10-30-2022, 07:22 PM | #1 |
rack and pinion steering
Has anyone had a successful Flaming River rack and pinion kit installation? Had a kit along with Flaming River column installed, on my 71 by a professional shop and when went to pick it up was not drivable on street. Had 4 hard spots when turning from lock to lock. Upon further inspection could see evidence one U-joint hitting on itself, angle was to great. Shop says can't correct do to headers. I have since made major changes double D rod lengths and redid the center rod supports. Is considerably better, but not what I would consider to be acceptable for a rack and pinion steering.
The pictures should further explain my situation. The u- joint @ end of column is at 16.5 degrees and center u-joint is right at 35 degrees, the bottom u-joint is at 32 degrees. I am thinking the middle u-joint is my problem. Last edited by pappy 2; 10-31-2022 at 04:56 PM. Reason: add more information |
10-30-2022, 09:58 PM | #2 |
Re: rack and pinion steering
Was the steering joint binding? If so they need to start over and adjust the angles or add another joint to make it work properly.
NHRA Super Street 469C It only runs 10.90 at 156 mph |
