Old 07-10-2022, 05:22 PM   #2976
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: What did you do to your truck today.The 3rd chapter
Lookin' good! Now, go put a scuff mark on it before someone else does!
~Steven
Simi Valley, CA
Old 07-10-2022, 06:42 PM   #2977
67C10Step
67C10Step's Avatar
Spent about an hour a night for the past week and a half fixing the two lower corners of my windshield so I can get the glass installed. Took advantage of the opportunity and repainted the top of my dash. Shade is just a bit darker than the fawn interior. Also cleaned up the entire pinch weld area, primed, and painted with a flat black since the glass seal will cover pretty much all of it. Cleaning all the old goop off it went to the metal in a lot of places and I didn't want to leave it that way.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 07-10-2022, 07:45 PM   #2978
Steeveedee
Who Changed This?
Steeveedee's Avatar
Youngest bro and I (mostly him) made two replacement springs for my truck seat. I'll paint the seat tracks tomorrow, and install them onto the seat bottom and dope out how the release works...or just leave it all the way back. Short stuff wife can't drive it that way though.
~Steven
Simi Valley, CA
Old 07-10-2022, 07:48 PM   #2979
NoStopN
NoStopN's Avatar
Originally Posted by countr View Post
Installed my bumper. (finally)
Was that one you had laying around, NOS, or repop from a parts company?
1969 GMC 2500. 250 I6, 4-speed w/ granny low
NoStopN is offline   Reply With Quote
Old 07-10-2022, 08:01 PM   #2980
countr
countr's Avatar
Original, Not NOS. Repainted, Very heavy and i can not believe the weld that went all across the top. A lot of skill.
Got the Bumper from Iron Mike.
Thanks Russ
countr is offline   Reply With Quote
Old 07-10-2022, 09:44 PM   #2981
pjmoreland
pjmoreland's Avatar
That looks so tidy. It's got to feel good knowing that rust will no longer be lurking under the seal.
I'm planning on installing a quick ratio steering gearbox. While I'm at it, I'm going to replace my current one piece decapitator steering shaft with a newer two-piece style with an intermediate shaft. Will improve safety, and will make removing and installing the column easier. I cleaned up and painted an intermediate shaft I bought from Jeff's Bowties.
pjmoreland is offline   Reply With Quote
Old 07-10-2022, 10:24 PM   #2982
Orange Crate
Orange Crate's Avatar
The only thing I did was install an NV4500 and a 6 bolt round pattern twin stick NP205.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...
Orange Crate is offline   Reply With Quote
Old 07-11-2022, 09:51 AM   #2983
67C10Step
67C10Step's Avatar
Thank you. I am really no fabricator but my wife confuses my stubbornness for patience. I actually purchased a spot sand blaster so I didn't have to use my bigger blaster to get the metal as clean as I could. It still made a big enough mess. Digging out and blasting out old seam sealer was really fun.
I have a steering box, pump, and bracket from a 73-74 model truck and think swapping to power steering will be a winter project this year. Just gotta figure out which bottom pulley I need for my 283.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 07-11-2022, 09:20 PM   #2984
FL71C10
Got my windshield washers working and put the cowl back on with the wipers all together. Got my helper with me tonight.
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 07-12-2022, 12:46 AM   #2985
BLP1969
I received a new brake line kit and got it ready to install them on the truck, but noticed something that I need to address. The studs from the brake pedal assembly are getting very corroded, and need replaced. Where can I buy a new brake pedal assembly? All that I can find are just the brake pedal lever, but not the mounting bracket. Thank you for any assistance that you can provide.
BLP1969 is offline   Reply With Quote
Old 07-12-2022, 09:50 AM   #2986
FL71C10
I would think that is something you could buy used on the Forum here. You could post a want to buy in the parts for sale section
Old 07-12-2022, 11:08 AM   #2987
KW5413
KW5413's Avatar
What did I do with my truck, today? I stood there and looked at it wishing it wasn't so damned hot. Day after day it has been in triple digits with heat indexes over 110. This heatwave is unusual, even for us, this time of year. Some cars shows are being cancelled or, times being moved to earlier AM or later PM.
KW5413 is offline   Reply With Quote
Old 07-12-2022, 11:24 AM   #2988
LNP
https://www.classicparts.com/1969-74...tinfo/CP-2032/
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 07-13-2022, 04:52 PM   #2989
67C10Step
67C10Step's Avatar
New glass!!!! Truck is filthy but the glass is in at least.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 07-13-2022, 09:45 PM   #2990
Steeveedee
Who Changed This?
Steeveedee's Avatar
Got the seat backrest done. I'm trying to figure out how to compress that foam so that I can pull the cover over it and put in the hog rings on the bottom part. I wonder if they use some sort of squeeze machine in the upholstery shop? I need about 5" of "stretch" to get the cover to the back side attachment wires. My brother says to start at the back. Given that I'm not an upholsterer, I'm tempted to ask for mercy at a local shop.
~Steven
Simi Valley, CA
Old 07-14-2022, 03:06 PM   #2991
72c20customcamper
72c20customcamper's Avatar
New clutch fan . Old one wasn’t doing a damn thing . Truck is running normal temps again at lower speeds . Highway wasn’t a problem as the fan doesn’t do at that much at 70mph
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 07-15-2022, 10:11 AM   #2992
tdangle
tdangle's Avatar
I believe somewhere I saw that they put the foam in a big plastic bag and used a vacuum to squeeze it down put the cover over and then removed the bag. I think they used powder to ease the removal. Pretty sure this was for bucket seats, but maybe you could figure something our similar
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 07-17-2022, 05:47 PM   #2993
72c20customcamper
Finally made some time for the 68 Stepper . I think they greased this truck every month . The grease and South Carolina red dirt was caked at least an inch thick on everything . When I started there was no lip on the control arm .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-17-2022, 08:04 PM   #2994
Jiggers72-GMC
Jiggers72-GMC's Avatar
Right on Mark, when I got my old Chevy the valve cover gaskets were leaking so bad it saved things from rusting out, either way it's all good......
Gerry, North Bay Ontario
1971 Chevy K10 short stepper, 518 med green & white
1972 GMC C1500 long box, dark Brown, owned since 1977
1969 GMC C2500 manual
Jiggers72-GMC is offline   Reply With Quote
Old 07-19-2022, 06:07 PM   #2995
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Got the new engine primed and almost ready to fire up.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 07-20-2022, 03:47 PM   #2996
crazyjeenyus
crazyjeenyus's Avatar
Dropped it off at the fab shop as a lwb. Hopefully picking it ip as a swb in a couple weeks.
crazyjeenyus is offline   Reply With Quote
Old 07-20-2022, 08:05 PM   #2997
jaros44sr
jaros44sr's Avatar
luv a sbc, nice work on smoothing out the exhaust manifolds
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 07-21-2022, 04:16 PM   #2998
67C10Step
67C10Step's Avatar
Ordered new wiper blades and a washer bottle/pump for a mid 90's S10 with the intentions of getting the wiper/washers functional when it gets cool enough to work in the shop. Also working on stereo system. Maybe end of September.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 07-23-2022, 10:54 PM   #2999
allchevy58
allchevy58's Avatar
Bought another set of NOS upper trim to get the one I needed for the bed, installed Wednesday. Today I replaced mufflers and tailpipes.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 07-24-2022, 09:34 AM   #3000
LNP
Wow you got your own exhaust pipe bender. Nice!
Harley
