 Build
Thank you sir!
Old 02-07-2022, 07:21 PM   #66
tucktuck
tucktuck's Avatar
Re: My 72 Build
Yeah thats why I opted for the mid mount. I didn't want it to stand out once the hood was popped.
Old 02-07-2022, 10:10 PM   #67
JUN1269
Re: My 72 Build
Looking good sir...you motivated me to start back on my project.
Freddie...
1969 Chevy C20 – Twin turbo Gen III 5.3 Restomod in progress http://67-72chevytrucks.com/vboard/s...d.php?t=793149
2006 Chrysler 300 SRT8 – Supercharged, Bored and Stroked 426 with nitrous: https://www.youtube.com/watch?v=uPAyVwL_C_I
JUN1269 is offline   Reply With Quote
Old 02-07-2022, 10:15 PM   #68
tucktuck
tucktuck's Avatar
Re: My 72 Build
Awesome! You have some skills for sure, I've been watching your build as well.
Old 02-07-2022, 10:19 PM   #69
tucktuck
tucktuck's Avatar
Re: My 72 Build
Didn't get much done today, but I got the high hump installed...
Started to tackle moving my rear end back 1-1/4" to center it up, but lost motivation once the kids and grand kid showed up.
I'll get it done tomorrow.
Old 02-09-2022, 12:51 AM   #70
tucktuck
tucktuck's Avatar
Re: My 72 Build
Well that was a pain in the ass...
Ended up having to move my crossmember back to center my axle in the wheels wells. The monster hyme joints would have had too much thread exposed if I didn't, so I tore it all apart. I got lucky with only having to drill one set of holes on each side though.
Old 02-09-2022, 12:54 AM   #71
tucktuck
tucktuck's Avatar
Re: My 72 Build
Here it is all back together. A lot of work for 1-1/4 inch...
Old 02-09-2022, 12:57 AM   #72
tucktuck
tucktuck's Avatar
Re: My 72 Build
Looks like I'm gonna have to get my driveshaft reworked...little too much of the trans yoke hanging out for my taste. Oh well.
Old 02-09-2022, 12:59 AM   #73
tucktuck
tucktuck's Avatar
Re: My 72 Build
Rear axle centered.
Old 02-09-2022, 01:00 AM   #74
tucktuck
tucktuck's Avatar
Re: My 72 Build
Before and after.
Old 02-09-2022, 08:01 PM   #75
Alex69c10
Re: My 72 Build
That’s a truly great looking build. A lot of work for 1/4” but it just makes it so much better!
Alex69c10 is offline   Reply With Quote
