3 OTT and 3:08 gears
Anyone running this set up?
If so is "feathering" (slipping) the clutch required in first? Looking to reduce FWY RPM's Current gears, 3:73, 12 bolt truck My understanding I need to switch to a 2 series carrier to go higher gear ratio other than 3:73 |
Re: 3 OTT and 3:08 gears
Tire size has a big impact on the rpms. what tire size you running?
What engine and how do you use your truck? |
If you got torque, you need not worry about having to "feather" the clutch.
Have a 250 6 cyl
Yes aware tire size affects RPM. Current 235/75 x 15's BFG's with the 2.85 1st, was asking if anyone is using a 3:08 rear gear with 3 OTT I drive Fwy often so would like to run at 70mph vs 55 mph and be under 3k rpm. Using RPM calculator, the 3:08's do that |
I have a 1978 c10 with 350 /th350 and 3.08. It does do well, but you need more torque from the 250 to get there IMO. Consider a 3 speed with overdrive instead of a new rear end/gear change.
Honestly I think you're gonna be just fine, don't switch trans, don't add OD, just slip the clutch a bit.
As long as you really do mostly hwy driving. |
My 67 Camaro TH350 has 2.52 1st gear and I have 3:08 in that car. Yeah it makes over 400hp and TQ....so it will just boil the tires
Given the Saginaw 2:85 1st gear I suspect the 3:08 will be "normal" clutch engagement although I suspect won't just go off idle releasing the clutch now as it does with 3:73's Completely aware of other trans swap possibilities, just asking if anyone has 3OTT and 3:08's and what initial clutch release is (read does it require feathering or slipping) |
I ran that exact setup in a 68 back in the 80s. With the 250, you had to feather a bit but that engine was tired. I replaced it with a healthy stock 1972 350 and it lasted for years. I think you will be fine.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71 |
Who Changed This?
![]() Join Date: Jan 2013
^ Agreed. I had a '69 Camaro (admittedly, it had a 327) with a close-ratio Muncie (2.20:1 low) and a 3.08 axle. It worked just fine; got good mileage when I kept my leg out of it and had a crazy top end.
Subbing on this
![]() ![]() Join Date: Jul 2002
My 70 is a 3OTT with 3:08 rear. Granted I have a 350, but no issues driving normal. IF you are going to pull or haul heavy loads you then may be slipping clutch to get it rolling. My last truck was a 250 6 with 2.73 rear gears and no issues with it either. Just no low end umph, but drives just fine.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 01-03-2023 at 12:51 PM. |
![]() Join Date: Nov 2013
My Dad bought a new truck way back in 79....350 3OTT.....3.08
not a lot of clutch slipping normally...... but a lot trying to pull his boat up the ramp...
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
I don't have this combination. But I can't imagine not being hard on the clutch. I tried a 3.08 rear with a Muncie 4spd and felt that was too high pulling out. Went with 3.42s for a happy medium. I started off with 3.73s and was looking for better cruising gear. The thing I never liked about the 3spd is tall gearing down low. Not just off the line in 1st, but taking slow turns in 2nd gear too.
#14 | |
It sounds like a few people have managed with the setup the OP is asking about. |
#15 |
I do my own work. There's more to it than cost anyway. It's drivability. That was the question. I was giving my impression of the combination asked about by referring to another combination that should work better, having a lower first gear and closer ratios throughout (also a 325hp 350). I've had 6cyl/3spd trucks with 3.73 and couldn't imagine running 3.08s. I guess GM agreed. I never knew of anyone running that combination until this thread. Different people get different impressions. Mine is no thanks.
#16 | |
Its a Truck Thing......
Did the exact swap you are asking about. Yes on the 2 series carrier, and you will be Good to Go. I run 275/60/15's on mine and it runs fine. Original 250 6cyl, 3 OTT , 3.73 rear, Now 283, 3OTT, 3.07's or 8's depending on the day...Clutch works fine. Now go to a 2.76 and the truck will not pull itself over a curb without straining....(Been there, done that).... Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
#17 |
^^, thanks for the comments on your set up
The 2 series Yukon though is the biggest cost. Its a peg leg now. This truck may see a V8 swap at some point but for now the 250 six runs fine so will get to the gear/carrier swap. My 30 spline axles will work with the Yukon diff https://www.summitracing.com/parts/y...ckup/year/1972 Gears: https://www.summitracing.com/parts/m...-308?rrec=true Bearing Kit: https://www.summitracing.com/parts/m...rmkt?rrec=true |
#18 |
I'd go drive a truck with the exact setup I was considering before I spent a bunch of money and time on modifying the rear end.
#19 | |
Mine is a Open Carrier, I don't mind the Single Wheel Solo. It is a good cruiser that way for me. I changed everything and moved the engine to the V8 position when the 283 went in. I don't pull anything with it anymore so I am not worried about clutch slippage. I got enough trucks to do truck stuff. My C30's are going to be some great builds. Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time Last edited by 71meangreenc10; 01-05-2023 at 08:58 AM. |
#20 |
![]() Join Date: Feb 2016
This may be a cheaper option for you. Not my transmission. Just offering an alternative.
https://seattle.craigslist.org/sno/p...565561671.html
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
