10-11-2022, 09:29 PM | #1 |
Turn/wiper/dimmer switch issue
I just put a new turn signal cam switch and ignition key switch in my 86 M1009 Blazer. The turn switch will not allow me to give a left signal because the rod hits the column housing when I attempt to do so. For some reason the wiper/dimmer switch seems bad or worn out somehow. I cannot seem to figure out exactly how this is removed and replaced.Can someone help me with this?
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion Last edited by HIGHWAY BY THE SEA; 10-11-2022 at 09:54 PM. |
10-13-2022, 10:57 AM | #2 |
Re: Turn/wiper/dimmer switch issue
The dimmer switch is further down the column and is actuated by a rod making its way up to the turn switch. sounds like when you put it back together you missed the alignment of the 2 at the top. there is a piece that forms itself into the turn switch kinda shaped like a tear drop.
10-23-2022, 09:12 PM | #3 |
Thanks for the reply! I was able to figure it out and install everything perfectly.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion |
