11-14-2022, 09:32 PM | #2601 |
Re: Post Your Craigslist Finds Part 2
11-14-2022, 09:34 PM | #2602 |
https://sfbay.craigslist.org/sby/cto/7552631639.html For Sale, a 1971 C20 3/4 Ton Pick Up. Good running Truck, recent Complete Tune Up, new front and back brakes, Clean Title and Registration up to date with Tags good to June 2023
Body damage front fender driver side. See pictures. This C20 already has front Disk brakes, power steering, V8 350 2BBL Carb. |
11-14-2022, 09:36 PM | #2603 |
72 Chevy Longhorn C-20 pickup. Low miles on engine and transmission. Original 402 big block and turbo 400 trans.
Cheyenne. 8.5 ft bed. A/C front disc brakes. Recent work includes a complete rebuild of front suspension. Very few miles on new tires. Reupholstered bench seat. Perfect truck for a vintage camper or camp trailer. Runs and drives well. Trades or offers considered. https://sacramento.craigslist.org/cto/7556215736.html Last edited by Wikid61; 11-14-2022 at 10:12 PM. |
11-14-2022, 09:37 PM | #2604 |
1972 Chevrolet El Camino SS 454
Matching Numbers LS-5 454 Turbo 400 Automatic Transmission Power Steering, Power Disc Brakes Tilt Steering Column Factory Cruise Control Rare Vinyl Top, AM/FM Radio Super Rare Factory Air Conditioning Correct Hood Pins Factory Rally Wheels with TA's Tires Rare and Correct Mohave Gold Paint (code 63) J.D. Power Average Retail: $47,700 https://portland.craigslist.org/wsc/cto/7555119753.html J.D. Power High Retail: $72,200 |
11-14-2022, 09:39 PM | #2605 |
Hello craigslist I am selling my 1972 Chevrolet Cheyenne C10 pick up truck v8 350 automatic all original drives fantastic fires right up and goes with no hesitation the body and interior are in beautiful condition no scratches or dents on her garage, kept most of its life you wont find a better running truck this truck will take you anywhere. Clean title and registered.
Im asking $23,500 serious buyers only call https://sfbay.craigslist.org/pen/cto/7554445827.html |
11-14-2022, 09:39 PM | #2606 |
11-14-2022, 09:40 PM | #2607 |
1972 Chevy C10 stepside short bed
New paint and interior Clean California title 5.3 LS V8 4L60 Four speed automatic New tires Power steering Front disc brakes ice cold a/c Nice dependable truck No tradeshttps://sfbay.craigslist.org/nby/cto/7553202863.html asking $29,5 obo |
11-14-2022, 09:44 PM | #2608 |
5.3 LS Powered 4L60 Trans
New American 5 Spokes With Tires Paint Is Nice Zero Rust Body Is Nice Air Bagged All CPP components New Wood In Bed Body Gaps Are Nice Still Has All The Factory Glass You Can Drive This Thing Across Country No Problem Please Call With Questions show contact info NO TRADES https://losangeles.craigslist.org/sg...557487306.html |
11-14-2022, 09:45 PM | #2609 |
1967 Chevrolet c10 short bed truck.
5.3L LS Swap fresh engine build by Napa of Mustang Oklahoma, BTR stage 2 cam kit/springs. Long tube headers, 3 exhaust to 1 chamber flowmaster mufflers. Aftermarket wire harness and fuse/relay bank to run ecu, tuned and runs great. After market aluminum radiator, electric fan, Custom made intake cover to match truck, New sensors, new gaskets, new injectors, new water pump, new belt and hoses etc.. not a junk yard swap. RRR Transmissions built th350 trans, built internals good for 800hp, B&M 2800 stall converter, B&M pro pistol grip shifter, transmission hits hard and works great. Narrowed Ford 9 rearend, Moser screw in big stud axles, new positrack unit, 3.50 gear, rear gear whines on deceleration but drives fine, Competition Engineering ladder bar setup, Strange Engineering adjustable coilover kit, Weld Forged 15x12 wheels, was on 28x10.5 radial, currently on Mickey Thompson sportsman 31x18.5 (will need tires before long) will fit small tire or big. Will fit big wheels for the pro touring style as well. 2x4 rec tubing rear frame with tall z step ( will lay frame on air ride setup) still has air bag plates welded into frame for bags. Can be swapped back to air ride pretty easy. Large 20 gallon bladder fuel cell in rear under bed, rear mounted battery on frame, Has receiver hitch behind tag and will pull a trailer 😉 #Rockymountainraceweek Z step front frame and boxed, stock style front end but trimmed for air ride, truck used to be on air and 22s, can lay body.. front fenders trimmed for big wheels/no inner fenders. Has bolt in brackets for stock style front springs ( currently on) , still has air bag plates welded in, New front control bushings included with truck, has new ball joints upper and lower now, Aftermarket 2 drop spindles, disc brake front. I have the option of a brand new disc brake kit for the rear if we make a deal. Ive owned this truck for approx 13 years, bought it stock and partially restored, already had some body work done when I got it but needed alittle more to be paint ready (to me) so I had it patina sanded and Summit racing matte clear coated, was a Texas truck so no bad rust in the major areas, has new rockers that I know, has minor rust in front core support bracket (pics) had some spots lower inner door, not bad for a driver at all, its not a show pony that stays in the garage, it was meant to be driven and it does. I daily drive this truck stock for years, then lowered on 22s for years, then air ride for years and now on coil overs and big tires for years, the current LS 5.3L thats in it only has approx 1,000 miles on it and the transmission, original standard trans truck, still has the clutch pedal and column shifter. the interior is in good shape, all lights work/turn signals, headlights, floor dimmer switch, dash lights, dome light, wipers, no fuel gauge, in dash DVD player, has a Bully Dog digital gauge setup, with tach and temps, is programmable etc.. seat was completely redone when I got the truck and sits great, new carpet kit, custom made console with nice B&M shifter. Ive loved truck for years but its time to build a bigger shop.. its not perfect but its been road proven and driven, has little quirks but always starts and runs right, I will do my best to answer questions but please No Trades, if your serious you can call me. NO TRADES. Thank you https://lasvegas.craigslist.org/cto/7557239770.html |
11-14-2022, 09:47 PM | #2610 |
Hi I am selling my 1972 C10 super Cheyenne Frame off restored 10,000 miles on my engine it is 350 ,400 Turbo transmission Drives like brand new everything on the truck is all brand new Original short bed ,AC ice cold All brand new tires and also a second set of tires Extra parts goes with the truck A must come and see for yourself please call or text for more info No emails will not answer emails serious buyers cash Asking price $39500 https://inlandempire.craigslist.org/cto/7557099945.html
11-14-2022, 09:50 PM | #2611 |
11-14-2022, 09:52 PM | #2612 |
Brand new engine! Brand new custom wood bed! This beautiful forest green 1969 Chevrolet C20 with matching interior is ready to be your stylish daily driver. Runs great, kept in excellent condition by previous 2 owners. Automatic. Front tires recently replaced. Ready to be your daily driver, or could be a fun project if youre looking to build something special. Clean title! https://losangeles.craigslist.org/la...556263424.html
11-14-2022, 09:53 PM | #2613 |
11-14-2022, 09:55 PM | #2614 |
This is my daily driver. 350 cu in with mild cam and headers. Has a tow package and a eight foot bed. Has vintage air, brand new transmission(Turbo 350), new interior, new electronic distributor, wires, torque converter, and mounts. Kenwood stereo that cranks. It does have imperfections and some minor scratches. My next stop was addressing that and paint. Just testing the waters and dont need help selling. Will consider trade up or down. This truck does not over heat or leak and all gauges work. Extra parts plus some interior parts on back order. https://bakersfield.craigslist.org/cto/7553393385.html
11-14-2022, 09:57 PM | #2615 |
11-14-2022, 09:58 PM | #2616 |
1972 GMC 4X4 2500 ALL ORIGINAL PANELS , 86000 ORIGINAL MILES FROM NEW. (USEING DAILY)
BRAND NEW TIRES, VERY GOOD PAINT VERY CLEAN INTERIOR REALLY NICE TRUCK. Transmission, Transfer case, Brakes, and suspension bushings FRESH 23,500. OBO https://losangeles.craigslist.org/sg...557153481.html |
11-14-2022, 10:01 PM | #2617 |
11-14-2022, 10:02 PM | #2618 |
https://phoenix.craigslist.org/evl/cto/7556378221.html This is the first time this truck has ever been offered publicly for sale. It was purchased from the original owners estate. Spent its entire live in the sunny dry climate of Arizona and parked / stored undercover for the last 20 years.
This C10 is a genuine short bed with a small rear window. Powered by what appears to be the original 283 small block and 3 speed manual transmission. This three on the tree truck was delivered new with a limited number of luxury options - equipped with a drivers side sun visor and radio blank out plate. The paint is original and sports an amazing pitana finish. The interior seat has been reupholstered in its original vintage style and color. The factory dog dish hubcaps are correct for the 1967 truck. The full undercarriage and frame are rust free and very vintage original. |
11-14-2022, 10:04 PM | #2619 |
1967 Chevrolet CST Pickup. Original owner swapped out small block and a/t for a crate 454 and crate 700 R4 about 4k miles ago. Factory Air truck with everything there but compressor not hooked up charged. Original Blue interior. One turn of the key fires it up every time. Very Clean Laser straight body and frame. ready for restoration. Air Bags for rear come with it. Original A/C compressor with Bracket comes with it.Clean Title. Clean Dry body and frame. Dual Exhaust. 1967 with Big Back Window.
Must See this Truck Must sell buying house odometer and title show 99k original miles and works Best offer takes it Call 52O 977 4II5 in tucson $12,560 https://phoenix.craigslist.org/nph/cto/7554362637.html |
11-14-2022, 10:05 PM | #2620 |
https://phoenix.craigslist.org/evl/cto/7552487726.html 1967 Chevy shortbed pickup
Small back window 2 wheel drive 350 Chevy motor 350 transmission Runs and drives Original shortbed No rust Good clean title 8500 obo |
11-14-2022, 10:07 PM | #2621 |
1968 Chevrolet C10 Short Box with 1970 Front clip - $25K Best offer - cash only
This is a real original short box not a cut down Power steering and Power brakes Restored Salvage Arizona title in my name ready to go Note: Original owner stated reason for Restored Salvage title status was original Big Block motor was blown and replaced with a 350 Small Block. I think it had more to do with the front clip being damaged at some point in time and then replaced with the 1970 front clip. Orange outside, (Driver quality paint) Gray, Orange and Black interior (very good shape) 350 Small Block Chevrolet 350 Turbo Automatic transmission Chevy 12 bolt rear end The good Truck has been in Arizona most of its life Truck drives good and has decent power, shifts well and sounds good Frame is solid Exhaust is in good shape - dual exhaust with headers and Magnaflow mufflers Newer front and rear lowering springs and shocks Engine compartment is in pretty decent shape, needs more cleaning, painting and detailing Interior - is in really nice shape, buckets and removable console many new parts listed below Cooper Cobra front and rear tires P255/70R15 American Racing wheels Gas tank relocated to under bed Battery replaced Feb 2021 Clarion AM/FM, CD player with Sub and amp The not so good Driver quality paint Rust spots on lower passenger door and lower fender due to draining issues Would be nice to have tilt steering Original AC truck that is not connected Wipers dont work Fog lights are not connected No seat belts Many New parts: have most receipts Front Bumper, brackets and bolts Rear bumper brackets and bolts Front inner and outer 1970 Gill assembly Front headlights whiter lights H4 new from the inside bucket out to the trim LED side marker running lights all four corners and they blink with the blinkers LED taillights Rear window and seal Holley Bed Mat Bed is in great shape no rust Windshield wiper arms and blades Bowtie hood emblem Fuse box and all dash wiring Rear wiring harness Autometer Sport-Comp gauges with Chrome dash bezel all gauges work Ignition and Light switch replaced Both side door windows were rebuilt with new crank mechanism, weatherstripping and operate like new Wing window rubber seals Door weatherstripping Interior LED light Chrome glove box door Black dash pad and gray dash carpet that can be removed Rear view mirror Black Chevrolet mats Have good used gray headliner that can go with the truck Valve covers, breathers and air cleaner matching set MAS HEI Distributor, rotor, cap, spark plug wires and spark plugs Edelbrock electric fuel pump, fuel filter, Belts, radiator hoses, thermostat, Oil and filter Transmission - vacuum module, Speedo housing kit including seals and speedometer cable fluid replaced Radiator was replaced with a Big Block radiator and a new fan shroud No scammers https://phoenix.craigslist.org/nph/cto/7557559776.html |
11-14-2022, 10:10 PM | #2622 |
1967 chevelle ss, 396 4v, automatic,
very solid builder bench seat not running all there needs full restoration (non matching numbers) $31500.00 1970 c10 350 2 v longbed factory automatic very solid builder , engine running no tailgate otherwise all therehttps://santafe.craigslist.org/cto/7547712132.html $5700.00 obo |
11-14-2022, 10:13 PM | #2623 |
11-14-2022, 10:16 PM | #2624 |
11-14-2022, 10:16 PM | #2625 |
1971 Chevrolet K10 4x4 Custom Deluxe Fleet-side Pickup. This is a full numbers matching well documented truck with its original owners manual and Protect-O-Plate. I purchased this truck from the original owner in 2020. The truck retains all of its original sheet metal and panels. It had a frame off nut and bolt restoration in 2021 by Hot Rods and Customs of Tucson. The truck is in its correct Copper Poly exterior paint with a beautiful correct Medium Saddle and Parchment Custom Deluxe interior. It retains its original drive train that features a 350ci engine with 3 speed automatic transmission. It includes factory installed power steering, disk brakes and wood bed. I did install a period correct looking Blue Tooth audio system. All receipts, documentation and pictures of the restoration are fully available for your review. This truck is as true as you can get and is an absolute beauty to drive. https://phoenix.craigslist.org/evl/cto/7557320724.html
