08-03-2016, 11:48 AM | #1 |
Bagged Suburban Owners, questions?
So I'm in the market for a C10 2wd Suburban. I would like to eventually put full air ride suspension in the truck and lay it out either completely or most of the way. I love the look of a Suburban with the bumper/ fender laying on the ground when the truck is off.
My question is, how reliable is a bagged/ lowered truck like that to drive? I'd like to take the family on vacation in this vehicle, take it all around the Northeast, I live in MA. I've never owned anything that was low like that and just wondering what I have to look forward to. Thanks, Nick |
08-05-2016, 09:46 AM | #2 |
Re: Bagged Suburban Owners, questions?
Full air ride done properly will offer the reliability you are seeking. My 72 is bagged, given my system is near 10yrs old I do experience a slow leak here and there within the distribution block fittings. Easily fixed, but if you are going all new or auto level you can't go wrong.
I think your biggest concern will probably be if you don't go with an electronic leveling system you will always need to pay attention to how low your front end is so you don't buckle a fender when turning. |
08-05-2016, 09:57 AM | #3 |
Thanks for the reply. I really love the fully laid out look but I might end up going as low as I can do without cutting the rear floor. We will see what happens After I get a vehicle.
Nick |
08-06-2016, 12:26 AM | #4 |
You will be surprised how low you can go without cutting the floor.
I can barely fit my foot under the front/back bumper and again floors are uncut. |
08-06-2016, 07:36 AM | #5 | |
Nick Posted via Mobile Device |
08-06-2016, 04:46 PM | #6 |
Getting you pictures is not something I can do it this time just because of issues with my phone. You can pretty much find out anywhere online all of the steps you will need to do to lower your Burb. Just throwing some things out there right off the bat, drop spindles, drop shocks, C-notch the rear frame, lowering blocks for rear suspension. Not to mention you will have to cut out your entire front fender wells and remove multiple things in the engine compartment because of how high up the tires will sit to the hood. And then of course one of the last things would be the entire air ride suspension kit.
08-07-2016, 05:21 PM | #7 |
Check out my build
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD Last edited by 72MARIO; 08-07-2016 at 05:33 PM. |
08-08-2016, 05:02 PM | #8 |
I've had air ride on my burb since 2002. I haven't had to replace anything bag,lines or valve wise. I did replace a tank 2 years ago, it developed a pinhole.
I did "upgrade" the system to all digital last summer...and had the computer module melt on me with less than 400 miles on it. ART warrantied it out but I'm still cautious of it now. Bag,lines, valves etc still work well though.
you never have too many suburbans.... |
08-24-2016, 10:58 AM | #9 |
///Relaxed Atmosphere
my 72 Suburban has had air ride since 2002 and have only had to replace a pressure switch about 2 years ago and that is it. haven't had any problems with mine. I just recommend using good quality parts and don't go cheep on the components. I decide to do a full chassis upgrade and am installing all Porterbuilt suspension on mine right now. Here a few progress pics of it and a pics of it before I tore it down for the suspension upgrades.
72 Suburban 64 Chevy short fleet 04 Chevy Colorado Sport Reg Cab 2012 Chevy Avalanche 2003 Chevy S10 Blazer Xtreme http://www.hubgarage.com/mygarage/RA_Jeff 64 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=295915 |
08-24-2016, 01:36 PM | #10 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
08-24-2016, 02:25 PM | #11 | |
Thanks, Nick |
08-24-2016, 03:48 PM | #12 |
Nick I use Firestone airbags, air ride technologies electric valves, Viar compressors, Porterbuilt Xtreme front and rear kit. the floor will be done in 3/4" plywood like it came from the factory, but will be put in last once I get the fuel line and electrical all routed(hopefully this weekend ) the floor structure idea came from BruinD as he did the similar set up on his suburban.
08-24-2016, 03:50 PM | #13 |
That looks great and thanks for all of the info. From what I read online you can go fairly low in the rear without cutting the rear floor. I'd like to go as low as possible without cutting the rear floor since I would like the option of having all three rows of seats in the truck.
Thanks again, Nick |
08-24-2016, 03:59 PM | #14 | ||
08-24-2016, 04:03 PM | #15 |
Thanks for those pics as well. That's great, I'd like to go that low and stop there. Someday. I guess I need to buy a truck first??
08-24-2016, 05:12 PM | #16 |
Wide n'Low
A shot of mine with uncut floor and no drive train.. still fairly low
c-notch and bags w/Accuair
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
08-24-2016, 08:54 PM | #17 |
03-02-2022, 05:54 PM | #18 | |
what wheel ant tire size are you running here?
