Old 10-07-2022, 03:36 PM   #3326
Jiggers72-GMC
Jiggers72-GMC's Avatar
Re: What did you do to your truck today.The 3rd chapter
Wow Zellway, very ''cool'' ....
Gerry, North Bay Ontario
1971 Chevy K10 short stepper, 518 med green & white
1972 GMC C1500 long box, dark Brown, owned since 1977
1969 GMC C2500 manual
Jiggers72-GMC is offline   Reply With Quote
Old 10-07-2022, 04:50 PM   #3327
Johnl48
Hanging doors
Old 10-07-2022, 07:22 PM   #3328
72c20customcamper
72c20customcamper's Avatar
Looks great .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 10-07-2022, 07:27 PM   #3329
72c20customcamper
Grill was worse than I first thought but it’s all welded up . Didn’t get to fussy with the lower attachment area .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 10-07-2022, 07:30 PM   #3330
72c20customcamper
This part I knew about it’s the hole the po put in for the fog lamps .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 10-08-2022, 05:48 AM   #3331
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
A simple engine swap that has turned into all new bearings and a crank from a different engine.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 10-08-2022, 01:13 PM   #3332
72c20customcamper
Installed the new Precision push on door seals . Install was super easy and the door closes fairly nice I didn’t have readjust it at all . Little slam not hard a slam but I’m sure it will crush as time goes on .I did have to cut it but a good set of metal scissors worked well , purchased from GMCPAULS .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 10-08-2022, 01:30 PM   #3333
68bowtie
68bowtie's Avatar
I got the same ones, also from gmcpauls. I have to really slam hard. I guess I need to mess with adjustment.
I live in California, but identify as a Texan
"If a job's worth doing, it's worth doing well"
Survivor "Lil’ Mint" (67 c10 40k mile light green original paint)
68bowtie is online now   Reply With Quote
Old 10-08-2022, 01:49 PM   #3334
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Thanks for the post. I have the same seals and was wondering how hard/easy they might be to install. Is there adhesive behind the original seals ?
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 10-08-2022, 01:58 PM   #3335
72c20customcamper
It’s a firm close but not hard slam . Guess I hit it right at the sweet spot installing the door .
Super easy to install took all of 5 minutes . I use a small rubber mallet to seat the seal . It takes a little back and forth roll to get the lip over the seam by hand then set it with the mallet . I didn’t use adhesive but there were no instructions so I winged it . I was going to use the Honda seals but they are no longer available and I wasn’t going to put used on it .
Now we shall see how the windshield goes in next week . I bought the precision rubber for that too .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 10-09-2022, 01:42 PM   #3336
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Followed Jim's lead and installed this cover on a pretty darn nice wheel. The cover is as old as the truck its going in, 1971
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 10-09-2022, 08:22 PM   #3337
Johnl48
Today I coated door parts with black oxide, and put on the handles and dummy filler cap
Old 10-09-2022, 08:46 PM   #3338
pjmoreland
pjmoreland's Avatar
Nice!! What kind of tank are you installing?
pjmoreland is online now   Reply With Quote
Old 10-09-2022, 08:48 PM   #3339
Johnl48
I did the rear tank conversion from LMC
Old 10-10-2022, 01:33 AM   #3340
Louisvillekytruck
Where did u get the black oxide thanks
Louisvillekytruck is offline   Reply With Quote
Old 10-10-2022, 07:19 AM   #3341
Johnl48
https://caswellplating.com/black-oxide-kits.html
https://youtu.be/7vTn6l5h67A
Old 10-10-2022, 11:01 AM   #3342
Louisvillekytruck
John thank you. Kenny
Old 10-10-2022, 01:10 PM   #3343
OregonNed
OregonNed's Avatar
This last weekend I installed one of those plate mounts to tuck the LP up - I thought it turned out really well.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 10-10-2022, 02:23 PM   #3344
Tommyups
Went shopping 😎
Tommyups is offline   Reply With Quote
Old 10-10-2022, 02:46 PM   #3345
LNP
Some great work guys. I like the electric fan in the stock shroud. Good Idea and very clean looking.
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 10-10-2022, 04:01 PM   #3346
72c20customcamper
Last body panels in high build primer . Dark grey is epoxy prime the body supply had no black and it’s been on back order for 6 weeks .Hopefully paint on Wednesday suppose to be warm enough .
The fender was much worse than I had expected . Took a lot more time just to save the triangles . I could have just worked a new one and welded these onto it
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 10-10-2022, 04:09 PM   #3347
Louisvillekytruck
Alot of work looks great mark
Old 10-12-2022, 03:50 PM   #3348
72c20customcamper
White is painted and dry . Don’t think GM painted the inside of the grill this nice .Couldn’t help myself had to see how the emblem would look.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 10-12-2022, 03:57 PM   #3349
72c20customcamper
Did the drivers side inner skirt . Was going to paint the passenger also but noticed a few holes that weren’t suppose to be there . Not rust but mounting holes for something . I may redo the hood latch . Not liking the little pits .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 10-12-2022, 04:26 PM   #3350
OregonNed
OregonNed's Avatar
Got bored the other evening so I took a set of stainless bolts and polished them up for the perimeters of my wheel housings.
