03-29-2022, 07:24 PM | #1 |
Steering wheel wobble
Please help I stopped driving myy 89 suburban years ago and just recently just put her back on the road. I replaced the steering wheel gear box but and had the wheels aligned. But I'm still all over the road ......everyone I've talked to keeps tell me that even the rebuilted units are the same. So my question for the board is " is there a newer years that will work in its place, or if there is anything else I can do to fix this problem
03-29-2022, 08:26 PM | #2 |
Re: Steering wheel wobble
I will assume the frontend tech who aligned it also made sure all the ball joints, tierod ends etc were good. I have had a bent rim cause a wobble (the tire shop bent the rim), also had tires on a couple of occasions get a small bubble and caused a wobble. Move your fronts to the back and see if it changes. Good luck
03-30-2022, 05:42 AM | #3 |
Just here to tinker
X2. Any one of those parts can contribute to the problem. Including sway bar bushings, etc.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
03-30-2022, 10:49 AM | #4 |
Wheel/tire balance?? 2 or 4 wd?
04-05-2022, 07:44 PM | #5 |
I hated loose steering so I learned how to adjust my own box and its much better now. gotta tighten the adjustment where the steering shaft goes in first. also helps to run a xj steering shaft as well.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
