New member from South Alabama.
Thanks for the add!
After wanting a square for a while I picked up an 84 Silverado last May for a song. Filthy and completely ruined by meth heads, but after months of hand-scraping spray paint and some elbow grease she is coming along nicely. Plan on bagging it during/after this cruising season, since I just grabbed an 84 Sierra Classic to keep close to stock I figured I may as well get weird with this one. |
![]() ![]() ![]() Join Date: Jan 2018
Re: New member from South Alabama.
Welcome! That's quite a transformation on the paint. Lots of patience there
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Thanks, three months of hand scraping with a flat razor, no chemicals. Then about 16 hours of wet sanding what was left of the factory Apple Red body stripe. I'll have to start a build thread as I start putting it on bags, I have tons of pics.
Yeah, that's a lot of work, but it definitely paid off. Pop those dents out of the door, and it would look even better
I can get to them from the inside and worked them out a little. Tried some suction cups on the outside as well. With it creasing that hard body line I am going to have some else do it so I don't make it worse. More pending things like exhaust for now though.
I'd probably do the same, especially when wanting to save the paint.
Moderator
![]() ![]() Join Date: Aug 2011
Welcome to the forum.
I've seen you in the squarebody build threads. Welcome!
![]() ![]() Join Date: May 2015
Welcome.. Enterprise, home of the boll weevil..!
