Old 03-14-2022, 09:15 AM   #1
C101968
Remove body sealer around roof drip rail ?
Best way to remove 50 year old body sealer around drip rail on roof.
mine is old and cracked, suggestions for replacement sealer ?
Thanks,
C101968 is offline   Reply With Quote
Old 03-14-2022, 10:20 AM   #2
raggedjim
raggedjim's Avatar
Re: Remove body sealer around roof drip rail ?
Thanks,
Old screw driver, wire wheel on side grinder, whatever will work to get it out.
Thread on options https://67-72chevytrucks.com/vboard/...ghlight=sealer
Good luck, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 03-14-2022, 02:18 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Here's what I used to reseal my drip rail.
http://67-72chevytrucks.com/vboard/s...&postcount=356
Sealer:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Applicator tubes:
Applicator gun:
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 03-14-2022, 03:59 PM   #4
BASE
BASE's Avatar
Good luck, Rg
I was going to recommend trying that. Mine mostly came out just by using a screwdriver, cleaned up the rest with a flat wire wheel.
BASE is offline   Reply With Quote
Old 03-15-2022, 12:26 PM   #5
I just did my driver's side with a wire wheel on one of my 4.5" grinders. Once I replace the drip rail I'll be sealing it. I have some brush on sealer, but I may do the self leveling stuff. I haven't decided yet. Make sure you check and paint it before you add the sealer. I am doing some Eastwood on mine. My friend used POR.
Old 03-15-2022, 04:46 PM   #6
Accelo
Accelo's Avatar
3M Self-Leveling Seam Sealer, 08307, Two-Part, Quick-Curing Epoxy is a great product and will look great. Will have the issue on how to do the rail where it curves down at the back. However, at $45 it is also the most expensive option.
Maybe this is another option, 3M Dynatron Auto Seam Sealer Caulk, 550, Grey Color, Permanently Elastic, Fast-Skinning, Non-Staining, Non-Sagging, 12 oz
It is only $15 and will not have issues on the not so flat areas.
https://www.amazon.com/550-Permanent...17&sr=1-5&th=1
I wish GM would have used Epoxy when the trucks were new. Would have saved a lot of headaches down the road.
Accelo is online now   Reply With Quote
Old 03-15-2022, 10:38 PM   #7
jumpsoffrock
Do you know what they actually did use? I always wondered if the dynatron 550 I use will end up looking like the factory stuff after 10-15 years in the CA sun...
jumpsoffrock is offline   Reply With Quote
Old 03-16-2022, 10:32 AM   #8
68 C10 Driver
I used a wire wheel on a grinder, came right out and got the rust out at the same time.
68 C10 Driver is offline   Reply With Quote
Old 03-16-2022, 05:34 PM   #9
landarts
landarts
If you are going to do paint on truck then heat will really help take it out. Use a flat blade screwdriver to remove the cleanup with a wire wheel then wipe down with acetone.
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
