Old 05-21-2022, 12:58 PM   #1
Gary 70 Jimmy
Gary 70 Jimmy's Avatar
Found washer in rear axle
Changed the seals in rear axle put shafts back in and found this washer lying in the bottom of the axle don't no where it goes.
1972 GMC Jimmy 1/2 4X4 4wheel camper
1970 GMC Jimmy 1/2 4X4 350
1969 Chevy Blazer 1/2 4X4 307
1967 chevy LWB 3/4 396
Gary 70 Jimmy is offline   Reply With Quote
Old 05-21-2022, 02:02 PM   #2
jocko
jocko's Avatar
Re: Found washer in rear axle
I think it’s a spider gear thrust washer - believe it goes between a spider gear and case. Might check the others that aren’t missing a washer to confirm location and orientation.
Old 05-21-2022, 02:05 PM   #3
bluek5
bluek5's Avatar
i think it’s a spider gear thrust washer - believe it goes between a spider gear and case. Might check the others that aren’t missing a washer to confirm location and orientation.
x2
bluek5 is offline   Reply With Quote
Old 05-21-2022, 11:38 PM   #4
indymachinist
Agree. That goes behind the spider gears. When you had the diff pin out did you spin an axle? If so the washer could have slipped out.
-Curt
My 1968 Chevy shortbed stepside build
indymachinist is offline   Reply With Quote
Old 05-21-2022, 11:56 PM   #5
Gary 70 Jimmy
Thanks I will check it out.
Old 05-22-2022, 02:19 AM   #6
Accelo
Accelo's Avatar
Happens all the time. The confusing part is some differentials require them and other do not.
Accelo is offline   Reply With Quote
Old 05-22-2022, 09:04 AM   #7
Gary 70 Jimmy
Got it back in thanks for everones help.
Old 05-22-2022, 11:32 AM   #8
indymachinist
Great. Good thing you found it or you may have had a bad day on the road!
-Curt
