#301 |
Re: "Sweet Pea" 1975 Cheyenne 20
Just a heads up, DD wants a dedicated ground for the fuel level sender to the control box. It’s shown in the instructions and all 3 DD gauges I have installed required it for accurate gauge reading.
Your going to love those gauges.
‘53 GMC COE stock ‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘ '70 Chevy C10 LWB 350/sm465 ‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
#302 | |
![]() Join Date: Apr 2018
Just read that some of the early "LS" swap PCMs do not supply oil pressure readings... Great. I wonder if thats what I have.
"Sweet Pea" 1975 Cheyenne 20 http://67-72chevytrucks.com/vboard/s...00#post8477900 "Bourbon" 1975 Suburban ScottsdaleSOLD https://67-72chevytrucks.com/vboard/...49#post8769049 ”Otis” 1970 C10 SWB -SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=762766 ”Chebby” 1962 Impala LS/TKO-500 http://www.pro-touring.com/threads/1...2-Impala-Build |
#303 |
That’s probably your issue. If your oil pressure sensor is a one wire unit, the ecm doesn’t read it. I had to use the DD sensor in my 74. Just used the port above the oil filter.
#304 | |
#305 |
I got the gauges all wired in and tucked away, they look fantastic! So stoked on the outcome. I'll take some pics at night too, they look great with the back lighting.
However, on a test drive I found my fans aren't kicking on. Grr... They've worked before. Now they aren't kicking on. Tuner says they're programmed to come on at 196 and 204 (respectively) I did the 5 minute check up (fuses, ground, wiring) and its all kosher. Not sure how to check a relay, but everything looks tidy and right. Im baffled. Any suggestions? I have a show coming up over labor day weekend... if I cant get it figured out by then I'm just going to wire them to a switch.
#306 |
I'm no photographer, but here they are...
#307 |
I drove her to work today, 40 miles, mostly freeway. This was the first commute since the swap. She drove like a dream! 70-75 at 2300 rpm. Cruised right along. Stayed nice and cool, no weird shakes, noises, problems. From pulling the motor on Jan 1 to commuting to work worry free on 8/24. Quite the process! I'm sure there will be some things I iron out as I go, but its safe to say she's a runner! Thanks for all the help from everyone who has pitched in along the way.
#308 |
Did you get the fans sorted out?
#309 |
Not entirely. I’ve got them running on a switch right now, which works fine… but I’d like to have them running as they’re meant to.
#310 |
Been away for a bit, but Sweet Pea is running strong as ever. Lots of use as a daily driver, firewood hauler and all around pickem up truck. Ive got some pics from the C10 Intervention show back in Sept, So i'll upload em now.
The lineup! ![]() ![]() ![]() ![]()
#311 |
And now a few pics of her less fancy daily life
#312 |
![]() Join Date: Dec 2009
Nice.
#313 |
![]() ![]() Join Date: Aug 2013
Well done.....
#314 |
Just here to tinker
![]() Join Date: Jun 2008
Beautiful work my friend!
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
#315 |
![]() Join Date: Jun 2019
Looking good as always! Nice to have a 3/4ton, when you want to carry a load!
http://67-72chevytrucks.com/vboard/s...d.php?t=791250 |
#316 |
I've been dealing with the sticky steering wheel for years, and finally decided I'd had enough. I found this NOS Truckline Sport Grip wheel cover on ebay a while back. Finally got around to installing it. I love it. Such a period correct, old school feel. I swear my dad had one of these on every truck we owned when I was a kid. No more sticky fingers, and it looks pretty dang cool in my opinion. Love the original box and hand drawn instructions.
#317 |
BlahBlahBlah
Love the steering wheel cover, Ive put a lot of those on over the years. Didn't think there were any out there anymore. Id like a black one, Ill have to have my brother check E bay for me.
#318 |
As far as the sticky steering wheel goes...I have been doing some research and apparently the way to solve it, is you apply some Oxi Clean to the plastic parts and it neutralizes the degradation of the plastics in the steering wheel.
I have NOT done this to mine yet. Test in a small area to start! Mine needs it too!
#319 |
Hmmm.
Funny how some do it and others don't. My '86 is sticky in damp weather but my '84 which has an '85 wheel is never sticky. |
#320 |
chevy truck fan
i like the steering wheel cover... reminds me of my 'ol '79 big10 which had one when i took over driving duties from my dad. gauge question: did you have any issues with the fuel gauge? if not would you be willing to share how you hooked it up? I am having issues with it reading in mine.
thanks!! |
#321 | |
#322 |
chevy truck fan
shorthaul. thanks for the reply, I thought i had it wired according to DD instructions as well, but to no avail... I checked cont. between each ends of the fuel gauge wire from the dash end to the selector switch (dual tanks) it is good there. I guess I am confused on the grounding issue? i have '87 tanks & '87 sending units. the gauge shoots to full at start up
anyways... nice job n the dash ![]() |
#323 | |
#324 |
chevy truck fan
shorthaul, thanks again for the reply. I think I will start a seperate thread (don't want to hi-jack you) the truck looks cool & looking foward to more updates....
#325 |
No worries, thanks and good luck sorting it out. I’m sure you’ll get it dialed in. Don’t be afraid to call Dakota Digital directly.
