Old 04-20-2022, 08:33 AM   #76
Jiggers72-GMC
Jiggers72-GMC's Avatar
Re: Bringing my Grandfather's 1972 Longbed Stepside C10 back to life
Right on man, your Grandfather would be proud,
don't forget to check the trans fluid one more time ........
Gerry, North Bay Ontario
1971 Chevy K10 short stepper, 518 med green & white
1972 GMC C1500 long box, dark Brown, owned since 1977
1969 GMC C2500 manual
Jiggers72-GMC is offline   Reply With Quote
Old 04-20-2022, 08:41 AM   #77
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice work! That's got to be a great feeling!
Ryan
1969 Chevy milk truck
Old 04-22-2022, 11:54 PM   #78
bwl101
bwl101's Avatar
Good to have it on the road, except now the starter gave out so will have to find a new one tomorrow...
'72 C10 Long Bed Stepside
Putting my Grandfather's truck back on the road:
http://www.67-72chevytrucks.com/vboa...d.php?t=829659
bwl101 is offline   Reply With Quote
Old 04-23-2022, 06:17 AM   #79
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Congratulations! It looks great outside.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 04-23-2022, 07:51 AM   #80
Dieselwrencher
Very nice! Sorry to hear about the starter. That's the old truck blues though.
Ryan
Old 04-23-2022, 08:21 AM   #81
Jiggers72-GMC
The truck really looks great, I can't believe how good the original paint is, you must feel proud of 'er. thanks Grampa !!
Old 04-23-2022, 08:52 AM   #82
kev2809
low n' slo
kev2809's Avatar
what a great patina it has, good work!
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 04-23-2022, 05:54 PM   #83
bwl101
bwl101's Avatar
Yep, I imagine more things will show as I put miles on it. Luckily only cost me $75 for a reman one from AutoZone. Starts so much easier and quieter now!
Old 04-25-2022, 02:14 AM   #84
bwl101
bwl101's Avatar
Now the one brake light that was working no longer does, in addition to the reverse lights no longer working???? I'm assuming on these it would be a ground issue?
Old 04-25-2022, 02:16 AM   #85
bwl101
bwl101's Avatar
Trans level is a little high, but it is shifting and all properly. I'm guessing from sitting the pan gasket on the trans dried up. After driving it about 70 miles, its starting to drip from the bolt heads on the pan. Can't tell if it's from the opening that the bolt goes through or if its leaking out the gasket and down and just finding the bolt head as that is the lowest place before dripping off.
Old 04-25-2022, 11:33 PM   #86
bwl101
bwl101's Avatar
Figured out this is all related to the turn signal switch assembly. Before today the horn would come on if you pulled the post toward you or like when signaling for a left turn. Pulled steering wheel off and cleaned up what was a nasty, dirty and corroded turn signal switch. Got it all cleaned up and now turn signals work along with the brake lights. Unfortunately, post will still activate horn and the rear passenger brake light will work depending on position of the post. It appears that the switch grounds on itself somewhere when the post is moved around. So I ordered a new switch and wiring harness and will get it put in when it arrives and hopefully that will solve the brake light/ turn signal/ reverse light issues.
Old 04-26-2022, 07:30 AM   #87
Jiggers72-GMC
That looks nasty in there, I hope the new switch fixes all that .......
Old 04-30-2022, 02:42 PM   #88
bwl101
bwl101's Avatar
Well now ended up with only 30psi in the #8 cylinder due to an exhaust valve issue. So instead of putting money into an engine without known history or mileage, I ordered a reman 350 which I can use all the accessories I have already purchased. Looking forward to getting a motor in there with a little bit more power and *hopefully* more reliable. Of course I will update as I make progress!
Old 05-01-2022, 07:46 AM   #89
Jiggers72-GMC
Well that sux, I guess Grampa didn't want the 305 huh ............
Old 05-01-2022, 09:45 AM   #90
Ol Blue K20
Totally sucks.
Dale
Old 05-02-2022, 09:56 PM   #91
bwl101
bwl101's Avatar
Got the new turn signal switch installed, which has fixed all the turn signal and taillight issues. Also got the horn stuff in correctly so the horn only honks when I want it to. Also got motor mostly torn down and ready to come out after the motor mount bolts, bell housing bolts and torque converter bolts are removed.
Old 05-02-2022, 10:49 PM   #92
Ol Blue K20
I'm glad the switch worked out. Used engines are always a gamble. I'm sorry it didn't work out. But, it work good enough for you to drive grandpa's truck!
Dale
Old 05-03-2022, 08:55 AM   #93
kev2809
low n' slo
kev2809's Avatar
that looks a lot cleaner.
at least with the crate there is no doubt what you will have under the hood, peace of mind.
-_--_--_ _________
Old 05-03-2022, 09:28 AM   #94
Jiggers72-GMC
I was wondering who you ordered the engine from, looks like I also have a dead cylinder
Old 05-03-2022, 10:20 AM   #95
bwl101
bwl101's Avatar
Jegs, only place that had one that was in stock. They have a few others showing end of May or end of July shipment. The one I ordered was an ATK one. Also Jegs was best price, some places want $2,700 for a long block plus a $800 core charge! One I ordered was $2,100 for long block and a $400 core. They are all stupidly priced now though. Just a couple years ago you could get a nice reman 350 for less than $2,000 including core charge. Sucks but I'll have more power and better reliability now. Plus while taking stuff off this 305, it became more apparent how poor of shape it was in when draining all the fluids.
Old 05-03-2022, 12:36 PM   #96
Jiggers72-GMC
Thanks for the info Sir
Old 05-03-2022, 10:55 PM   #97
bwl101
bwl101's Avatar
Well, the 305 is back out of the truck. Am now waiting on the new motor to get here. The more we took off the 305, the better I am feeling about buying a new motor. That oil has only 105 miles on it, that just shows how dirty that thing was inside.
Old 05-04-2022, 07:36 AM   #98
Jiggers72-GMC
I hope you get the new engine soon and everything works out for you. Good thing your neighbor has a nice garage.
Old 05-06-2022, 01:12 AM   #99
bwl101
bwl101's Avatar
It should be delivered tomorrow, and yea without him and his garage this wouldn't have been possible!
Old 05-07-2022, 12:37 AM   #100
bwl101
bwl101's Avatar
New crate engine came today! Was very happy to see it arrive!
