Old 02-20-2021, 04:39 AM   #26
ChevyRacefan
ChevyRacefan's Avatar
Re: Changing from a Low Hump to a High Hump
Book marking just for the vendor info.
I will be adding holes in the firewall, and add plugs, while there to get to the upper bolts of the transmission bell housing. So if the Transmission needs to be pulled ) in my case most likely will be in and out a bunch) It just be a matter of pull the 4 grommit plugs . and socket and ex. to get to the bolts. Getting to them when vehicles are on stands is a pain. this will make it simple. and might as well add them while there adding the hump.
Making swapping/testing converters at the track a lot easier.
ChevyRacefan is offline   Reply With Quote
Old 02-20-2021, 12:58 PM   #27
Gary 70 Jimmy
Gary 70 Jimmy's Avatar
Good information I will be cutting mine out to.
1972 GMC Jimmy 1/2 4X4 4wheel camper
1970 GMC Jimmy 1/2 4X4 350
1969 Chevy Blazer 1/2 4X4 307
1967 chevy LWB 3/4 396
Gary 70 Jimmy is offline   Reply With Quote
Old 08-01-2022, 01:00 PM   #28
3757chevy
3757chevy's Avatar
Originally Posted by 3757chevy View Post
QUOTE:
Re: 72 one piece high hump cab floor
The big blocks with turbo 400 were high hump. The small blocks with th400 were low hump.:Quote......................................................................................... .................................................................................................... .................................................................................................... ........................... I stand corrected.
I bought a '68 Suburban last June 327 w/TH400 and a low hump.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 08-01-2022, 01:36 PM   #29
kwmech
Which begs the question--- if that is true-- WHY?? the placement of the big block engine moves the transmission forward 1-1/2'' giving more room around the hump. My 69 1 ton originally had a 350. I converted to a 454 and had to move the trans x-member and linkage pivot forward. Still a low hump with more clearance. I can get my fat hand all around the trans case
kwmech is online now   Reply With Quote
Old 08-01-2022, 04:10 PM   #30
CC69Rat
CC69Rat's Avatar
Just noticed this one, I know it's an older post but just adding to Dads comments.
This truck had quite a few modifications to the Kmember, engine mounts, etc. It was done before I bought it. The engine had been moved back from the factory location (Big Block, or small block) to help keep it from plowing in the corners. With the BBC setup it was done this way to keep it from being nose heavy. It definitely wasn't in the stock Fore/ Aft position.
I understand it can be done with a low hump. Just saying, in this truck, in this position we had to do a high hump to get it to clear.
Just wanted to clarify. Pop was really just trying to document how it's done, where to cut, how we did it, etc. Not saying you need a high hump if you have a TH400.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 08-01-2022, 04:19 PM   #31
CC69Rat
CC69Rat's Avatar
Originally Posted by kwmech View Post
... the STOCK placement of the big block engine moves the transmission forward 1-1/2'' giving more room around the hump. .. This truck wasnt in the stock mount position.
Chad
Old 08-01-2022, 05:28 PM   #32
kwmech
Originally Posted by CC69Rat View Post
Either way there is still clearance for the automatic. SM465 4 speed, with or without t-case......nope
Old 08-02-2022, 07:31 PM   #33
georgieb51
georgieb51's Avatar
Originally Posted by gmc684x4 View Post
My understanding trucks with t400 came factory with high hump
I did this on my 68 gmc when i went from 2x4 to 4x4 there is a spot welded ring that is below the floor pan for use of bolts not sheetmetal screws to secure high hump pan
Maybe this is getting a little off track but since you brought it up I will report that my 1970 GMC2500 3/4 came stock with the TH400 and a low hump. I had to double check since I recently purchased carpet and had to get the hump right
1972 Chevy Custom Deluxe Highlander, owned 34 years.
1970 GMC Sierra Grande 2500, unrestored, original.
1970 Chevy K10 Short Wide-bed, working on restoration..
1967 Chevy K10 Short Stepside, unrestored original.
1969 GMC CST (Longhorn) 396, buckets, unrestored.
1995 GMC K2500, 65,000 miles, 454.
georgieb51 is offline   Reply With Quote
Old 08-03-2022, 10:25 PM   #34
Mike C
Mike C's Avatar
I have a ‘69 C2500 parts truck with a first year small block 350 and TH400 and its a high hump. All the big block trucks I have owned have been high hump. Same with SM465.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
