Old 10-30-2021, 10:37 AM   #301
Rickysnickers
Re: 1958 SWB C4 Fleetside - NZ Build
Nice!!
Old 10-31-2021, 09:57 AM   #302
57FleetsideC4
Very nice work!! Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054
57FleetsideC4 is offline   Reply With Quote
Old 11-07-2021, 11:00 PM   #303
QBRacing
Here is a YOUTUBE VIDEO which shows the deck and further explains the above bits
It also shows the
fuel breather and roll over valve,
Number plate lights, reverse lamp, number plate
Hood support braces
Under tray battery brackets
QBRacing is offline   Reply With Quote
Old 11-21-2021, 05:14 PM   #304
QBRacing
Speedway motors billet aluminium fuel trap door review.
So I bought one of these to finish of the bed of my fleetside because I think it looks awesome.....
I now think thats all it has going for it. Once fitted the actual usable opening is about 3.5" * 4" max and even my skinny mits have problems getting into the hole. Also, be prepared to mess with the spring catch which doesnt work half the time and be prepared to modify the bracket it fits to
Finish 10/10
Fit 4/10
Overall, 6/10
I made this quick VIDEO to explain more.
Old 12-13-2021, 01:16 PM   #305
QBRacing
I knew the rear toe and camber was bad but thought I could dial it out.... how wrong was I
With the C4 Corvette rear end when installed and at the ride height I wanted I had about 5 degrees rear camber once installed. I used the C4 rear camber adjustment but could only get it down to 3 degrees.
In NZ our modified vehicle rules state you can run 0.5 degrees more than factory or a max of 1.5 degrees. Oops. Guess I will need some adjustable rear arms to dial that out.
Also I noticed that the rear tie rod arm has bottomed out on the chassis and bent it to hell. Lucky it didn't break I guess. Anyways I have ordered the Flatout toe kit to fix this and recommend if you want to stay low that this is a must as the only other way to fix both issues is to raise the rear about 50mm and run some serious rake
VIDEO HERE which may explain it better.
Old 12-13-2021, 03:31 PM   #306
Rickysnickers
Seems kind of silly. What's the point of the rule/law?
Old 12-13-2021, 05:13 PM   #307
joedoh
joedoh's Avatar
might be like the USA, some states have the same law because of the onikyan cars that are popping up. the tire shop i visit has a pile of ruined low profile tires from the 15 degree camber imports.
joedoh is online now   Reply With Quote
Old 01-22-2022, 10:33 PM   #308
QBRacing
Re: 1958 SWB C4 Fleetside - NZ Build 90%
Well the rear end is now fully reassembled again and ready to be dropped on the rear wheels.
THIS VIDEO shows my newly made adjustable rear control arms and my newly bought Flatout Engineering rear adjustable toe kit.
The video doesn't show it installed but the final picture does.
Looks so good
Old 03-19-2022, 08:06 PM   #309
springm
Today's update comes courtesy of covid boredom
I splashed out and bought some Altman door catches which I air freighted in and even with all the lockdown rubbishbonly took 10 days to arrive. The courier even put them straight in the garage (contactless) which was great.
When I got home and was able to inspect the package I was immediately worried as the bix had suffered damage so to work I went.... and as expected the main support panels were both damaged. 1 easy fix, 1 not so much
Just wondering how you got on with compliance on the Altman latches? My compliance officer is looking for certification, which Altman don't have!
springm is offline   Reply With Quote
Old 04-13-2022, 05:57 PM   #310
QBRacing
@springm
When I took it for the cert check, other than door alignment issues, he never said anything about them but they were on my pre build which was approved by LVVTA ... so pass.
In regards to updates , whilst slow i have progress. I now have a 50sq meter (540sq ft) shed in the back yard with a 3m stud and a fully working clearfloor 2 post hoist .... yay...
I have also installed the LS6 valley plate so I could run the PCV system as required by the LVVTA cert process. I got lucky on that front as I happened to have the late LS1 block without the plug that interferes with the PCV block under the valley plate so there was no alloy shaving to get it to fit. With a small bend to the output pipe it nicely cleared the steam vent system I have too
now to fix the chassis flex and the steering column then I can get a recheck and hopefully on the road.
Old 04-13-2022, 06:15 PM   #311
QBRacing
Oh and like always I made a Video which explains it easier.
Enjoy
Q
Old 04-13-2022, 10:46 PM   #312
Rickysnickers
Nice shop.
Old 04-14-2022, 05:23 PM   #313
dsraven
always good to have a shop for YOUR stuff.
curious about the weight of the steam line set up. vibration may cause fracturing of the fitting at the head if the system is left hanging on that. it looks cool, just may be heavy.
Old 04-15-2022, 01:22 AM   #314
Patina56
Patina56's Avatar
I’ve been subscribed to your YouTube for a while and enjoy your videos. New shop looks great!
Patina56 is offline   Reply With Quote
Old 06-07-2022, 12:37 AM   #315
QBRacing
@ DSRaven
The steam lines dont normally sit up like that, I moved them to fit the LS6 valley cover.
I have since lowered them back down so they run flat along the valley cover now.
Old 06-07-2022, 01:33 AM   #316
QBRacing
So I just uploaded this Youtube Video showing the mods I did to the front A-Arm wing plates of the flatout front subframe. Don said that the later models already have something like this but I just went really overboard to make sure.
I basically tied the A-arm mounts to the box section to the chassis rail and think that should stop the flex I was getting that the certifier didnt like.
I have booked my next cert check and cant get in until the end of July now so that gives me about 6 weeks to fix the steering column. Plenty of time.
Here are some pics of the plates I had welded in.
Old 06-07-2022, 09:08 AM   #317
6DoF
6DoF's Avatar
BEEEEEFF, i liiike
6DoF is offline   Reply With Quote
Old 06-09-2022, 12:03 PM   #318
daveshilling
daveshilling's Avatar
Well this will be setting my project back now )= How can I NOT add these after hearing about the flex??
daveshilling is offline   Reply With Quote
Old 06-09-2022, 02:16 PM   #319
6DoF
6DoF's Avatar
finally had a chance to watch the vid ... i was really hoping for the certifiers flex vids.
Old 06-09-2022, 05:04 PM   #320
QBRacing
It has been on youtube for a while but was private while I discussed with Don.
As I said the later model systems come with it because the front plates are higher but given the shallow height of the earlier models (pre 88 i think it was) They werent deemed necessary till now.
Last I heard I think he was going to put the plates on all from now on but if not... i would do it
Here is the Flex Video from 1 min 40 on.
Please do NOT blame Don at flatout. For me he has been great to deal with, he supplied the kit and the suspension components and got them to a freight forwarder in LA for me to get all the way to NZ, nothing was broken, bent, missing and he has always been there when I called him (chassis length issue on earlier video). that said, I hope he fixes the issue moving forwards.
Please note : my fix required welding over the chassis number so make sure thats noted / photographed before hand. In my case I already had a NZ VIN attached so the stamped number is no longer required, TAKE PHOTOS ANYWAY....
Cheers
Q
Old 06-09-2022, 06:14 PM   #321
G&R's57GMC
G&R's57GMC's Avatar
Great fix .
I kind of questioned that single plate design when I saw it but figured it might be ok but still thought it should have more support .
Looks like your inspector thought the same thing and proved it . Nice catch .
I think you did a great fix and I hope Don at Flatout incorporates it in his design and offers the plates to previous customers .
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 06-09-2022, 09:39 PM   #322
Kevin_C
Great Video Q. I had to go back and look at mine. Im running the later 96 suspension and there appears to be extra bracing. That is some upgrade you made. I don't think you will have any issues now.
1955 chevy longbed shortened, C4 vette suspension front and rear with flatout kit. Gen V LT1/8L90
http://67-72chevytrucks.com/vboard/s...d.php?t=746958
Kevin_C is offline   Reply With Quote
Old 06-10-2022, 07:28 AM   #323
6DoF
6DoF's Avatar
wow, you weren't even really getting after it. imagine the flex if you were hammer down around a road track!
Any business that stands behind their work to help, even when you point out a flaw, deserve the business! it's a shame more don't, but it's great to find those who do. Good on Don and Flatout.
Old 06-11-2022, 05:43 PM   #324
daveshilling
I checked mine too, and I have the same bracing, fortunately, so I think I'll be leaving it as-is, although QB's bracing seems pretty bulletproof!
Old 06-11-2022, 11:13 PM   #325
G&R's57GMC
G&R's57GMC's Avatar
Hay Dave is your bracing the same as Kevin C’s ?
Glen & Jane's Rides
