Old 03-12-2022, 09:27 AM   #1476
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: How about some pics of 88-98 Part II
Nice looking truck Kevin. What are the tire size, drop and truck specs?
Front 2 inch drop coil with Belltech shocks. 255/60-15 on 8 inch rally wheel.
Rear 4 inch Belltech drop leaf springs. Belltech shocks. 275/60-15 on 8 inch rally wheel.
I chose coils in the front over spindles so I didn't have wheel interference issues and the need to trim the lower arms. In the back I chose the drop leaf springs because they are way easier to install than drop hangers and shackles and also it addresses the inevitable lean or unlevel sag that these trucks get in the back as they get older.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-12-2022, 03:02 PM   #1477
Boog
laying low
Boog's Avatar
It's got that just right stance. I've not bought lowered leaf springs before but I did once or twice heat some a little near the ends. It was just a 1/2 ton shorty and it never hauled anything much.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 03-12-2022, 03:41 PM   #1478
Tx Firefighter
My experience with lowered leaf springs have all been Belltech.
I have run two sets of them on GMT400 trucks, including this one. And I ran a set on a Ford Ranger I built a couple of years ago. They flat work and they fix any bit of out-of-level the trucks have. People underestimate how much leaf springs sag over time and then say "Chevy lean, they all do that". Not with good leaf springs they don't. And it beats all to hell having to remove the riveted on hangers for a typical 4 inch rear drop.
Old 03-12-2022, 03:44 PM   #1479
Tx Firefighter
Old 03-12-2022, 06:20 PM   #1480
b454rat
My two pieces…..
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 03-16-2022, 07:50 PM   #1481
MadRatt
MadRatt's Avatar
My 1989 C3500 Ramp Truck with a 454 and turbo 400 doing what it does. Pics are from Daytona Turkey Rod Run.
If you ain't living life on the Edge....
Your taking up entirely to much space!!!!
My 64 Stepper Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=586792
MadRatt is offline   Reply With Quote
Old 03-16-2022, 08:13 PM   #1482
Very nice hauler. Is that a Hodges body?
Old 03-18-2022, 11:56 PM   #1483
GSFMECH
On the road
GSFMECH's Avatar
My 98, I bought this truck when it was 2 years old. It's like part of the family.
Mike
Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos
72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works.
My new build thread "Castro"
https://67-72chevytrucks.com/vboard/...d.php?t=820934
My old build thread, the blue truck
http://67-72chevytrucks.com/vboard/s...d.php?t=271489
www.louisianaclassictruckclub.com
GSFMECH is offline   Reply With Quote
Old 03-19-2022, 07:57 AM   #1484
OutlawDrifter
Very sharp!
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 03-19-2022, 08:49 AM   #1485
Really nice! Goes to show how a well designed vehicle stands out. A little extra rubber to set it off as being special to the owner and kept up is all they need. They look good all by themselves
Old 03-19-2022, 07:33 PM   #1486
Boog
laying low
Boog's Avatar
An update to my ‘91. I have had these Outlaw wheels for 20 years and this is the 3rd truck they’ve been on.
Boog
primer is finer
Old 03-19-2022, 08:02 PM   #1487
OutlawDrifter
Looks good!
1991 Z/28, 6.0L/T56
Old 03-19-2022, 08:38 PM   #1488
Tx Firefighter
I got a new factory GM 88-93 grille and lights for my truck. Then I finally found some 88-89 sealed beam assemblies in the junkyard. So I converted my 97 model work truck front end to an 88-89 Silverado quad sealed beam front end. The GM grille is so much nicer than aftermarket. i had to save my money a long time to get all the new factory parts. One area I cut corners on was buying a billet grille emblem rather than a new OEM one. GM gets eye watering money for new original grille emblems.
Old 03-19-2022, 08:41 PM   #1489
OutlawDrifter
Looks great with the W/T smoothie bumper Kevin!
1991 Z/28, 6.0L/T56
Old 03-19-2022, 08:48 PM   #1490
I always wanted to swap the headlights in my '92 with glass 88-89 lights. A nice improvement.
Old 03-19-2022, 09:01 PM   #1491
Tx Firefighter
Thanks bud.
I think I gave like 35 dollars for the headlight assemblies from PicknPull. Then I wound up buying four new sealed beam bulbs from Rockauto. Some bead blast time and new hardware and paint and it wound up being nearly 100 bucks for them. But they're worth it in my eyes.
The turn signal lights below them are different too. They have black trim around them rather than silver like the 90-93 uses. And they mount on special 88-89 only brackets which go between the grille shell and the light housings to space them out further.
Old 03-19-2022, 10:04 PM   #1492
Nice detail. I always noticed the difference and preferred the early bulb set-up.
Old 03-19-2022, 11:28 PM   #1493
Just call me Sean
Just call me Sean's Avatar
I always thought it was odd my 93 grille has the molded in feature for the sealed beam headlights. It's barely noticeable unless you look for it though.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 03-20-2022, 12:09 AM   #1494
Boog
laying low
Boog's Avatar
Glass headlamps are better in my eyes. They don't yellow and scratch. I converted my old 97 GMC to 88 sealed beam lamps. I liked it much better and all I ever did was wash them.
Kev I am surprised GM still offers those grilles. Good to know though.
I may have to snag on some sealed beams for my 91 when the time comes.
Boog
primer is finer
Old 03-20-2022, 08:05 AM   #1495
1badgmc
1badgmc's Avatar
It makes sense on a '93 grille since it's the same grille as the '88-'89 trucks that came with the sealed beams. The '94-'98 grilles are also shaped that way, even though those grille styles never came with the quad sealed beams.
Old 03-20-2022, 10:38 AM   #1496
My '95 Suburban has factory sealed beams
Old 03-20-2022, 12:09 PM   #1497
Just call me Sean
That's so funny! I went to check my 99 all prepared to call BS and you're right. I never looked for it on that one, I assumed it didn't have it. It is less pronounced though.
Old 03-20-2022, 02:20 PM   #1498
Tx Firefighter
I ran an ad on Facebook for the old parts, cheap. No interest from anyone so to the dumpster they go. I don't like to keep too much clutter around.
Old 03-20-2022, 04:01 PM   #1499
SCOTI
SCOTI's Avatar
Some of us avoid FB....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-20-2022, 04:54 PM   #1500
Tx Firefighter
I've deleted it multiple times but I go back to it. There's nothing else that's active anymore. I hate it with a passion but a man's got to buy and sell.
