Old 06-13-2022, 10:42 PM   #1
Gregski
Gregski's Avatar
Where to get Control Arm Seals?
I need both the upper and lower control arm rubber seals for my 1971 C10 2WD just the rubber seals. From what I have seen is places like Rock Auto want to sell you the whole kit with the shaft and the metal cups that screw in to either side. Your help is greatly appreciated
here's a link to MOOG upper https://www.moog-suspension-parts.com/moog-k6098
and here's MOOG lower https://www.moog-suspension-parts.com/moog-k6147
Gregski is offline   Reply With Quote
Old 06-13-2022, 10:45 PM   #2
Gregski
Gregski's Avatar
Re: Where to get Control Arm Seals?
Closest thing I found so far for the lower control arm bushings is this from Classic Parts but cups included:
https://www.classicparts.com/1963-72...ctinfo/74-323/
but they want $15 bucks each so that's $60 plus dollars for four of them and it's on 3 Week Back Order
Old 06-13-2022, 11:00 PM   #3
Gregski
Gregski's Avatar
Re: Where to get Control Arm Bushings?
LMC claims to have just the rubber seals for the upper control arms but their listing states: 2 WHEEL DRIVE 3/4 TON 67-72
https://www.lmctruck.com/1967-72-che...-2-wheel-drive
Old 06-14-2022, 07:01 AM   #4
Grumpy old man
Grumpy old man's Avatar
Just spend the $60. and buy them ,Think of it this way with all the cash you have falling out of your pockets from not buying $7.00 a gallon gas for your electric truck you'll be way ahead !
Sorry , I had too !
Old 06-14-2022, 08:31 AM   #5
67C10Step
67C10Step's Avatar
I don't see an easy way out here. Moog kits with the cross shafts and bushings are just over $30 on RockAuto so it's the same price but you get the cross shaft as well.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 06-14-2022, 09:40 AM   #6
72SB
I just replaced shafts and bushings, IMHO the way to go
72SB is offline   Reply With Quote
Old 06-14-2022, 12:05 PM   #7
Gregski
Gregski's Avatar
thanks, what rubber friendly grease do you recommend to make these go on easier and prevent them from squeaking later?
Old 06-14-2022, 01:34 PM   #8
72SB
The bushing material is a rubber like (not polly) so I just use regular grease I lube all my zerk fitting stuff with that is not poly.
Green grease would also be fine is you are concerned about Petro based grease. Sold at most auto part stores. I use green grease on my poly suspension stuff on other cars
Old 06-14-2022, 02:07 PM   #9
LNP
Originally Posted by grumpy old man View Post
just spend the $60. And buy them ,think of it this way with all the cash you have falling out of your pockets from not buying $7.00 a gallon gas for your electric truck you'll be way ahead !
Sorry , i had too !
lmao
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 06-14-2022, 06:15 PM   #10
pjmoreland
pjmoreland's Avatar
Is this possibly what you are looking for? The description reads right, but the photo looks like the upper seal.
https://www.classicparts.com/mobile/...ctinfo/74-324/
pjmoreland is offline   Reply With Quote
Old 06-15-2022, 08:52 AM   #11
cwcarpenter98
cwcarpenter98's Avatar
The rubber pieces in the 63-72 control arm shafts are not bushings. They are just for keeping dust and dirt out of the threads. The steel caps that screw on to the shaft is doing the "bushing" activity. Use plenty of the grease that you would use on your steering joints.
The swuarebody control arm shafts do use a rubber bushing, but the shaft is different than the older ones to account for the rubber bushing.
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 06-16-2022, 12:04 PM   #12
Gregski
Gregski's Avatar
wow, perfect, great find thank you so much, and yeah their website is jacked, anyway I emailed their customer support and am working with Angie to straighten things out
well they claim this indeed is the lower control arm seal and it's just a new look/design so we shall see
Old 06-16-2022, 12:32 PM   #13
Gregski
Gregski's Avatar
ok I think these are the right upper control arm seals
https://www.classicparts.com/1963-72...ctinfo/74-308/
Old 06-22-2022, 11:03 AM   #14
Gregski
Gregski's Avatar
so both upper and lower control arm seals showed up today from Classic Parts and they seem hefty and pretty nice, we shall see how they fits
Old 06-22-2022, 11:05 AM   #15
Gregski
Gregski's Avatar
and here's how the Classic Parts uppers compare to the flimzy junk LMC tries to pass on as their uppers
Old 06-22-2022, 11:27 AM   #16
LNP
Wow huge difference. Post pics of where they actually go too and how they fit will ya?
Harley
Old 06-22-2022, 11:34 AM   #17
Gregski
Gregski's Avatar
careful what you ask for, ha ha, excruciating detail on my build thread can be found here starting at post #664
https://67-72chevytrucks.com/vboard/...826089&page=17
Old 06-22-2022, 11:35 AM   #18
67C10Step
67C10Step's Avatar
Just to be clear, what I am seeing in your photos are not bushings. They are dust sheilds/seals for the bushing and cross shaft. The actual bushing is the large metal piece that looks like a nut on both ends of the cross shaft.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 06-22-2022, 11:36 AM   #19
Gregski
Gregski's Avatar
now I'm just showing off, but these are not new, I cleaned and powder coated these
Old 06-22-2022, 11:37 AM   #20
Gregski
Gregski's Avatar
yes, sorry, you are 100% correct! I come from the Squarebody world, please forgive me
Old 06-22-2022, 11:43 AM   #21
67C10Step
67C10Step's Avatar
No worries. Just didn’t want you to have some misplaced expectations if your bushing have slack in them.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 06-22-2022, 11:45 AM   #22
LNP
Thats the way I am seeing it too. I thought the bushing was the metal threaded peice on each end making those more of a seal for the bushing to hold in grease and keep out everything else. I get it why everyone calls them bushings as thats what the retailers calls them.
Thanks Gregski for the photos. I see now lookin at my truck I need those as well as I do not see them.
Harley
Old 06-22-2022, 11:47 AM   #23
Gregski
Gregski's Avatar
BINGO, it's like that whole give me a starter relay instead of a starter solenoid thingie when talking to an AutoZoner! kapish?
Old 06-22-2022, 11:49 AM   #24
Gregski
Gregski's Avatar
Oh wow! in that case I would highly recommend you give them zirc fittings a shot of grease pronto just to be sure there is still some in them cups, until you get around to putting the rubbers back on, assuming you are driving that rig around still
Old 06-22-2022, 12:13 PM   #25
LNP
I am driving it yes. I just greased them Sunday. I got the truck just over three years ago and have been drivin it for just over two years now. Thanks to everyone on here I have learned a lot about my truck in a hurry. I was a grease monkey for 30yrs so I knew how to do the work but what goes where correctly and all the cool tips tricks and hints along with how toos really made workin on my truck easier and enjoyable. I gotta take it to get aligned and according to how that goes will decide if I change them now or later. Thanks again
Harley
