Old 09-03-2022, 08:59 AM   #726
TKCR
TKCR's Avatar
Re: Bench Seats, Having them Reupholstered
Originally Posted by oldgold70c10 View Post
I can't wait to pick it up! That is going to be nice!!!
It was nice meeting you guys this morning.
These guys made a 15 hr trip, one way, to pick up the new restored seat and dropped of the old core seat. I believe the new seat is going to be an improvement!
Old 09-04-2022, 02:47 PM   #727
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
And here it is installed! I could not be more pleased! And it is as comfortable as it looks.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 09-04-2022, 08:17 PM   #728
TKCR
TKCR's Avatar
Happy to here!
Old 10-20-2022, 07:05 PM   #729
TKCR
TKCR's Avatar
73-74 Charcoal bench seat. This one went to California, but it’s the last seat that I’m shipping.
Old 10-20-2022, 08:43 PM   #730
Getter-Done
Getter-Done's Avatar
I have a Seat belt Question
Is there a Vendor that sells the Center seat belt sleeves?
The plastic pieces that crumble apart.
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 10-20-2022, 09:58 PM   #731
TKCR
TKCR's Avatar
Attachment 2225830
Nope, no vendors that sell them.
Old 10-20-2022, 10:08 PM   #732
Getter-Done
I search the WWW.
Then I thought I would ask an Expert.
84 Chevy K-20
Old 10-20-2022, 10:25 PM   #733
TKCR
TKCR's Avatar
Even on the belts I restore, 80% of them are cracked or broken. I get pretty excited when I have a set that they are still intact. Most of the time it’s the top section up by the buckle. I just cut that section off and then clean up the cut. If you look at some of the belts I have done on the Seat belt thread, you can get an idea of what I mean. It used to really bother me that I had to cut that off, but it doesn’t anymore. The buckles actually lay better on the seat with that too section cut off. Here’s an example
Old 10-20-2022, 10:31 PM   #734
Getter-Done
Even on the belts I restore, 80% of them are cracked or broken. I get pretty excited when I have a set that they are still intact. Most of the time it’s the top section up by the buckle. I just cut that section off and then clean up the cut. If you look at some of the belts I have done on the Seat belt thread, you can get an idea of what I mean. It used to really bother me that I had to cut that off, but it doesn’t anymore. The buckles actually lay better in the seat with that too section cut off.
I will take a closer look at that Thread.
I follow you on FB also.
Thanks for the Knowledge.
84 Chevy K-20
Old 11-14-2022, 02:05 PM   #735
65chevysub
65chevysub's Avatar
Re: Bench Seat, Having it Reupholstered
This seat is nearly completed. I still need to get it back together, put all the garnishes on and put the seat rails back on. Seat rails have been restored too.
I will post pics of it again, when it's back together. But here's what it looks like now.
Does anyone sell the oval seatbelt grommets, or should I just look in a salvage yard?
65chevysub is offline   Reply With Quote
Old 11-14-2022, 02:58 PM   #736
TKCR
TKCR's Avatar
These? What color? Send me a PM
Old 11-24-2022, 08:41 PM   #737
TKCR
TKCR's Avatar
Completed a Saddle Tan Velour for someone.
Old 11-24-2022, 08:43 PM   #738
TKCR
TKCR's Avatar
And a 81-87 Blue Velour.
Old 11-25-2022, 10:36 AM   #739
bennylava
bennylava's Avatar
Do you have any more of this fabric, or know where it can be purchased? I managed to find the correct vinyl, but I'm having some difficulty finding that color cloth. There appears two be two different colors of cloth in your image. I'm looking for the color of the pleats. It's the slightly more golden color.
I went to the local supply store and their sample said it's Empress 674-86. Out of the Detroit Auto Fabrics book. I think the 86 part might be the year, although my truck is 87.
Thank you
bennylava is offline   Reply With Quote
Old 11-25-2022, 11:33 AM   #740
TKCR
TKCR's Avatar
Thank you
This is the cover I offered up to you awhile ago. The reason why it looks like 2 different colors, is because the center section is done in a solid, and the rest is the pattern. This is how the originals were done, all the colors in fact. And the color is the same on the 81-87’s, it’s SaddleTan.
Old 11-25-2022, 05:53 PM   #741
bennylava
bennylava's Avatar
PM Sent!
Old 11-25-2022, 07:09 PM   #742
TKCR
TKCR's Avatar
PM Sent!
Returned
Old 11-25-2022, 11:08 PM   #743
Pontiac1976
Pontiac1976's Avatar
Here a thought this.
Getter-Done
Attachment 2225830
TKCR
Attachment 2225830
Well there is LMC bucket seat end sleeves very close to the 87 style just needs to be cuts on the side's and sewn I was going to get them try this. check out TKCR two pic here >
and maybe heat the end heat gun twist cool down fast help it keep it's twist. So what you think TKCR ?
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 11-26-2022, 10:14 AM   #744
TKCR
TKCR's Avatar
Originally Posted by Pontiac1976 View Post
Here a thought this. ...> Well there is LMC bucket seat end sleeves very close to the 87 style just needs to be cuts on the side's and sewn I was going to get them try this. check out TKCR two pic here >
Couple of things.
The sleeves in question are for the 79-87 belts. The previous year, the sleeves are straight, they don’t have all the curves & twist. But the twist is a pia in my opinion anyways. If it’s not on there, the belt lays nicely on the seat.
1) why would you cut the sides and resew?
2) why do the twist?
If you going to try them, try and use them without doing all the modifications.
I did just get a set of gray. I have a set of belts that are getting changed to the light gray color, so I bought a set to try out. Hope it’s not a waste of money. But I’ll update, but over on the seatbelt thread instead of this thread, since this thread is for the Benchseats.
Old 11-26-2022, 11:16 AM   #745
65chevysub
65chevysub's Avatar
Have a question for you. My seat slider on the right side doesn't lock in place. It constantly moves, and someone recommended tightening the wire between the sliders. How would I do that? The sliders are oiled, so there's no binding, and they don't look damaged in any way.
My truck is an 84 Sierra 2500, stock bench seat
Old 11-26-2022, 11:18 AM   #746
65chevysub
65chevysub's Avatar
I apologize. I just saw your message. I will PM you.
Old 11-26-2022, 11:31 AM   #747
Pontiac1976
First the question quote was on the seat, so I just keep place. Two site like the factory for feeding the belt throw. if you wanted copy factory set. and because 81-87 there two different styles I not sure I would because I do not have many people in cab for the one center belt the twist is nice that person try buckle up. Third the sewing is for the belt to the sleeves of the LMC like the factory did to hold it.
Now I believe the LMC bucket seat sleeves may be longer may have to have the bottom cut you can't see any how.
In your second pic is what the LMC sleeves most like which it the later style.
So, you have order them I have had a chance yet. very Kool I would like you thoughts on them, I still going to order them.
Oh, for the center you still have to make a straight cut if you want it like the factory did to lay out face to right way if you have more than two people.
Old 11-26-2022, 11:55 AM   #748
TKCR
TKCR's Avatar
Your probably missing the little spring on the back of the tracks. They are circled in red.
Now the wire between the 2 tracks, you don’t want to tighten that up. All that will do is keep the locks in the open position. All the wire does is pull the locks open to slide the seat when you pull the seat adjuster handle. It does need to be fastened to the frame in one spot to take up the slack. That’s the second photo.
Old 11-27-2022, 03:48 PM   #749
bennylava
bennylava's Avatar
Recommendation on a good place to buy new seat belts?
Old 11-27-2022, 04:42 PM   #750
TKCR
TKCR's Avatar
This is the is the Benchseat thread. I do have a Seatbelt thread, but I’ll answer this. If your looking for new belts, those would be aftermarket belts, but I wouldn’t recommend them to anyone. They are ugly and don’t work very well. You have said numerous times that you can’t afford a new cover, so new seatbelts are going to be more than what a new cover costs.
If you have your original belts, I can restore them, that is what my Seatbelt thread is all about. If you haven’t seen it yet, check it out.
