05-21-2008, 02:21 AM | #1 |
Back in the sticks
Hood Alignment
Need some help. I can't get the hood on the Blazer to line up. I've shimmed the driver's fender to make the measurements match the 71, but I still have a huge gap on the passenger side at the front end only and the latch won't even come close to making. Any idea's? I've tried preloading the springs, adjusting all the bolts on both the 6 in the fenders and the 4 in the hood. Still no joy. No matter how I adjust it, I still have a huge gap on the leading edge of the passenger side. Closest to the grill I mean. Any help would be great.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
05-21-2008, 02:39 AM | #2 |
Re: Hood Alignment
Have you checked the "X" dimensions on the rectangle formed by the fenders, radiator support and cowl. It sounds like the rectangle is out of square so you may have to shift the body or the radiator support to square it up. Also, have you tried adjusting the triangular brackets that mount the fender to the radiator support.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
05-21-2008, 02:49 AM | #3 |
Re: Hood Alignment
I am having the same problem on my 72 c20. Subscribed for info.
The ONLY way to go. 1972 C20 Custom Deluxe: Rebuilt 402 hopped up a bit, th400 with shift kit, Dana 60(wanna have posi), New solid, no cancer, cab. B & M Starshifter floor shifter. |
05-21-2008, 02:50 AM | #4 |
Back in the sticks
Re: Hood Alignment
I did check the square on it, thats the other reason I shimmed the driver's fender. That brought the two sides into alignment as far as fenders to cowl and fenders to radiator support. The distances are now the same on both sides, but the hood still didn't come into the right place. Which way would I move the triangles in order to pull or push the passenger in or out? Thanks, Jeff.
05-21-2008, 03:04 AM | #5 | |
Re: Hood Alignment
69 Chevy 4x4 383 Power |
05-21-2008, 03:09 AM | #6 |
Back in the sticks
Re: Hood Alignment
Hmm, I'll give that a try as well. I need to realign the windshield anyway. Thanks and I'll update you guys after I pull the windshield on the passenger side. Jeff.
05-21-2008, 06:40 PM | #7 |
Back in the sticks
Re: Hood Alignment
Ok, checked my "X" again, and I'm about an inch different between sides. I tried to pull the driver's side forward and got about a 1/4 inch more on it and its closer, but the passenger side is still way out. Still won't latch either. I lined up the windshield frame and braced both sides so it can't move, so all I'm doing is moving the fenders and radiator support.
Should I loosen up the bolts on the support mount bushings? Might make it easier to slide it around. Got some more "honey-do" stuff today, but I'll update again this afternoon.
05-21-2008, 07:49 PM | #8 |
Re: Hood Alignment
loosen all the bolts one your fenders and rad support andf try to manipulate it to get things square. You pretty much need to have everything loos to get all the pieces to wiggle which ever way they need to go. You may need to shift the cab some too depending on the situation.
I don't remember the exact difference, but there is something different with with hoof latch assembly between the 69/70 years and the 71/72 years which might account for it not latching.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 05-21-2008 at 07:53 PM. |
05-21-2008, 08:36 PM | #9 |
Re: Hood Alignment
I would remove the whole piece or the rod from the hood while lining up the hood, just confuses things. When you get the hood to fit, then play with the latch. I almost wore out the bolts on the cab and radiator mounts on both the 68 and 70 before finally getting them right.
Rad support has to center on frame, else bumber will be off, work back and play with cab but keep in mind box alignment to cab. Frame could be a little tweaked too, Lots of fun, move one part, then something else is off, doing another one this summer, not looking forward to lining all the stuff up again.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
05-21-2008, 08:57 PM | #10 |
Re: Hood Alignment
Out of fAQ's -
Hood alignment: Let's start with raising and lowering the rear of the hood. If the car you are working on has a hinge that sits on top of the cowl, your only options are to shim or bend the hinge. Bending the hinge slightly is one way to move it. If you need to come up in the rear you can put a small block of wood or other item on the hinge, to bend it. When you close the hood down (NOT ALL THE WAY) it will get in the way of the hood closing and bend the rear or the hinge up. If you need to bend it down, the only option may be to remove it and bend it a little. You can also shim the bolts between the hood and the hinge, more on this later. If you have a hood where the hinge mounts on the side of the fender or the side of the cowl like with an older car or truck, you want to "rotate" the hinge on the fender. Just pushing the hinge up and down will give you very little movement on the top of the hood. This is the strange little trick that you have to remember, if you raise the back of the hood on the hinge or raise the back of the hinge on the fender the hood will go up. If you raise the "front" of the back of the hood ON THE HINGE or the hinge to the fender it will go down. What you have to remember is you are working with a pivot point in the hinge, not a stationary part. If you loosen the FRONT bolt on the hood (where it bolts to the hinge) and put a shim, or washer between the hood and hinge, this will LOWER the hood on that side. If you put that same washer under the rear bolt it will RAISE the rear of the hood on that side. So, if you loosen the bolts from the hinge to fender and close the hood, the hinge will rotate on down in the front right? This will raise the REAR of the hood like putting a shim in the back bolt between the hinge and hood! What you need to do to lower the back the hood is to loosen the bolts (only slightly) and PUSH UP on the front of the hood. This rotates the hinges back, thus raising the front of the hinge and lowering the hood in the back. If the hinges are warn out it won't change how high the hood sits when the wear, not by more than a fraction of an inch. And I have never seen a car with these style hinges that you couldn't put the hood a half inch LOWER than the fenders if you wanted to. The adjustment is HUGE on these cars. That is one of the things that is easy to do on them is align panels. I recommend you remove the striker or latch from the hood so that you can move it up and down without worrying about the latch grabbing the hood. After you have aligned the hood, take a piece of dumb-dumb or clay or something similar and put it on the latch. This way you can see exactly where it hits when you do install the latch. You bring the hood down till you just tap this dumb-dumb but DON'T LATCH IT. Just so the hood makes an indentation in the clay/dumb-dumb. This tells you where you have to move the latch. I do this at work everyday, by my self so if you can't get help this is the trick. Always leave one bolt on the hinge tight. If you want to rotate it back, leave the front bolt tight. If you want to rotate it forward, leave the rear bolt tight. When you move the hood forward or back on the hinge, leave the bolts snug enough that you have to tap on the edge of the hood to get it to move. Or if it needs to go back, leave the bolts a little snug, and wiggle the hood up and down and the weight of the hood will make it slide down. Remember it only needs a 1/16" or so to make a 3/16" or more change at the front. To pull the hood forward on the hinge loosen them so they are still a little snug so you have to pull up on the back of the hood to make it slide that little bit. If you loosen it up so it moves anywhere you want it, YOU WILL NEVER KNOW HOW MUCH YOU MOVED IT AND YOU WILL MOVE IT TOO MUCH, GUARANTEED. Get the hood laying flat first, then move the hood forward or back on each side to make the hood fit the hole between the fenders. If the gap is large on the front right and small on the front left, then the hood needs to me moved back on the right side. As you move the hood back on a side it will close up the gap in the front of that side and open it at the rear of that side. You may need to move fenders too. Just do each change slowly, move it VERY LITTLE. Look at the bolt and washer as you move the panel, you will see where the washer used to be, the amount is much easier to control if you watch the washer movement. If you need to move the hood up or down at the front, you have a few ways to do it. First, on each side there are the "bumpers". The hood bumpers are located at each front corner and look like a bolt with a rubber pad on top. Just unlock the jam nut and raise or lower the "bolt" so it holds the hood at the height you need to match the fender. You may find that the hood won't go low enough even with the bumper down far enough. The latch may not be down far enough. When you close the hood, you shouldn't be able to pull up on the hood or push it down. The latch should be tight enough to hold it against the bumpers tight, but not too tight. If you have to apply too much force to open the hood or it opens with a loud POP, the latch is probably too tight. If it is at the right height but you can lift it up some, then the latch needs to be moved down. Doors: If the doors are off the car, bolt the hinges to the door and the cowl in the middle of the movement allowed. Let's face it, it "shouldn't" be too far off the center of holes. If the doors are on or if after putting them on things are way out of whack, raise the door up on the hinges as far as it will go while still staying about the right height. You always want to start high, it is much easier to come down than go up. Besides this is the ONLY time you will loosen all the bolts on the door. I don't mean ALL the bolts, leave the hinge to cowl (or center post on a four door) tight. Only loosen the door to hinge bolts. Unless it is WAY down then you may need to move the hinges up too. But do one at a time, both door to hinge or both hinge to cowl/center post. While moving the hinges aligning the door NEVER loosen all the bolts on the hinge, NEVER. Loosen all but one, just till it is still a little looser than "snug". Leave that last on just a little snug. Let's say the door fits well but is a little too far forward. NEVER loosen top and bottom hinges and move it forward. Loosen the top hinge to cowl/center post as described above and lift the rear of the door, a LITTLE. This will push the upper hinge forward. Now TIGHTEN that one bolt that was left snug. Do the same on the lower hinge, pushing down, but remember the weight of the door is helping, so little push is needed. If the door fits well but is out at the top or the bottom, again, loosen ONE hinge to DOOR in the manner described and push it out or in. If it is out or in at the top rear for instance, move the bottom front in the opposite direction. This will pivot the door on the striker, and move the rear top where you want. Moving the bottom rear takes moving the top front of course. You may need to twist the door. If the front fits well and rear is out at the top (or bottom, just reverse) you can put a block of wood at the rear of the door at the top lets say and push in on the bottom to twist the door. Some will take a LOT of force to bend, and be VERY careful not to let your fingers hang around the outside of the door edge!! I lost a finger nail doing this on a '69 Shelby GT500 convertible once (remember it well) when the block of wood fell out with all my weight on the door while twisting!! Tip: If you are hanging the door and you have access to the hinges (either through the wheel well with the skirt off or if the fender it's self is off) you can simply hold the door up to the opening and push the latch shut. Then put the bolts in the hinge. I can often install doors all by my self in this way. Deck lid: The trunk lid is pretty much like the hood but the hinges don't move at all on the body (usually). So shimming and twisting are a few of your only options beyond the movement in the slotted holes on the hinge. Bending the hinge or pushing up or down on the sides of the quarters, front or rear panel are the others. These should be done ONLY after all other things are tried. Fenders: Most of the tips for doors and the hood work here, with a little twist or two. Start with fitting the rear top of the fender. I like to put all the bolts in, loose. Not falling out loose, just so the fender would easily move. Close the door, and with the hood open adjust the gap at the top of the rear of the fender to door. After you tighten other bolts this cannot be modified so, do it first. Tighten the bolt under the hood closest to the door to secure the position. You may need to shim a bolt at the rear of the fender to the cowl, to move the fender forward or back. After you have that bolt tight and the gap is to your liking open the door and tighten the rear fender bolt that is at the top of the fender in the door jamb. Now do the bottom bolt, with the door closed, adjust your gap. You may need to wedge a flat blade screwdriver or body spoon to "force" the fender forward to get the desired gap. Or just the opposite, use a 2x4 or something similar off the front tire to force the fender back to get the gap. This is one of the hard spots to get nice because you have to get both the gap and the in and out of the fender to door at the same time with the same bolt. Some cars have two bolts that are far enough apart to get the gap and tighten the front bolt and then pull the fender in or out and tighten the rear bolt to get the flush fit of the panels. General tips: Bending a panel or adjacent panel is sometimes required. You can get this done in a number of ways, one is to use a block of wood. Let's say that along the edge of the hood there is a spot that is high. Well you can't adjust it down, the front and the rear are perfect. So you can lay a block of wood on the spot, right at the edge where it is strong. Using a big hammer (the bigger the better, trying to make a small hammer do the job can cause a lot of damage) hold the block and strike it nice and solid. Then check the results, you may need many strikes to do it. In doing this you may want to support the hood at the front with a block of wood under the hood. This way the hood is up off the fender and it will bend easier because of the solid rest it has. You can also put the block under the edge of the hood at a low spot and with steady pressure bend it down at a point if you need it. If you are working with very tight tolerances, you can actually grind the edge of a panel or jamb to get an extra fraction of an inch. Be VERY careful and using a fine disk like 80 or 120 take a LITTLE off. You don't want to grind the metal thin of course but a LITTLE can make a big difference when you are fighting for fractions. Now, you really won't be cutting too much metal, you are really just cleaning off ALL the primer and paint there. Then when you prime it, don't put a lot or sand it thin so there will be very little on the edge. You may want to paint the hinge with a little contrasting paint. Do it with the hinge bolted on, right over the bolts. This way you can see easier how much you have moved it. These directions are for doors where the hinge bolts flat to the side of the cowl and then flat to the front of the door. There are of course many ways the hinges can be mounted on cars. If yours are different than you need to use the "concepts" that I have described here. If for instance you have a 1950 Chevy pickup. The hinge bolts flat to the back of the cowl but will work the same way. The door hinge bolts flat to the side of the door. In this case you do just the opposite as I earlier described. You would loosen the hinge to cowl bolts to move the door in and out and the hinge to door bolts to move it back or forward. If you find that your car has a design that hasn't been addressed, take a good hard look at your hinge arrangement. If the door is open, close it enough while you can still see the hinges and imagine what direction will it go if you loosen a particular set of bolts. Get an idea of how you can move it, then start the alignment process. These are just ideas that I have used over the years and some may work for you some won't, but it is a start. Above all, have fun!
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread |
05-22-2008, 02:41 AM | #11 |
Back in the sticks
Re: Hood Alignment
Was that some of Martin Sr's stuff? I looked but didn't find it in there.
Anyway, here is where I'm at: Removed my shim from the fenders and loosened the core support and slid it as far as I could get it to the driver's side. Here's where my hood is now...and it latches! Still need some fine tuning...
05-22-2008, 02:43 AM | #12 |
Back in the sticks
Re: Hood Alignment
Also got a new cute little air cleaner! Had to post a pic...
05-22-2008, 04:12 AM | #13 |
Happy Camper
Re: Hood Alignment
Who care if things line up... the engine looks good! Grin.
RIP El Jay! Love you brother! |
05-08-2013, 10:55 PM | #14 |
Re: Hood Alignment
This is what I have learned from others and done myself.
First: do the fender alignment. With the hood open, close the doors. Start with fitting the rear top of the fender. Place the ½” bolts in loosely. Adjust the gap at the top of the rear of the fender to door. Tighten the bolt closest to the door to secure the position. You may need to shim that bolt at the rear of the fender to align with the cowl (or shim the cowl to the fender whichever). Open the door and tighten the rear cowl bolt. Now, do the bottom fender bolt with the door closed, adjust the gap. You may need to wedge a non-scratching blade or body spoon to "force" the fender forward to get the desired gap. This is one of the hard spots to get nice because you have to get both the gap and the in and out of the fender to door and the cowl at the same time. Shims/washers may be needed to get excellent fit. Second: verify the core support is tight to the frame. Using a large builders square, check the “square” on the hood opening. Measure opposing corners for total distance accuracy, prepare to loosen core support and reposition or slightly shim the tops of the fender where fender attaches to core support. If OK and the distance between rear of fenders along firewall and front of fenders along core support are a 3/8" wider than hood widths then get the hood laying near flat on the hinges, then Move the hood forward or back on each side to make the hood fit the opening between the fenders. NOTE: If the gap is large on the front passenger and small on the drivers, then the hood needs to me moved back on the passenger side. As you move the hood back on a side it will close up the gap in the front of that side and open it at the rear of that side. Third: Check alignment of hood latch. Short of loosening the cab (as a last resort), use a bar to bend the hinges a little! Or drill out the hinge alignment holes with a step drill bit! But only if very close to perfect alignment. If not, loosen the cab and reposition the cab and start over with the fenders because you know the front clip is straight and square. |
08-21-2016, 01:25 PM | #15 |
Re: Hood Alignment
I can always count on finding detailed info on here about nearly EVERYTHING. This is one of the biggest PITA tasks I have had to undertake on my truck and I appreciate the help. Especially because most of the adjustments (like doors!) are counter-intuitive !!! Thank You to all the folks who have figured it out on their own or do it every damn day for sharing your knowledge with us. Each one-teach one, makes us all wiser.
Wanda - 1969 C/10 LWB 250 I6 3OTT LWB>SWB |
05-12-2022, 07:09 PM | #16 |
Re: Hood Alignment
Hi all - I see this a very old thread but I am hoping I can get some help here. I have recently started working on my 1970, I would really like to get the hood fitting properly. Question is - previous owner couldn't offer up much about the history, basically his teenage son had it and used it the way teenagers do - i think the grille is caved in from a low speed crash into a retaining wall or something - could that be causing the misalignment - meaning I need a new rad support - or - should I follow the instructions above and loosen fenders rad support etc. and try to re-square everything first?
I dont see any obvious damage or deflection in anything besides the grille and obviously the offending hood. Any wisdom from the group here is greatly appreciated. |
05-12-2022, 07:50 PM | #17 |
Re: Hood Alignment
An aftermarket core support adds another level to the already complicated issue.
I would not change it out unless I had to. |
