Old 11-11-2022, 12:56 AM   #151
daveshilling
daveshilling's Avatar
Re: 1958 Apache Big Window Loooooong Bed "Lucky"
Since Glen is a bully, I did something and took photos. I wanted to shorten my pedal, but I figured while I had it hacked up, why not sneak a custom change in there that only truck guys would notice?
I got a disc brake rubber replacement pad for a newer chevy truck, made a new pedal, and welded it to the shortened rod. I expect much less travel with hydroboost so this should be plenty, and if it's not, I will change the pivot or just go firewall instead.
It's cut to match the DBW pedal I have installed right now.
daveshilling is offline   Reply With Quote
Old 11-11-2022, 12:59 AM   #152
dsraven
It's good to check that a full pedal travel equals a full master cylinder travel, plus a safety margin.
dsraven is online now   Reply With Quote
Old 11-11-2022, 01:08 AM   #153
daveshilling
The original pedal had more travel and a shorter pivot point, creating more leverage due to the 4 wheel drum brakes on a larger cylinder. With power brakes, less force is needed, and the pivot point has been effectively moved further to center, increasing travel after that point per inch of pedal travel.
Hydroboost also just doesn't need much pedal, but we will find out one way or another!
Old 11-12-2022, 09:04 PM   #154
daveshilling
I'm still on the hunt for a new red 58/59 front clip, and will likely be doing so for years, but in the meantime I need to attach a headlight to this crappy fender. It was hit, creased, and a light bucket could not fit.
Considering my absence of metalworking skills and the crap I was working with, think its a solid C-
There is still crappy sheet metal in this area, but It's not worth going further right now... I'd rather get it driving. Also I don't have the skills anyways.
Old 11-12-2022, 09:06 PM   #155
daveshilling
Here is how it used to look:
Old 11-12-2022, 09:52 PM   #156
dsraven
Looks ok to get it going and just keep an eye out for a better one.
Old 11-15-2022, 03:03 PM   #157
59chev
59chev's Avatar
What year is the replacement pedal pad? Looks great! I have been considering a similar mod for my 59.
My Build Thread: 59 Apache - Lifelong obsession
http://67-72chevytrucks.com/vboard/showthread.php?t=622133"]59 Apache - Lifelong obsession
59chev is offline   Reply With Quote
Old 11-15-2022, 04:17 PM   #158
dsraven
c'mon 59, its from a newer chevy truck. duh.
just kidding.
what I would doif I were you, if you like the look and larger pedal pad, is look at a newer truck that parts are easily available, like in stock at canadian tire or auto value's "help" section etc, then go to pick n pull and find that truck, remove the pedal pad and take a pattern of the steel part of the actual pedal. then you can either keep the used pedal pad or order one for a vehicle of that year/series. when it arrives you can fab a steel pedal part for it and weld it onto your existing pedal. or get the complete pedal from the donor truck at the wrecker but you need the whole pedal as a hacksaw isn't gonna cut it well and they don't usually let you in the yard with any soet of power cutting tool. trust me, those pedal arms are hardened or treated steel. when I was working the rescue truck we avoided cutting the pedals if we could because they took the edge off our jaws of life tools, or they took a piece out of the cutting edge.
Old 11-15-2022, 09:06 PM   #159
daveshilling
....or order one for a vehicle of that year/series. when it arrives you can fab a steel pedal part for it and weld it onto your existing pedal.
This is exactly what I did. I ordered a larger pad, made a new steel pedal using the pad as a template, and welded it to the shortened factory bar.
Old 11-15-2022, 09:08 PM   #160
daveshilling
It's a Dorman 20771. I think they make one with a metal insert in the center that says Disc Brake, but I couldn't find it and didn't try super hard either.
Old 11-20-2022, 08:02 PM   #161
daveshilling
drivers door repair
Working on the Drivers door, and decided that hey, I have sheet metal here, lets repair the bottom of the door. Patina trucks can still have this bit replaced without the absolute travesty of fresh metal and paint showing somewhere (=
I cut out the nasty bit and did my best to form a patch... its not perfect, but it's here, and it was free!
I also found the old window... it was rattling around inside this door along with 5 pounds of dirt!
Then I realized easy access like this is great for fixing the rest of the door... the hinge side was all pushed in, the lower hinge area is a disaster and was farmer-fixed... so this led to that.
Old 11-21-2022, 08:54 PM   #162
G&R's57GMC
G&R's57GMC's Avatar
For not being a body man Dave you sure tackle the sheet metal work and get good results … well for a patina truck .
But the more you work the more experience you gain and the better the results .
Won’t be long and you’ll be ready to go for a primed finish and then the fun begins.
Yah I know you’re going for patina finish on this truck, but some day the next project you’ll be that much closer with your skills to go to the next level.
Congratulations keep at it.
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 11-22-2022, 09:27 PM   #163
daveshilling
Thanks, Glen! I'm definitely just jumping and getting some lessons learned. I don't have a body work mentor here so I'm just going at it. It's fun AND stressful, but I WILL get this truck on the road!
The drivers fender eyebrow is essentially non-salvageable unless you were fully equipped with tools and skills to form patches and I'm not. But it will hold headlights now, and I may tinker with it a bit to improve the looks a touch more.
Old 11-22-2022, 09:35 PM   #164
daveshilling
Working on the door hinge area
While I had the door apart, I was able to fix some "creative" body work done by previous owners and get the hinge side jamb area to more closely resemble what it should be, vs. being all caved in.
I had a piece of steel bar stock to use as a dolly that was the right width. You can see in the second photo how wide this area had become by past hammering, vs the lower portion of that photo showing how narrow it should be.
Old 11-23-2022, 02:01 PM   #165
daveshilling
The hinge corner on this door was BAD. Someone before me used C channel, steel rod, and some nuts to repair it, which wasnt too bad considering it was basically a quick fix, but it wasnt good enough for me.
I cut that garbage out, and I'm welding in some slightly better garbage
My donor was much better, but still broken, so I first made a thick, strong backing plate to hide behind the cracked sheet metal. After I drilled and bolted it in, I welded it to the back of the hinge support in multiple places (not pictured) From the outside, it will appear to be in dire need of repair, but magically strong somehow!
Old 11-23-2022, 02:24 PM   #166
daveshilling
Once this hinge was fixed, I could take HOURS to get it positioned the best I could based on measuring another spare door in like 20 places... It's probably not a perfect positioning but its better than what I had!
I also had to replace a little corner of the door but I didnt photograph that bit.
I'll have to experiment with blending this paint in, but the good news is that I can do that some other time, when I have a running, driving, stopping truck.
Old 11-24-2022, 12:03 PM   #167
Rickysnickers
Nice job on the repair!! That ought to hold for a few years
Old 11-29-2022, 03:17 AM   #168
daveshilling
Thanks! I think it will keep the door on, at least...we'll see if it closes.
Old 11-29-2022, 03:19 AM   #169
daveshilling
Before I could continue on, I needed to add a corner to the door... there was simply just no metal here whatsoever. I cut it clean, made patch and did my best to be patient with the tacks. it wasn't a smooth area to begin with, but I didn't want to cut more painted surface away than necessary.
Old 11-29-2022, 03:24 AM   #170
daveshilling
The lower corner I attached seemed to be at a bit of an angle to the rest of the door. The missing sheet metal at the bottom certainly wasnt helping with rigidity... so I came up with this solution. I clamped bar steel on both sides until the corner and door were flush with each other, and tacked the door to the steel on top to keep it there while I attached the door bottom patch.
It worked well, and held just fine while I got the lower patch fitted.
Old 12-14-2022, 09:09 PM   #171
G&R's57GMC
G&R's57GMC's Avatar
Any more progress lately ?
Glen & Jane's Rides
Old 12-18-2022, 05:52 PM   #172
daveshilling
I've been on vacation for a couple of weeks, so nothing has really been done. Before I left, I fitted the patch I made and started tacking it in.
I realize that I didn't fit any drain holes, so I'll have to sort that out, somehow. I still need to clean up the corners, but I think it will be a functional door at least, and I'm glad I can hide my beginner-quality work under a door!
Old 12-19-2022, 11:18 AM   #173
dsraven
looks good.
when I do patches I fit the part and hold it in place with magnets, then do small tacks starting at one end with a tack, then go to the other end with a tack and then one side then the other side. this ensures the part doesn't get moved as the welds pull the metal when they heat and cool. I try to tack not too close to a magnet as the magnetic field disrupts the mig welder. then once it's tacked in a few spots I ensure the fit is still like it should be and adjust as required. then I place a tack half way between the existing tacks. letting each one cool, an air blow gun can help this along. tack, cool, tack, cool, placing the tacks half way between the other tacks and working at opposite areas between tacks and checking fitment. if I have access easily to the back side of the panel sometimes I will hammer on dolly right on the tack weld when it is still cooking hot. this expands the weld and when it cools the panel doesn't shrink or pull so much.
Old 12-19-2022, 01:55 PM   #174
daveshilling
looks good.
Thanks for sharing the tips!
Old 12-19-2022, 02:10 PM   #175
daveshilling
Since I didnt want to cut into the door front too much at first, this section had very little integrity, looked like crap, and needed to be replaced. This also let me smooth out the line at the bottom of the door where the replacement corner meets the rest of the door.
Nothing too exciting, but I'm documenting the steps!
