Old 10-10-2022, 10:33 AM   #126
doug_p
Junior Member
doug_p's Avatar
Re: My 1967 Build (Finally)
Truck is looking awesome - very nice work you are doing.
DP
doug_p is offline   Reply With Quote
Old 10-11-2022, 08:18 AM   #127
KyleSeal
KyleSeal's Avatar
Etch primer laid down, went on pretty good, I used the SEM acid etch in an aerosol can, and Id say it seems like good stuff. I am going to try my hand at the epoxy Raptor two part before putting down the final liner.
Size:  109.7 KB Name:  IMG_1810.jpg
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 10-17-2022, 08:58 AM   #128
KyleSeal
KyleSeal's Avatar
Sunday was the day, tinted the Raptor liner and put it down in two decent coats. Not sure what PSI this was at, but the texture was pretty good.
Size:  90.4 KB Name:  IMG_1893.jpg
Old 10-17-2022, 08:59 AM   #129
KyleSeal
KyleSeal's Avatar
Final product. If anyone needs to know, two bottles of Raptor liner cover a 67-72 floor perfectly, with some left over.
Size:  64.7 KB Name:  IMG_1891.jpg
Old 10-17-2022, 09:17 AM   #130
KyleSeal
KyleSeal's Avatar
I appreciate it!
DP
Old 10-17-2022, 10:26 PM   #131
Pingar
Truck is coming along nicely.
Pingar is offline   Reply With Quote
Old 10-19-2022, 11:27 AM   #132
KyleSeal
KyleSeal's Avatar
Thanks! Looks like you're in VA as well, what part?
Old 10-19-2022, 11:29 AM   #133
KyleSeal
KyleSeal's Avatar
I have to give the Raptor liner about a week to fully cure, so in the mean time I'm trying to get this roof skin sorted out and see if its worth using. I got it for a great deal, even considering its dents, so Im currently trying to work those dents out before I replace it, if I decide to. Reason being, my inner roof has a few small holes needing fixed, and I imagine theres more in there.
Old 10-19-2022, 01:19 PM   #134
Pingar
Chesapeake
Old 10-19-2022, 03:59 PM   #135
88Stanger
88Stanger's Avatar
damn fine job so far sir!!
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 10-19-2022, 08:05 PM   #136
72 tigger
72 tigger's Avatar
Good progress!
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 10-25-2022, 09:54 AM   #137
KyleSeal
KyleSeal's Avatar
Thank you both!
Originally Posted by 72 tigger View Post
Good progress!
Old 10-25-2022, 09:57 AM   #138
KyleSeal
KyleSeal's Avatar
Working on odds and ends while I have the cab on its back, for whatever reason one of the previous owners of the truck decided to primer the inner roof skin and back wall. With a little 800 and 1000 Ive cut some down to see if the original color is still there - it is. They burned through some of it when sanding to prime, so itll be 'patina'd' once all the gray primer is gone. I sure have my work cut out for me.
Old 10-29-2022, 12:09 PM   #139
Undone
Attachment 2225020 Attachment 2225021
Attachment 2225022
What process did you use to tint the Raptor liner?
Undone is offline   Reply With Quote
Old 10-31-2022, 10:25 AM   #140
KyleSeal
KyleSeal's Avatar
I went to a local paint supply house and had them match the color of the truck, and they sell Raptor kits as well, told them it was for a Raptor tint so they mixed accordingly.
They recommend to add by weight, but since Im not looking for a crazy match, I just added 3.5oz, and the hardener was added with the kits supplied measuring cup.
Old 10-31-2022, 10:55 AM   #141
KyleSeal
KyleSeal's Avatar
Bench seat time. Getting a jump on costly interior stuff so it doesnt smack me in the face when it comes time to get it together. Bench needed some areas repaired.
Size:  82.7 KB Name:  IMG_2048.jpg
Size:  80.4 KB Name:  IMG_2049.jpg
Old 10-31-2022, 10:57 AM   #142
KyleSeal
KyleSeal's Avatar
Local hotrod shop, Bad Company , had a Trunk Or Treat Saturday night, they had this 67 on GSI setup there, pretty cool truck. Good inspiration for future bags..
Size:  77.0 KB Name:  IMG_2039.jpg
Size:  69.4 KB Name:  IMG_2028.jpg
Old 11-01-2022, 08:20 AM   #143
KyleSeal
KyleSeal's Avatar
Finished up the new 'block off' plate for the firewall. I basically cut the face off, glassed a flat sheet to be graphed in, and then took the box and cut down the width, as you can see in the pics. I took apart the blower motor and cut the big nose off it, and graphed it back in to look like a block off plate.
Size:  83.3 KB Name:  IMG_1952.jpg
Size:  71.2 KB Name:  IMG_0787.jpg
Old 11-01-2022, 08:27 AM   #144
KyleSeal
KyleSeal's Avatar
Ordered a bench seat cover from Distinctive Industries through CJPonyParts last night... we will see how it works out soon hopefully! Waiting on new seat springs and foam still, should have some pictures of how it works out by December.
Old 11-01-2022, 08:32 AM   #145
Grumpy old man
Grumpy old man's Avatar
Attachment 2227886 Attachment 2227887
Attachment 2227888 Attachment 2227890
So I have to ask , Your not going to have any heat/air/ defrost ?
Old 11-01-2022, 08:38 AM   #146
KyleSeal
KyleSeal's Avatar
Vintage Air is on order through Laid Back Recreations
Should have it around January or so, I'll do like N2Billet did an run a bulkhead through the face of the box.
Old 11-02-2022, 09:03 AM   #147
KyleSeal
KyleSeal's Avatar
Final pics of it together.. suuuupper glossy... probably gonna put this one outside in the sun for a few days or weeks and let it age, or hit it with some scotchbrite and matte clear.
Size:  52.3 KB Name:  IMG_2083.jpg
Old 11-07-2022, 10:31 AM   #148
KyleSeal
KyleSeal's Avatar
Learned some stuff this weekend. Found out that there are no current bench seat upholstery kits that fit my style bench seat - my luck . So I've decided to not compromise and just have a local shop do the upholstery I want and be happier in the end. So I cleaned up the bench seat and shot some black paint after fixing some spot weld areas that had broken and repaired some other areas. Installed the Full Custom Fab drop brackets and added the measurements.
Old 11-14-2022, 09:22 AM   #149
KyleSeal
KyleSeal's Avatar
Well, I did the thing, cut the roof skin off. Talk about nervous to see what is below. But it wasnt as bad as I thought, I expected much worse. Repaired one of the front roof holes, and honestly the metal is still pretty strong. I still have some small pin holes to fix.
Size:  56.3 KB Name:  IMG_2180.jpg
Size:  54.0 KB Name:  IMG_2187.jpg
Old 11-14-2022, 09:27 AM   #150
KyleSeal
KyleSeal's Avatar
Patch came out pretty well, still need to get it fully massaged in place, but I also need to make a decision on the rest of the pinch weld seam at the windshield.
Size:  76.4 KB Name:  IMG_2194.jpg
1967, custom, dropped, lowered
