Old 08-21-2022, 01:33 PM   #1
ImCallingHerShirley
Mystery part????
Just pulled the seat out of my 72 c10 and found this thing…absolutely no clue what it is. It had these foam pipe protectors on it and it’s painted silver but the rods themselves are definitely about as old as the truck. (approx 3/8” rod, 29.5” straight section and from the pivot bolt up, the bent sections measure 19”-8”-4”)
Any ideas or suggestions would be greatly appreciated!
ImCallingHerShirley is offline   Reply With Quote
Old 08-21-2022, 01:33 PM   #2
CG
BlahBlahBlah
Re: Mystery part????
Jack handle for turning the jack up and down
Here is a pic I have saved of one in a Burb
Old 08-21-2022, 04:23 PM   #3
ImCallingHerShirley
Awesome! Thank you for the quick response.
Old 08-22-2022, 01:32 PM   #4
Custom 68
Custom 68's Avatar
a lot of folks would put the foam on them to keep them from rattling. Mine had some very old heater hose or something of the sort.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 08-22-2022, 03:32 PM   #5
Fizoust
I have one of those, couldnt figure out what it was, Thanks!
Fizoust is offline   Reply With Quote
1972, 72 c10, c10, cab, parts
