03-14-2022, 01:19 PM | #26 | |
Re: Freshly Lowered Questions.....
I want to try something similar on my Squarebody (leaf spring) build coming up.
Kitsbeach (Ken) 1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills" |
03-15-2022, 01:26 PM | #27 |
I used Frizzle Fry's rear shock relocation method on my '66 along with an 80's F150/Bronco rear sway bar and it made a huge difference compared to stock. I've been recommending this setup anytime I see relocated shocks mentioned. I'm in the middle of doing the same thing on my new '66.
Using the hardware that came with drop blocks I had to slightly clearance the washer for the relocated hole since the new hole is closer to the folded edge. For the front I bought Currie shock mounts intended for axle tubes and drilled holes to mount them to the frame rails. With the relocated shocks, bump stop brackets completely removed, and front/rear sway bars the truck rode better than my dad's completely stock '66 and had less body roll than my autocross car. It was super stable on the interstate even at 90+ mph.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
03-15-2022, 05:46 PM | #28 |
Very smart about the shock mounts..!!
03-16-2022, 12:22 PM | #29 |
I have also used frizzle's rear shock setup. It works great. I would also recommend it.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
