Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 10-29-2022, 05:11 PM   #1
Zonaman
Zonaman's Avatar
Minimum Ohm Requirement?
Got an original GM radio in my dash and I'd like to wire it up again. Question: Isn't there a minimum ohm requirement for the speaker on that? Also can i get some type of splitter for the radio antenna so both units can use the existing antenna?
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus!
Zonaman is offline   Reply With Quote
Old 10-29-2022, 08:39 PM   #2
Dead Parrot
Re: Minimum Ohm Requirement?
Not sure about a minimum. But best operation is when the speaker and radio match. IIRC late 60s and 70s radios were 8 ohm. Later ones went to 4 ohm.
Dead Parrot is offline   Reply With Quote
Old 10-29-2022, 08:54 PM   #3
Zonaman
Zonaman's Avatar
I seem to remember 8 ohms too.
Old 10-31-2022, 02:47 PM   #4
damnyankee36
damnyankee36's Avatar
Speakers of that era are 10 ohm.
Splitters are available too.
https://www.google.com/url?sa=i&url=...r4kDegUIARCGAw
damnyankee36 is offline   Reply With Quote
Old 11-05-2022, 03:50 AM   #5
Zonaman
Zonaman's Avatar
That's good news. Are there any diagrams or photos around that illustrate how the factory brackets fit together for the radio and speaker?
Old 11-05-2022, 09:43 AM   #6
damnyankee36
Here are a couple from a 68 I am building.
Old 11-05-2022, 09:55 AM   #7
damnyankee36
I just took a few more for ya...
Old 11-05-2022, 10:24 AM   #8
Zonaman
Zonaman's Avatar
Thanks! Does that assembly act as a ground in any way for the radio or speaker?
Old 11-05-2022, 10:57 AM   #9
damnyankee36
The radio is grounded through the brackets and I think the speaker is also grounded to the body electrically, but not directly. If it is grounded it's through the radio/speaker harness. Here's a photo of the harness.
The speaker wires are permanently attached to the speaker and its 3-terminal connector plugs into the back of the radio. The red power wire plugs into this same connector and the other end connects to the fuse box to the left of the "RADIO" fuse.
Old 11-05-2022, 07:59 PM   #10
Zonaman
Zonaman's Avatar
Yeah, thought so. My brackets are long gone. So if get a screw strap on there and use it for a bracket (along with the speaker ground) that should ground the beast?
Old 11-05-2022, 08:00 PM   #11
Zonaman
Zonaman's Avatar
Is there a decent, reasonably priced 10 ohm speaker on the market? Thanks again for all pictures!
Old 11-05-2022, 10:53 PM   #12
damnyankee36
Yes, grounding the radio case will get everything working for you. I don't know of a10 ohm speaker off hand. I'm sure you get can one reconed.
I'm pretty sure the setup I have will not be used in this build. The owner wants a modern stereo, like RetroSound along with kick panel speakers to go in the truck.
PM me if you're interested.
Old 11-11-2022, 06:47 PM   #13
Zonaman
Zonaman's Avatar
Picked up 10ohm Delco 6x4 oval in good condition at a local garage sale. Looks like I'm in business. Thanks.
Old 11-12-2022, 10:58 PM   #14
Zonaman
Zonaman's Avatar
Anyone recognize this type of speaker plug. Still available?
Old 11-13-2022, 11:53 PM   #15
pjmoreland
pjmoreland's Avatar
That looks like the kind of connector that is on the speakers in my '89 Chevy truck. I am in the middle of replacing the rear speakers, and I bought a set of replacements at the wrecking yard. I have the original connectors that I cut off the donor truck. I'd be happy to send you one if you pay for the shipping.
pjmoreland is offline   Reply With Quote
Old 11-14-2022, 05:57 PM   #16
Zonaman
Zonaman's Avatar
Thanks but I ended up cannibalizing the connecters from another speaker and it fit okay. So just waiting for my antenna splitter plus some odds and ends and I'll see if my Frankenstein lives.
Old 11-16-2022, 11:37 AM   #17
Zonaman
Zonaman's Avatar
One other detail: What's the correct fuze size on the stock radio?
Old 11-16-2022, 11:49 AM   #18
pjmoreland
pjmoreland's Avatar
The radio fuse in the fuse panel is marked "3A"
Old 11-16-2022, 12:50 PM   #19
Zonaman
Zonaman's Avatar
3A check, thanks.
Old 11-17-2022, 03:14 PM   #20
Zonaman
Zonaman's Avatar
Got everything wired up but could only get a very weak broadcast. Ground is good- screw strap from back of radio right to the body , antenna good (other radio is fine). speakers are wired up right. Only thing I noticed was the static was a bit louder when I put a little pressure on the volume button. Any thoughts?
Thanks.
Old 11-18-2022, 06:08 AM   #21
Zonaman
Zonaman's Avatar
Something else: Since I didn't have the bracket that the speaker sits in and I did think it was a good idea to have the speaker in the factory location right in the front dash where the Arizona sun could do its work on it, I ran the speaker wires down the firewall and under the seats to the center console. It sits in a speaker box there. I bring this up because factory bracket has the speaker magnet itself in direct contact with the body ground in a big way. Did I by any chance "screw the pooch" by setting it up this way?
Old 11-18-2022, 02:13 PM   #22
pjmoreland
pjmoreland's Avatar
I have bench-tested multiple OE radios with a speaker sitting loose on the bench, and it has worked just fine that way. I don't think the housing of the speaker needs to be grounded. I saw some stock speakers in a mid-90s Chevy truck recently that were mounted in plastic housings that isolated them from the metal body.
Old 11-18-2022, 02:20 PM   #23
Zonaman
Zonaman's Avatar
Radio is damaged likely?
Old 11-18-2022, 02:29 PM   #24
pjmoreland
pjmoreland's Avatar
I had a damaged OE AM radio that produced nothing but quiet static that didn't change when the tuning knob was turned. My guess is that it had been powered up without a good 8-10 Ohm speaker attached at some point. I ended up replacing it with another AM radio that did work.
https://67-72chevytrucks.com/vboard/...d.php?t=814243
Old 11-19-2022, 04:45 PM   #25
Zonaman
Zonaman's Avatar
Maybe. I recall reading something about that radio needing a 7 ohm speaker which is what I had on it one time. I probably messed it up with that.
