01-16-2023, 11:02 AM | #3 | |
Re: Dana 44 Ring Gear Swap Question
Next question, would I be best to transfer the shims out of the closed knuckle axle, or use the shims that are in the new axle? I will definitely check the wear patterns and such, but would it be better to keep the shims and oil slinger with the donor pinion? Thanks, Clay
Clayton Sikes Peoria, Arizona 1967 Chevy K20 Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272 |
