Old 12-28-2021, 10:30 PM   #51
Crjpiolt
Crjpiolt's Avatar
Re: 30% More Powerful-New 1/2T Power Brake Sys
PayPal payment sent your way. Thanks and Happy New Year!!!
Crjpiolt is offline   Reply With Quote
Old 01-27-2022, 04:00 PM   #52
Wardo
Hi, I’m interested in this for a ‘68 GMC long-bed with drums all around.
Do you still have them available?
Thanks…
Wardo is offline   Reply With Quote
Old 01-27-2022, 04:01 PM   #53
Wardo
Forgot to mention it is a 1/2 ton…
Old 02-16-2022, 07:15 AM   #54
chewychevy67
I was wondering if you sell just the booster? I'm looking to replace a failed stock booster on my 67 1/2 ton and the smaller double diaphragm booster would be nice.
chewychevy67 is offline   Reply With Quote
Old 02-16-2022, 12:44 PM   #55
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
No parts for sale. Complete systems use coordinated parts and are not just stock replacements.
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 02-16-2022, 12:51 PM   #56
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Thanks…
Yes. Still building complete systems, as shown. I use new adjustable valves and lines on my Drum/drum units. These function as a Dist Block and fit really well. Note 2022 prices.
Phone: 360-956-7170
Old 02-16-2022, 01:30 PM   #57
MikeB
MikeB's Avatar
What size is the booster and the master cylinder's bore diameter? And the system is 30% better than what? I assume that's relative to some of the aftermarket kits that don't properly size the master cylinder and booster.
I ask because my 69's stock 71-72 master cylinder, booster, and disc/drum brakes will just about put me through the windshield!
That said, the factory did a much better job than the aftermarket does today. Way too many improperly sized boosters and master cylinders, and "one size fits all" fixed-pressure proportional valves used by default. I like that yours was designed specifically for our trucks, and fits without mods.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 02-16-2022, 06:29 PM   #58
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
The booster is 9" dual diaphram (DD), new, built for our systems. It is 30% more powerful than original OEM 1/2T. Other components are selected and fitted for our specific truck applications, not some universal off-the-shelf car parts. You cannot buy this system in catalogs or web sites.
Phone: 360-956-7170
Old 02-16-2022, 07:39 PM   #59
MikeB
MikeB's Avatar
The dual 9" booster answers my question! That's a good way to go. Funny that some kits have dual 7" or even a single 8". Downside is you may put some guys through the windshield.
Mike
Old 03-14-2022, 05:48 PM   #60
richard2717
Equal opportunity joke ofender
richard2717's Avatar
Sending PM with questions
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 03-16-2022, 07:43 PM   #61
Jbrem010
Originally Posted by PICKMUP View Post
Yes. Just ask for DISC/DISC set and I will build it that way. I can accept PP or Visa/MC "IF" you would like to add the extra 3% add on processing fees. There are no extra fees with USPS MO.
Frank, what is the reference to "MO" above? I see you're in WA, does it reference Mail Order or Missouri? I'm in Missouri and why I'm asking.
Jbrem010 is offline   Reply With Quote
Old 03-17-2022, 08:54 PM   #62
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
MO = Money Order
Phone: 360-956-7170
Old 04-18-2022, 05:21 PM   #63
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
'2022 PRICES: $375 + $75 S/H/INS =
I split the increases with you.
Phone: 360-956-7170
Old 04-24-2022, 09:05 PM   #64
zicc1835
zicc1835's Avatar
Frank
my 71 has manual MC I want to upgrade to your unit I have a mild cam in my 327 im assuming that should not pose a vacuum problem ? disc /drum
thanks
Jess
zicc1835 is offline   Reply With Quote
Old 04-25-2022, 07:45 PM   #65
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Originally Posted by zicc1835 View Post
Frank
thanks
Jess
Mild cam should be OK.
Phone: 360-956-7170
Old 04-25-2022, 08:44 PM   #66
MikeB
MikeB's Avatar
MP Brakes says you need 18" minimum idle vacuum, but I think that's conservative. That number will vary with caliper and pad type, as well as booster area and vehicle weight.
The kit listed in this thread uses two 9" boosters, which is a lot of diaphragm area! So I'd say 16"-18" should be fine, assuming your calipers, pads, rotors, drums, shoes and hoses are in good shape. Otherwise it's like installing a performance cam and a new carb on a worn-out engine.
Mike
Old 04-26-2022, 11:35 AM   #67
truckdude239
truckdude239's Avatar
how does the pedal higheth compare to the manual brakes? i tried swaping to power brakes once and never could get a decent pedal and it sit like 2 inchs lower then the manual setup.
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 04-26-2022, 01:46 PM   #68
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
It sits in the same location as the stock/OEM PB pedal.
Phone: 360-956-7170
Old 05-09-2022, 05:43 PM   #69
extd56
extd56's Avatar
I would like to order one for my Jimmy
extd56 is offline   Reply With Quote
Old 05-10-2022, 02:18 AM   #70
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
I have all the components in stock. Just send PP with all info.
Thanks, Frank
Phone: 360-956-7170
Old 05-10-2022, 05:58 AM   #71
zicc1835
zicc1835's Avatar
thank you Mikeb much appreciated
Old 05-12-2022, 08:55 PM   #72
Woodsloafer
Tag
Woodsloafer is offline   Reply With Quote
Old 08-29-2022, 07:12 PM   #73
72peace
72peace's Avatar
Sir, are these still available?
70 Custom 10 350 w/700r4 (current)
69 Custom 10 I250 Three on the Tree
72 Cheyenne Super 350
66 Ford F100 I240 Three on the Tree
72 Chevelle Malibu 402
66 Pontiac Catalina 421
65 Ford Fairlane 500
72peace is offline   Reply With Quote
Old 11-21-2022, 06:30 PM   #74
bobvilla67
Are these still available? If so, I will take a complete set-up.
bobvilla67 is offline   Reply With Quote
Old 11-22-2022, 02:39 PM   #75
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Yes. All components are back in stock and I am building & shipping these regularly. Just send PP to below address. Thanks, Frank
Phone: 360-956-7170
