12-06-2020, 05:24 PM | #26 |
Re: Has anyone cut the lens off from a sealed beam headlight?
You can buy the harness from various vendors, or you can make your own. The wiring isn't really difficult.
The idea is that instead of running the amperage for the headlights through the switch, you control the relays with the switch. Full amperage runs through the relay to the headlights. It preserves the switch and gives full voltage and amperage to the headlights, resulting in a brighter light.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
12-06-2020, 06:19 PM | #27 | |
1972 Chevy Custom Deluxe Highlander, owned 34 years. 1970 GMC Sierra Grande 2500, unrestored, original. 1970 Chevy K10 Short Wide-bed, working on restoration.. 1967 Chevy K10 Short Stepside, unrestored original. 1969 GMC CST (Longhorn) 396, buckets, unrestored. 1995 GMC K2500, 65,000 miles, 454. |
12-06-2020, 06:23 PM | #28 | |
Link:https://www.jalopyjournal.com/forum/...ights.1209713/ .
12-06-2020, 07:05 PM | #29 |
Who Changed This?
My FiL did that. I don't know if it got hit, or what. I'd like to go back to the original, someday.
12-07-2020, 12:13 AM | #30 |
When I do this I'll do the 1st one comple and compare it to the others before I o them all. I know it's probably illegal and I will check the glare before I drive with them. If they glare bad they will just become art pieces I guess.
12-07-2020, 04:19 PM | #31 |
I have researched led bulbs a bit and I came across these. I may contact these ppl once I have my bulbs done. They seem very knowledgeable. The led they are displaying here is moveable so that may help me in this situation. https://youtu.be/IWDjFQuT7Gs
04-21-2022, 09:40 PM | #32 |
Well tonight I split 2 of my t3 bulbs. 1 high and 1 low beam. Here are some pictures. I am waiting for my h4 housings to come in and I will do more then. I am just doing this for experimental purposes. I understand this is illegal and I would not use these if the beam pattern is harmful to oncoming traffic (which I will try to test with a few different bulbs
04-21-2022, 10:30 PM | #33 |
20' Daredevil (Ret)
Good to see an update.... and with successful lens removals! As to legality, IF glare is not an issue, I wouldn't worry about it. Technically, some E-code conversions are not DOT-approved, but properly adjusted they don't raise any eyebrows. I have run them in various vehicles, in several states, since the early Seventies and have never had an issue.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
04-21-2022, 10:47 PM | #34 |
Cool
Great Progress. I passed a J E E P that had lights that was not legal yesterday. I want to find my Q-Beam for Tomorow morning.
04-27-2022, 10:52 AM | #35 |
So I have to wonder how these lenses would look on Holley's new retro bright LEDs, I know it's a dumb idea but it makes a fella wonder
05-04-2022, 06:08 PM | #36 |
Here are brights and dims with the hella h4 glass. 1st with the morimoto 3.0 headlights and second with the hella bulbs thar came with the lenses
05-04-2022, 06:13 PM | #37 |
And the results with the t3 lens on the h4 back. 1st with morimoto 3.0 and second with the hella bulbs. Bulb is about 8 feet from my garage doors and this is only 1 single bulb. All are low beam picture first
05-04-2022, 06:15 PM | #38 |
Do you have to glue [or epoxy] the lens back on? Or does the stainless steel retaining ring hold it together?
05-04-2022, 06:24 PM | #39 |
This is what I used
05-04-2022, 06:35 PM | #40 |
That'll work.
05-05-2022, 12:17 AM | #41 |
Night shots. the cut off line actually isnt too bad with these morimoto 3.0 bulbs. This is only 1 bulb . On a vehicle it would be easier to aim. Low beam is the st picture
05-05-2022, 02:39 AM | #42 |
Is that snow, or sand, or black asphalt but looks white bc the light's so bright?
05-05-2022, 10:15 AM | #43 |
It's just dry dirt from my back alley.
05-05-2022, 10:19 AM | #44 |
This pic creeps me out . Looks like a skull
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
05-05-2022, 03:45 PM | #45 |
At the body shop.
My old cibie lights fell apart.
Put hella h4 in their place. Pretty neat taking a T3 apart and replacing with a H4
" That didnt make it any newer " " Dont antique the equipment " |
05-15-2022, 12:05 AM | #46 |
I did a tweek to the piece that blocks the light on the led light and it got rid of that line on on the low beam and I'm extremely happy about that. And I did a comparison to the original t3 an the pattern is very close to the same as I expected. Here is a picture of the bulbs in the same spot on low beam. 1st is original bulb. The led is much brighter and wider pattern.
10-02-2022, 10:32 PM | #47 |
In case anyone ever needs this info here this is what all 4 look like in the rad support. They look A little better in real life than the pictures show
10-03-2022, 01:15 AM | #48 |
Four Eyes rules the night.
