12-27-2015, 09:33 PM | #301 |
Re: My crewcab 4x4 cummins project
And now all sanded down flattened out ready for colour number two and a complete reclear...
86 gmc short box..461bbc/th400 12.95@106mph 85 gmc crew cab 4x4 8"lift cummins conversion |
12-28-2015, 01:53 AM | #302 |
Looks awesome. Can't wait to see the whole thing done. Keep it up.
1987 GMC R2500 SC 454 T400 1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors |
01-25-2016, 07:45 PM | #303 |
Back to work spraying... Got the bed, fenders, and flares done n I just had to set a flare on n look ... It's much brighter in the sun when the dark brown comes alive... Kinda keeps the 80s classy vibe... Way out side the box for me since I've only painted things black
Had some issues first thing on the doors this morning so hopefully get that fixed up...
02-02-2016, 11:47 AM | #304 |
Starting to get a few things put together
02-02-2016, 12:07 PM | #305 |
Looking good. It looks like it has a little Fall Guy truck vibe. Very cool
02-02-2016, 12:10 PM | #306 | |
That's funny the guys shop where I sprayed it said the same thing lol
02-02-2016, 01:32 PM | #307 |
Reminds me of the iron man suit
02-23-2016, 08:36 PM | #308 |
Getting a little bit more done... Front end getting fitted back on... Need to build my permanent body mounts once I get the box set back on. Started putting in the carpet had to set a seat in and the shifter and make truck noises for a good hour, it's been a long time coming finally getting excited to see it all coming together. Getting some wiring done on it and a few other odds n ends
02-23-2016, 09:55 PM | #309 |
6>8 Plugless........
It's coming together very nice! Great work!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
02-26-2016, 02:45 AM | #310 |
glad to see our economy hasnt derailed this project like most others.
Nice choice on the two tone. I rarely like two tone, but thats nice
1989 3+3 2wd Dually. 454 BB. Factory loaded for the day, including Alcoa rims. |
02-26-2016, 08:42 AM | #311 |
Things have slowed down for sure but after having the truck as long as I've had Ive picked up bits and pieces along the way so I have quite a few things to do... It won't be on the road for the summer that's for sure... Unless something happens and it gets somewhat busy again in the oil and gas industry
05-12-2016, 10:19 PM | #312 |
Been a while since updated... Got all the glass in except the rear window, did a spray in bed liner and undercoated bottom of the box and inside box sides, picked up a set of wheels for cheap to use with My scrap 40s I had so I can size up building steps and bumpers... Again...
05-12-2016, 10:22 PM | #313 |
Start of the last front bumper I'm going to build for this truck get it all tacked together then pull it off and tig it all up
05-12-2016, 10:33 PM | #314 |
I'm liking the bumper so far. The truck is looking good all put together and on 40's.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
05-12-2016, 10:55 PM | #315 |
Looking real good. I like the colors.
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
05-13-2016, 03:42 PM | #316 |
Very nice work!
09-13-2016, 05:38 PM | #317 |
We'll i have been picking at the truck a little bit again. sold my motor cycle so of course dump the money back into the truck. got most of the fuel lines done just waiting on a couple fittings, got the bumper mostly welded up, rear drive shaft done, new alternator, ac compressor and a few lines bent up, and new water pump, borgeson steering shaft, went with dakota digital gauge cluster, mirrors, door lock cylinders. been picking at a fan shroud almost fitted and ready to weld up, swell as the exhaust system, just waiting on tips then ill be able to pull it out and weld it up, intercooler pipes finished. I'm hoping to be able to fire it up next month some time if the fuel fittings show up.
01-17-2020, 07:00 PM | #318 |
What's the scoop ever get the truck finished?? Beauty rig btw ... What did u use for fuel lines?
1996 Silverado ext cab s/b 1986 Silverado s/b 454 t400 -frame off resto hopefully done soon 1976 Silverado cclb dually - getting a cummins asap |
10-04-2022, 03:53 AM | #319 | |
Posted via Mobile Device |
10-04-2022, 03:54 AM | #320 |
Hey every one, owner of the truck if you would like to follow it more. It’s luke.watty on instagram and BigbrownChevy on TikTok. Big shout to M for the truck that he did such a good job on
