Old 06-20-2022, 11:56 PM   #676
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Lost My 65
She was so beautiful when I bought her in 82.
Then, the teenager I was, treated her badly and totaled her.
When I rebuilt her, I rebuilt her as a shortbed stepside on the 62 frame.
Here is the only picture I have of her - after I wrecked her. We used to go mudding a lot.
Anyway, she was originally a longbed fleetside.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 06-21-2022, 01:19 AM   #677
Braunschweiger
Re: Lost My 65
You only learn to appreciate things when you're older, they'll have a lot of fun with the truck again, but they won't do the really wild things anymore.
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is offline   Reply With Quote
Old 06-22-2022, 10:11 PM   #678
LostMy65
LostMy65's Avatar
Re: Lost My 65
Been working on the alignment.
Took her for another spin today.
Shimmys at about 45 mph but goes away at around 55.
Going to keep working on the alignment using this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=399479
Also going to try a different set of wheels and replace the idler arm.
I want to get her driving safely before reinstalling the body panels.
Old 06-22-2022, 10:20 PM   #679
cwcarpenter98
cwcarpenter98's Avatar
Re: Lost My 65
The weight from the panels will affect your alignment numbers just a smidge. Might not be enough to notice, but I would want all the usual weight on the truck before getting that final alignment dialed in. I bet people give you some funky looks for driving around like that
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 06-23-2022, 01:12 AM   #680
LostMy65
LostMy65's Avatar
Re: Lost My 65
Maybe I'll put a couple sacks of concrete on the inner fenders - one on each side. Just kidding..
I do like the easy access like I have it.
Old 06-23-2022, 02:27 AM   #681
350TacoZilla
Re: Lost My 65
I like the long bed transition man it looks good so far. I started out looking for a short bed stepside to try and get as close as I could to a truck my parents had bought years ago to use as a play toy and run around but after looking and finding a 3\4t long step I kinda came to the conclusion that the long bed would probably serve me better as an all around truck. Sometimes plans change for the better and it can always be put on a short bed chassis down the rd or even shorten the 3\4 chassis like some do to get the short bed.
350TacoZilla is offline   Reply With Quote
Old 06-28-2022, 09:08 PM   #682
LostMy65
LostMy65's Avatar
Re: Lost My 65
Working on my front steering linkage and ordered a new Moog idler arm.
I guess I forgot I used the 66 idler arm support bracket.
I could just order a 66 3/4 ton idler arm that has the bend, but I'm going to just switch out the bracket to the 73-87 so I keep the whole suspension as 73-87 - rather than having some 66 parts and some 73-87.
The 73-87 idler arm bracket hangs down lower than the 66s.
Old 06-28-2022, 09:18 PM   #683
LostMy65
LostMy65's Avatar
Re: Lost My 65
I went back and found the posts when I upgraded to power steering when my 65 was on the 62 frame.
You can see the difference between the 66 and the 73-87 idler arm support bracket.
Old 06-28-2022, 10:45 PM   #684
LostMy65
LostMy65's Avatar
Re: Lost My 65
And here is the new 73-87 idler arm next to the 66.
I just need determine what the difference in drop is so I know what height to set the 73-87 bracket at.
Old 06-28-2022, 10:52 PM   #685
SkinnyG
SkinnyG's Avatar
Re: Lost My 65
Just make sure the center link is horizontal.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is online now   Reply With Quote
Old 06-28-2022, 11:03 PM   #686
LostMy65
LostMy65's Avatar
Re: Lost My 65
Another I just remembered from doing it before is to keep the draglink level and parallel with the front crossmember.
Old 06-28-2022, 11:04 PM   #687
LostMy65
LostMy65's Avatar
Re: Lost My 65
Yep, I just remembered that.
I missed your post.
Old 06-29-2022, 03:02 PM   #688
LostMy65
LostMy65's Avatar
Re: Lost My 65
As I guessed, everything aligns with the original, I just need to raise it some to get the draglink level.
Old 06-29-2022, 08:44 PM   #689
LostMy65
LostMy65's Avatar
Re: Lost My 65
Well it still wobbles.
I'm going to try changing the wheels.
Also, it pulls to one side when I hit the brakes, and then jerks back the other way when I let off the brakes.
They are power disc brakes.
I could understand if they were drums and I needed to adjust the shoes, but I don't know what to adjust with the discs.
Old 06-29-2022, 09:03 PM   #690
LostMy65
LostMy65's Avatar
Re: Lost My 65
Found this for it pulling while braking:
Originally Posted by CUSTOM/10 View Post
If it pulls right when braking I would check the left front calipar. It might be frozen and not working causing the truck to pull towards the side that is working.
Gary
Another said if the left hose is collapsed, then it pulls to right when braking with disc brakes.
Old 06-29-2022, 09:16 PM   #691
SkinnyG
SkinnyG's Avatar
Re: Lost My 65
And a caster imbalance can cause a pull under braking too.
Old 06-30-2022, 01:47 AM   #692
LostMy65
LostMy65's Avatar
Re: Lost My 65
I guess the confusing part is it didn't drive like this before. Definitely no wobble.
I'll keep trying things. If changing the wheels gets rid of the wobble, then I'll feel like I'm making some progress.
But hey, it starts and runs nice.
Old 07-17-2022, 10:55 PM   #693
LostMy65
LostMy65's Avatar
Re: Lost My 65
Changing the wheels didn't change things one bit. I'm taking a break on this for awhile, but I'm thinking now it may be the front wheel bearings. I'll hopefully have time this next weekend to look.
Old 11-24-2022, 07:29 PM   #694
LostMy65
LostMy65's Avatar
Re: Lost My 65
Went to take my truck for a drive after several months.
I thought wow, how good the brakes were.
I forgot I put a booster behind my drum master cylinder.
Old 11-28-2022, 12:23 PM   #695
pdxhall
pdxhall's Avatar
Re: Lost My 65
Did you get the front end wobble solved?
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 11-29-2022, 12:15 AM   #696
LostMy65
LostMy65's Avatar
Re: Lost My 65
I guess I forgot to give an update about that.
I got a little tired of trying to figure it out, so I put everything back on the 62 frame. I don't like my 65 becoming unusable for too long. I'll probably give it another try next summer. I'm less tolerant of Portland's cold weather as I get older. I need a heated shop.
Old 11-29-2022, 01:09 PM   #697
pdxhall
pdxhall's Avatar
Re: Lost My 65
I understand the weather thing. I spent too many years dealing with that. I'm glad I got away even though I'll always have a connection to the NW.
Sanity'66
