05-11-2022, 09:21 AM | #51 | ||
Re: Factory chalk/paint marks
Does it look like that in real life, too? Quote:
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
05-11-2022, 11:03 AM | #52 |
I'm trying....
Definitely a ding Keith. But I read it as leaving the factory with it. It is not a build sequence stamp. Truck seems honest.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
05-19-2022, 01:08 AM | #53 |
1968 GMC 3/4 ton markings on back of cab after bed removal. Any ideas what the 525 represents?
1968 GMC 920 Longbed Original 307 |
05-19-2022, 01:40 AM | #54 |
Driver door 1970 Fremont suburban. Not chalk, but more like etched into paint.
05-19-2022, 07:34 AM | #55 | |
525 = build sequence number. You might find this in other areas, too (on the front end sheetmetal, radiator support, rear axle, front suspension crossmember, inside one of the wheels, front of the pickup box, etc). K
05-19-2022, 07:34 AM | #56 |
that looks like the same style of marks on my firewall,appears to be someone's initials scratched into the paint while it was still wet.i have 2 marks,both different on each side of my Fremont,Ca built Cheyenne Super.
05-19-2022, 07:35 AM | #57 | ||
See if there are any that match documented in here: http://67-72chevytrucks.com/vboard/s...light=sequence http://67-72chevytrucks.com/vboard/s...light=graffiti http://67-72chevytrucks.com/vboard/s...light=graffiti http://67-72chevytrucks.com/vboard/s...light=graffiti http://67-72chevytrucks.com/vboard/s...light=graffiti http://67-72chevytrucks.com/vboard/s...d.php?t=545345 http://67-72chevytrucks.com/vboard/s....php?p=6543084 K
05-19-2022, 07:38 AM | #58 |
I'm trying....
What do the firewall marks on this truck look like?
