Old 11-23-2022, 11:06 AM   #2276
piratexpress1369a
piratexpress1369a's Avatar
Re: My 52 GMC Build
Originally Posted by lower50's View Post
Well 7.3L idi diesel and transmission are out and 7.3L powerstroke is set in-ish. I will need to cut some of the fire wall at the top as well on the drivers side a bit. The motor is sitting on the motor mounts but needs to go back 1". Now to pull under the dash apart and remove all the wire to do with the old motor, then I can cut.
Attachment 2233502
Attachment 2233503
Attachment 2233504
Attachment 2233505
Attachment 2233506
That is going pretty quick so far
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 11-25-2022, 09:23 AM   #2277
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Originally Posted by Tempest67 View Post
well, you can't turn back now.
looking good,
Hope all is well
Sure I can I have only unbolted stuff but ya no going backwards. All is good.
Just remove about 50 bolts and the front end falls off. Marking all the wires as I go, so far so good.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 11-25-2022, 09:50 AM   #2278
OutlawDrifter
Re: My 52 GMC Build
Looking good! Can't wait to see how this one runs.
Taking that front end apart is what's keeping me from doing AC in mine.
For whatever reason I stopped getting updates a few pages back, they seem to be working now.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 11-29-2022, 08:25 AM   #2279
6DoF
6DoF's Avatar
Re: My 52 GMC Build
just wee little chops, sux to have to pull everything under the dash to make them.
that blue looks crazy in there!
6DoF is offline   Reply With Quote
Old 12-13-2022, 10:09 AM   #2280
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Don't let that hold you back we all had our trucks in little pieces at one point, at least this time it's only a bit of it.
Ya I'm changing up a bunch of other stuff at the same time, so not all bad.
Ya I really like the color.
1951 MG TD
Old 12-13-2022, 10:17 AM   #2281
lower50's
lower50's's Avatar
Re: My 52 GMC Build
A bit of fire wall massaging with a big hammer at the top for turbo clearance and had to cut a bit on drivers side to clear exhaust up pipe but not nearly as much as I thought. Welded up some holes that I'm not using any more as well. Added double layer of insulation to the fire wall and exhaust up pipes and turbo are wrapped. Closest place has 1/4" clearance with 3 layers of insulation plus the lizard skin on the inside, should be good.
1951 MG TD
Old 12-13-2022, 11:18 AM   #2282
6DoF
6DoF's Avatar
Re: My 52 GMC Build
just enough is all ya need!
but can you work on the exhaust without pulling the engine?
Old 12-13-2022, 11:22 AM   #2283
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Couple more pictures of the Power house Powerstroke install.
1951 MG TD
Old 12-13-2022, 11:24 AM   #2284
lower50's
lower50's's Avatar
Re: My 52 GMC Build
I should not have to ever get to the up pipes, but yes I would have to most likely pull turbo as well.
1951 MG TD
Old 12-13-2022, 11:49 AM   #2285
OutlawDrifter
Re: My 52 GMC Build
Definitely a tight fit!
1991 Z/28, 6.0L/T56
Old 12-13-2022, 08:36 PM   #2286
piratexpress1369a
Re: My 52 GMC Build
Dam that is close to the firewall...
63
Old 01-10-2023, 12:45 AM   #2287
lower50's
lower50's's Avatar
Re: My 52 GMC Build
I have had lots going on, so here we go. New exhaust pipes showed up, old motor had 3" new motor will have 4". All the 3" pipe I bought is for the intake pipes. Decided to make a new tail pipe out of the 6" dia 3/16" wall stainless pipe that the old one was made from. I made a tear drop tip. Took around 30hrs to make and the final cut took 45 min, had to go slow and help the blade go strait down.
1951 MG TD
Old 01-10-2023, 10:04 AM   #2288
Advanced Design
Advanced Design's Avatar
Re: My 52 GMC Build
Wow, impressive exhaust creation and sculpting….pure art.
Advanced Design is offline   Reply With Quote
Old 01-10-2023, 11:39 PM   #2289
dsraven
Re: My 52 GMC Build
curious, do you plan some sort of heat shield over the exposed area of the pipe? I ask because I was burned badly by an exposed pipe-on a firetruck at work, but still. it's likely gonna get hot and you likely won't wanna babysit it till it cools off.
nice work on fabbing those pipe bends.
Old 01-13-2023, 12:22 AM   #2290
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thank you, I wanted something different than what I had but similar.
Thank you! Well I had the old 6" tip for 8 years and 23,000mi no problems. Diesels do cool down when they idle I'm sure that helps. The way I am doing this one it will run even cooler, but thanks.
1951 MG TD
Old 01-13-2023, 12:32 AM   #2291
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Then onto cooling, new horizontal aluminum radiator that I modified to go vertical. It was off the shelf from Summit, they are both 4 core the new one is 6" longer and weighs 15lb less. The new fan is 2400cfm/17" and is 500cfm more and 1" bigger than the old one that worked ok. Had to trim the rad support a bit because the pullies are wider on this motor.
1951 MG TD
Old 01-13-2023, 10:16 AM   #2292
Tempest67
Tempest67's Avatar
Re: My 52 GMC Build
you are doing some very good work there Bob,
keep it going,
Tempest67 is offline   Reply With Quote
Old 01-14-2023, 04:56 PM   #2293
Advanced Design
Re: My 52 GMC Build
Yes, impressive work on the radiator!
Old 01-15-2023, 03:18 PM   #2294
piratexpress1369a
Re: My 52 GMC Build
Attachment 2248752
Attachment 2248753
Attachment 2248754
Attachment 2248755
Attachment 2248756
Looking good so far..stay at it Bob
63
Old 01-16-2023, 06:49 PM   #2295
lower50's
lower50's's Avatar
Re: My 52 GMC Build
keep it going,
Thank you
I can not take the credit for the welding I tried using my spool gun=lots of little holes so I had someone reweld it for me.
Thanks oh I will
1951 MG TD
Old 01-16-2023, 06:59 PM   #2296
lower50's
lower50's's Avatar
Re: My 52 GMC Build
So it has taken a ton of time to figure out what wires I need and where they need to go. (I can't find the right pinout for the computer) I started with the entire engine bay from the truck the motor came out of, whittled it down to what is in the 3rd picture then made spaghetti in my truck. I finally have everything hooked up, so the computer seems to be working properly. After I get the motor started I'll take it back out and make it all neat.
1951 MG TD
Old 01-17-2023, 12:06 AM   #2297
dsraven
Re: My 52 GMC Build
wiring is fun, isn;t it........
Old 01-17-2023, 03:41 PM   #2298
slammed57
slammed57's Avatar
Re: My 52 GMC Build
Attachment 2247358
Attachment 2247359
Attachment 2247360
Attachment 2247361
Attachment 2247362
that looks really slick. great work. making a complete exhaust system takes a ton of time. coming along great!
My 57 current build
http://67-72chevytrucks.com/vboard/s...d.php?t=662590
slammed57 is offline   Reply With Quote
Old 01-18-2023, 05:05 PM   #2299
lower50's
lower50's's Avatar
Re: My 52 GMC Build
I don't mind it, it would be a lot more fun if I could find the right pinout. But it's in the past now.
Thank you! I really like making full exhaust, I'll show it when I build it.
1951 MG TD
Old 01-18-2023, 05:16 PM   #2300
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Bit of a mish mash of stuff done. New lift pump and filter set up mounted in the rear same spot as the old setup. Then goes to my fuel cooler up to the motor and out through my regulated return system. I have 62psi without motor running, so I am perfect. Started my intake pipes, so far so good. I also got my new Dakota Digital gauges all working and set up, They are really nice to set up.
1951 MG TD
bagged, build, diesel, gmc, hot rod
