05-11-2022, 01:54 AM | #1451 | |
Re: What did you do to your truck today part IV
Thanks Palf!
Thanks! Quote:
Thanks! Yeah I'm pretty stoked with the sound. Tried to get as much of the raspyness out of it as I could. Those mufflers helped alot and next will be decently long tailpipe tips a good inch bigger in diameter to mellow it out more.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
05-11-2022, 11:12 PM | #1452 |
cleaned up some trans linkage, organized the toolbox and installed my (unofficial) front plate
1960 C-10 Apache- "Rusty the Redneck Reject"
1/2 Ton short bed step side. 350 crate motor, 3 speed manual (floor shifted) MKII - Buddy Buckets and Glass Packs 20+ year long term project in process Lots of Rust, more memories... |
05-12-2022, 01:46 AM | #1453 |
I like the front plate.
05-12-2022, 12:49 PM | #1454 |
Thanks, I figured it answered the 2 most common questions, what year? and why isn't it painted yet?
05-12-2022, 01:11 PM | #1455 |
NICE! I hate the statement, it's going to look great when you paint it. I look over at my truck and say, you don't like my custom paint job?
05-12-2022, 01:14 PM | #1456 |
I didn't do anything sexy to my truck but I had a small transmission leak at the mechanical speedo connection. Finally (hopefully) fixed the leak! Leaks are super annoying!
05-12-2022, 01:15 PM | #1457 |
05-12-2022, 01:16 PM | #1458 |
05-12-2022, 01:20 PM | #1459 |
haha..a little. What I really love is when they think cause it "needs" a paint job it is junk...so I open the hood to show off the engine candy! LOL
No, it's a Tremec T56 Magnum 6 speed. Love the trans...hated the leak. I finally bought a new mechanical speedo adapter from Bowler (has multiple Orings). Pricey, but worked! |
05-12-2022, 01:30 PM | #1460 |
No, it's a Tremec T56 Magnum 6 speed. Love the trans...hated the leak. I finally bought a new mechanical speedo adapter from Bowler (has multiple Orings). Pricey, but worked![/QUOTE]
Okay. I only asked because I had a 350 that I could not get to stop leaking from that location. |
05-16-2022, 11:10 PM | #1461 |
Picked up my Suburban body on Friday after blasting and primer. A little rougher than I thought.
Spent the weekend assembling my suspension, also cleaned and painted the engine. Not quite the color I wanted but it will work.
1951 Truck, LS1/4L60 1964 Suburban, current project 2014 Silverado daily driver 1953 Westerner "canned ham" trailer, rebuilt 1974 Prowler trailer, rebuilt |
06-11-2022, 09:55 PM | #1462 |
But Found Her 25yrs Later!
Moved my engine forward around 1/2 inch to 3/4 inch to give me more space between the distributor and the firewall.
06-15-2022, 02:11 AM | #1463 |
Brought Crustine the GMC home from the shop finally. Now onto driving again!
06-15-2022, 12:39 PM | #1464 |
Been doing this for a while. Replacing rusty rockers on the 65. Already have the passenger side done, these are pics of the Driver side.
moving on to seam sealer soon.
1965 C10 350 combo |
06-16-2022, 03:41 PM | #1465 |
Chased an electrical issue until I finally figured out that there was a grounding issue for the bulb socket to one of the tail light housings. Putting the housing on the negative post didn't work. I had to run a wire from the bulb socket to the metal housing to complete the circuit. Strange, just on the one side. I could have just bought a new housing, but a short chunk of wire was cheaper.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 06-16-2022 at 03:46 PM. |
06-17-2022, 05:32 PM | #1466 |
Bled the brake and clutch systems, replaced the leaking air bags with springs and shocks and got it back on the ground.
06-24-2022, 03:08 PM | #1467 |
It's been some days, but I wanted to post this.
First time using my new tractor to do something with my truck. Boy oh boy - perfect fit with the bucket.
06-24-2022, 04:48 PM | #1468 |
Moderator
Cool. Tractors are the best.
06-24-2022, 05:33 PM | #1469 |
It's about time..
I used to be able to just lift the hood off by hand by myself. Seriously.
06-26-2022, 01:28 PM | #1470 |
Clever
------------------------------------------- Greetings Harald My 62 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=829782 |
07-02-2022, 05:55 PM | #1471 |
I modified my finned air filter cover so that I can us a center stud instead of the complicated way it was originally attached. I might end up stripping the paint and having it polished to go better with my new aluminum heads on my new 355.
07-04-2022, 04:30 PM | #1472 |
Washed the truck so I could take a picture of the new shoes.
07-04-2022, 05:52 PM | #1473 |
After looking at the photos I think I need to even it out a little better and paint it black.
07-08-2022, 10:20 PM | #1474 |
Who Changed This?
I'm digging that truck, end of story. If I had it, it would be all black, except for the Ed Hubbs style flame job.
07-17-2022, 11:00 AM | #1475 |
Welded in some bed rails, most I haul in the truck are motorcycles😉
